Does the Listen Before Talk (LBT) feature work with Transparent Serial Mode ?
Is this a general question or are you planning to use transparent mode?
I see that you have a lot of questions about this chip, could you share some details of your application/ use case and it would be easier to answer the questions in that context.
Yes, it is an existing application using Transparent mode.
Currently, it just transmits regardless.
The requirement is to add the facility to check that the channel is "free" before starting to transmit.
EDIT
The application is in the 434 MHz band.
