  • Resolved
LAUNCHXL-CC1352P: Sensor and Collector - TI 15.4-Stack Project Zero - 863 Mhz instead of 868 Mhz
Expert 1985 points
Part Number: LAUNCHXL-CC1352P
I am following:
When I try to select the european freq for TI 15.4 , I get the choice between 915 and 863 Mhz. I think for Europe this should be 868 Mhz ?
Peter
  • Hey Peter,
    The European ISM band is 868 Mhz. This frequency range is approximately ~863-870 Mhz.
    Depending on your application, you'll need to select the appropriate channel to tune to the correct frequency.
    Ammar
    Please click the "This Resolved My Issue" button on this post if it answers your question
  • In reply to Ammar N:
    Hi Ammar
    How does the channel depends on the frequency ?
    I am not sure to understand what you mean with "appropriate channel to tune to the correct freq"
    Peter
  • In reply to Peter Vittali:
    Each channel is centered around a particular frequency. The OOB examples will select the least noisy channel to operate on from the channels enabled with the SysConfig tool.
    Peter Vittali
    I was mainly referring to regulatory compliance in the EU. I'm not too familiar in this area, but take a quick look at the following document for more info: http://www.ti.com/lit/an/swra048/swra048.pdf.
    If you have any follow up questions regarding the document above, please let me know!
    I apologize if I confused you in any way.
    Ammar
    Thanks Ammar, you didn't confuse with , it's just that I am new to the radio part and the link you provided is very helpful.
    Kind regards
    Peter
