Part Number: LAUNCHXL-CC1352R1
Is it okay to use other external flash memory? Like SST25VF080B.
We will be using the TI flash driver to read and write to this external flash memory.
Thank you and Regards
Jonathan
Jonathan
If SST25VF080B is functionally equivalent with the Macronix MX25R or WinBond W25X, then yes you can re-use the existing TI external NVS driver.
If it is not, then you need to implement the NVS driver yourself for the SST25VF080B. Take a look at the ti/drivers/nvs/NVSSPI25X.{h,c} for reference.
