Other Parts Discussed in Thread: CC1190
Hi E2E,
Good day!
Do we have the noise vs gain graph of CC1200?
Franz
I don't believe we have a graph that shows noise (which noise?) vs front end gain.
Typically the AGC is on meaning that the gain is set according to the input signal. To get the best possible sensitivity the AGC always starts with max gain.
Could you please elaborate some on what you would use a graph like this for? I assume the customer has requested this graph for some reason and knowing that reason would help covering what the customer needs to know.
Hi TER,
Sorry for the late response.
The customer wants to add an LNA upfront the CC1200 to improved the sensitivity. To make a good analysis the need the noise figure VS the gain of the CC1200.
Franz
They will gain about 3 dB of sensitivity using an external LNA. I have measured this both using CC1190 in RX and various Skyworks FEMs. I would assume it's possible to get somewhat better result but then the LNA has to have a very low noise figure meaning that both cost and current consumption will be very high.
Hi TER,
Thank you for your help.
My customer asked if RX AGC gain in function of the RX level? Also, is the measurement above done it actual boards?
Franz
Yes, the AGC gain is a function of input level. AGC_REF sets the level where the AGC start to reduce gain.
Yes, these are measurements done on multiple actual boards.
