We are currently using the CC1352R MCU. We need to stop the CPU from going into a low power mode after we generate a 802.15.4 message and transition into a CW beacon signal lasting approximately 100us.
We need to specify the message format and timing. We want TI 15.4 stack functionality with the CC1352R MCU, with the exception that at the end of a transmitted 802.15.4 message the MCU sends 100us CW signal, preferably with no interruption between the message and the CW signal.
The Ti15.4 stack is what generates IEEE 802.15.4 messages we use for communication.
Can you advise how to achieve the above?
We are currently just using the regular API call for a data frame transmission that’s provided by the 15.4-stack library:
ApiMac_mcpsDataReq(&dataReq);
