Part Number: CC1200
The device is used with PKT_CFG1 = 0x03 and Data field = 4Byte.
When is PKT_CRC_OK reflected in the LQI_VAL register?
When is the timing when the MARCSTATUS register becomes RX_END?
What is the relationship between the MARCSTATUS register RX_END and FIFO_CFG.FIFO_THR?
How does FIFO_THR affect TX FIFO or transmission?
What should the value of FIFO_THR be set in this case?
Hitoshi Miyazawa
