I am using the concentrator-node example. In this example the DualModeSensorPacket structure is being used to send and receive data.Currently this structure has 22 bytes.
I want to send 10 more bytes, but as soon as I add 10 mores bytes the node side starts resetting . The EasyLink transmit and receive structure can carry a payload of 128 bytes, which is where DualModeSensorPacket structure is copied into, and when I debug I see the packet being created but after that the program starts resetting.
My issue is similar to the one discussed in https://e2e.ti.com/support/wireless-connectivity/sub-1-ghz/f/156/t/673782 , but no solution has been provided for this.
Can you suggest why this is happening?
Thank you.
