The CC1125 has a FREQOFF register (or, rather, pair of registers) which specifies an offset to the frequency given by the FREQ registers.
Am I correct in thinking that this offset is always applied - there is no way to disable it ?
ie, if you want no offset, you must just set the FREQOFF value to zero.
I ask because there is also a register called (unhelpfully?) FREQOFF_CFG
Clearly, the name suggests that it would affect the operation of FREQOFF - but the description seems entirely unrelated ?
Please clarify!
