Other Parts Discussed in Thread: CC1350
1.i'm tring to make non rtos using call back that faild to work
i made maney changes how ever none of them seems to work .
2. i'm tring to sens and revice rf (that working exclent ) and getting uart input from user .
2.1 tx is working rx no working please advice
* Copyright (c) 2019, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/***** Includes *****/
/* Standard C Libraries */
#include <stdlib.h>
/* TI Drivers */
#include <ti/drivers/rf/RF.h>
#include <ti/drivers/PIN.h>
#include <ti/drivers/pin/PINCC26XX.h>
/* Driverlib Header files */
#include DeviceFamily_constructPath(driverlib/rf_prop_mailbox.h)
/* Board Header files */
#include "Board.h"
/* Application Header files */
#include "RFQueue.h"
#include "smartrf_settings/smartrf_settings.h"
#include <ti/drivers/UART.h>
#include <ti/drivers/ADC.h>
int i;
#define MAX_NUM_RX_BYTES 1000 // Maximum RX bytes to receive in one go
#define MAX_NUM_TX_BYTES 1000 // Maximum TX bytes to send in one go
// Number of bytes received so far
uint8_t rxBuf[MAX_NUM_RX_BYTES]; // Receive buffer
uint8_t txBuf[MAX_NUM_TX_BYTES]; // Transmit buffer
UART_Params uartParams;
UART_Handle uart;
char input;
char str[250];
char buftx[250],j=0;
/***** Defines *****/
/* Packet TX/RX Configuration */
#define PAYLOAD_LENGTH 30
/* Set packet interval to 1000ms */
#define PACKET_INTERVAL (uint32_t)(4000000*1.0f)
/* Set Receive timeout to 500ms */
#define RX_TIMEOUT (uint32_t)(4000000*0.5f)
/* NOTE: Only two data entries supported at the moment */
#define NUM_DATA_ENTRIES 2
/* The Data Entries data field will contain:
* 1 Header byte (RF_cmdPropRx.rxConf.bIncludeHdr = 0x1)
* Max 30 payload bytes
* 1 status byte (RF_cmdPropRx.rxConf.bAppendStatus = 0x1) */
#define NUM_APPENDED_BYTES 2
/* Log radio events in the callback */
//#define LOG_RADIO_EVENTS
/***** Prototypes *****/
static void echoCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e);
/***** Variable declarations *****/
static RF_Object rfObject;
static RF_Handle rfHandle;
/* Pin driver handle */
static PIN_Handle ledPinHandle;
static PIN_State ledPinState;
/* Buffer which contains all Data Entries for receiving data.
* Pragmas are needed to make sure this buffer is aligned to a 4 byte boundary
* (requirement from the RF core)
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_ALIGN(rxDataEntryBuffer, 4)
static uint8_t
rxDataEntryBuffer[RF_QUEUE_DATA_ENTRY_BUFFER_SIZE(NUM_DATA_ENTRIES,
PAYLOAD_LENGTH,
NUM_APPENDED_BYTES)];
#elif defined(__IAR_SYSTEMS_ICC__)
#pragma data_alignment = 4
static uint8_t
PAYLOAD_LENGTH,
#elif defined(__GNUC__)
static uint8_t
PAYLOAD_LENGTH,
__attribute__((aligned(4)));
#else
#error This compiler is not supported
#endif //defined(__TI_COMPILER_VERSION__)
/* Receive Statistics */
static rfc_propRxOutput_t rxStatistics;
/* Receive dataQueue for RF Core to fill in data */
static dataQueue_t dataQueue;
static rfc_dataEntryGeneral_t* currentDataEntry;
static uint8_t packetLength;
static uint8_t* packetDataPointer;
static uint8_t txPacket[PAYLOAD_LENGTH];
static uint8_t rxPacket[PAYLOAD_LENGTH + NUM_APPENDED_BYTES - 1];
static uint16_t seqNumber;
static volatile bool bRxSuccess = false;
#ifdef LOG_RADIO_EVENTS
static volatile RF_EventMask eventLog[32];
static volatile uint8_t evIndex = 0;
#endif // LOG_RADIO_EVENTS
* Application LED pin configuration table:
* - All LEDs board LEDs are off.
PIN_Config pinTable[] =
#if defined(Board_CC1350_LAUNCHXL)
Board_DIO30_SWPWR | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX,
#endif
Board_PIN_LED1 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
Board_PIN_LED2 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
PIN_TERMINATE
/***** Function definitions *****/
* Callback function to use the UART in callback mode. It does nothing.
void wuartCallback(UART_Handle handle, void *buf, size_t count) {
return;
int i;
uint32_t wantedRxBytes=3; // Number of bytes received so far
void ruartCallback(UART_Handle handle, void *buf, size_t count) {
int i;
UART_write(handle, "\r\nXXXXXXXX\r\n", 5);
// Make sure we received all expected bytes
if (count == wantedRxBytes) {
// Copy bytes from RX buffer to TX buffer
for(i = 0; i < count; i++)
txBuf[i] = ((uint8_t*)rxBuf)[i];
// Echo the bytes received back to transmitter
UART_write(handle, txBuf, count);
// Start another read, with size the same as it was during first call to
// UART_read()
UART_read(handle, rxBuf, wantedRxBytes);
else {
// Handle error or call to UART_readCancel()
uint8_t PacketCompare(uint8_t *txPacket,uint8_t *rxPacket,uint8_t lenght)
uint8_t i,equal;
equal=0;
for(i=0;i<lenght;i++) // start from 0
if (txPacket[i]==rxPacket[i])
equal++;
return(equal);
void *mainThread(void *arg0)
uint32_t curtime;
RF_Params rfParams;
RF_Params_init(&rfParams);
UART_init();
ADC_init();
const char ver[]="Xxxxxx Uart Rf test\r\n";
/* Create a UART with data processing off. */
UART_Params_init(&uartParams);
uartParams.writeDataMode = UART_DATA_BINARY;
uartParams.writeMode = UART_MODE_BLOCKING; //UART_MODE_CALLBACK;
uartParams.readMode = UART_MODE_BLOCKING;
uartParams.readDataMode = UART_DATA_BINARY;
uartParams.readEcho = UART_ECHO_OFF;
uartParams.readCallback = ruartCallback;
uartParams.writeCallback = wuartCallback;
// uartParams.readReturnMode=UART_RETURN_FULL;
uartParams.baudRate = 115200;
uart = UART_open(Board_UART0, &uartParams);
/* Display the data via UART */
UART_write(uart, ver, sizeof(ver));
strcpy(buftx,"Enter text to send [Enter]\r\n\0");
UART_write(uart,buftx,strlen(buftx));
/* Open LED pins */
ledPinHandle = PIN_open(&ledPinState, pinTable);
if (ledPinHandle == NULL)
while(1);
if(RFQueue_defineQueue(&dataQueue,
rxDataEntryBuffer,
sizeof(rxDataEntryBuffer),
NUM_DATA_ENTRIES,
PAYLOAD_LENGTH + NUM_APPENDED_BYTES))
/* Failed to allocate space for all data entries */
PIN_setOutputValue(ledPinHandle, Board_PIN_LED1, 1);
PIN_setOutputValue(ledPinHandle, Board_PIN_LED2, 1);
while(1);
/* Modify CMD_PROP_TX and CMD_PROP_RX commands for application needs */
RF_cmdPropTx.pktLen = PAYLOAD_LENGTH;
RF_cmdPropTx.pPkt = txPacket;
RF_cmdPropTx.startTrigger.triggerType = TRIG_ABSTIME;
RF_cmdPropTx.startTrigger.pastTrig = 1;
RF_cmdPropTx.startTime = 0;
RF_cmdPropTx.pNextOp = (rfc_radioOp_t *)&RF_cmdPropRx;
/* Only run the RX command if TX is successful */
RF_cmdPropTx.condition.rule = COND_STOP_ON_FALSE;
/* Set the Data Entity queue for received data */
RF_cmdPropRx.pQueue = &dataQueue;
/* Discard ignored packets from Rx queue */
RF_cmdPropRx.rxConf.bAutoFlushIgnored = 1;
/* Discard packets with CRC error from Rx queue */
RF_cmdPropRx.rxConf.bAutoFlushCrcErr = 1;
/* Implement packet length filtering to avoid PROP_ERROR_RXBUF */
RF_cmdPropRx.maxPktLen = PAYLOAD_LENGTH;
RF_cmdPropRx.pktConf.bRepeatOk = 0;
RF_cmdPropRx.pktConf.bRepeatNok = 0;
RF_cmdPropRx.pOutput = (uint8_t *)&rxStatistics;
/* Receive operation will end RX_TIMEOUT ms after command starts */
RF_cmdPropRx.endTrigger.triggerType = TRIG_REL_PREVEND;
RF_cmdPropRx.endTime = RX_TIMEOUT;
/* Request access to the radio */
#if defined(DeviceFamily_CC26X0R2)
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioSetup, &rfParams);
#else
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioDivSetup, &rfParams);
#endif// DeviceFamily_CC26X0R2
/* Set the frequency */
RF_postCmd(rfHandle, (RF_Op*)&RF_cmdFs, RF_PriorityNormal, NULL, 0);
/* Get current time */
curtime = RF_getCurrentTime();
int rxBytes = UART_read(uart, rxBuf, 1);
while(1)
/* Create packet with incrementing sequence number and random payload */
txPacket[0] = (uint8_t)(seqNumber >> 8);
txPacket[1] = (uint8_t)(seqNumber++);
uint8_t i;
for (i = 2; i < PAYLOAD_LENGTH; i++)
txPacket[i] = rand();
/* Set absolute TX time to utilize automatic power management */
curtime += PACKET_INTERVAL;
RF_cmdPropTx.startTime = curtime;
/* Transmit a packet and wait for its echo.
* - When the first of the two chained commands (TX) completes, the
* RF_EventCmdDone event is raised but not RF_EventLastCmdDone
* - The RF_EventLastCmdDone in addition to the RF_EventCmdDone events
* are raised when the second, and therefore last, command (RX) in the
* chain completes
* -- If the RF core successfully receives the echo it will also raise
* the RF_EventRxEntryDone event
* -- If the RF core times out while waiting for the echo it does not
* raise the RF_EventRxEntryDone event
RF_EventMask terminationReason =
RF_runCmd(rfHandle, (RF_Op*)&RF_cmdPropTx, RF_PriorityNormal,
echoCallback, (RF_EventCmdDone | RF_EventRxEntryDone |
RF_EventLastCmdDone));
switch(terminationReason)
case RF_EventLastCmdDone:
// A stand-alone radio operation command or the last radio
// operation command in a chain finished.
break;
case RF_EventCmdCancelled:
// Command cancelled before it was started; it can be caused
// by RF_cancelCmd() or RF_flushCmd().
break;
case RF_EventCmdAborted:
// Abrupt command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
case RF_EventCmdStopped:
// Graceful command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
default:
// Uncaught error event
while(1);
uint32_t cmdStatus = ((volatile RF_Op*)&RF_cmdPropTx)->status;
switch(cmdStatus)
case PROP_DONE_OK:
// Packet transmitted successfully
break;
case PROP_DONE_STOPPED:
// received CMD_STOP while transmitting packet and finished
// transmitting packet
break;
case PROP_DONE_ABORT:
// Received CMD_ABORT while transmitting packet
break;
case PROP_ERROR_PAR:
// Observed illegal parameter
break;
case PROP_ERROR_NO_SETUP:
// Command sent without setting up the radio in a supported
// mode using CMD_PROP_RADIO_SETUP or CMD_RADIO_SETUP
break;
case PROP_ERROR_NO_FS:
// Command sent without the synthesizer being programmed
break;
case PROP_ERROR_TXUNF:
// TX underflow observed during operation
break;
default:
// Uncaught error event - these could come from the
// pool of states defined in rf_mailbox.h
while(1);
eventLog[evIndex++ & 0x1F] = e;
#endif// LOG_RADIO_EVENTS
if((e & RF_EventCmdDone) && !(e & RF_EventLastCmdDone))
/* Successful TX */
/* Toggle LED1, clear LED2 to indicate TX */
!PIN_getOutputValue(Board_PIN_LED1));
PIN_setOutputValue(ledPinHandle, Board_PIN_LED2, 0);
else if(e & RF_EventRxEntryDone)
/* Successful RX */
bRxSuccess = true;
/* Get current unhandled data entry */
currentDataEntry = RFQueue_getDataEntry();
/* Handle the packet data, located at &(currentDataEntry->data):
* - Length is the first byte with the current configuration
* - Data starts from the second byte
packetLength = *(uint8_t *)(&(currentDataEntry->data));
packetDataPointer = (uint8_t *)(&(currentDataEntry->data) + 1);
/* Copy the payload + status byte to the rxPacket variable */
memcpy(rxPacket, packetDataPointer, (packetLength + 1));
/* Check the packet against what was transmitted */
int16_t status = memcmp(txPacket, rxPacket, packetLength);
if(status == 0)
/* Toggle LED1, clear LED2 to indicate RX */
else
/* Error Condition: set both LEDs */
RFQueue_nextEntry();
else if((e & RF_EventLastCmdDone) && !(e & RF_EventRxEntryDone))
if(bRxSuccess == true)
/* Received packet successfully but RX command didn't complete at
* the same time RX_ENTRY_DONE event was raised. Reset the flag
bRxSuccess = false;
else
/* RX timed out */
/* Set LED2, clear LED1 to indicate TX */
PIN_setOutputValue(ledPinHandle, Board_PIN_LED1, 0);
else
