Part Number: CC1352R
A customer wanted to implement a customizing bootloader,which was used to update flash image. But if any interrupt was included,like UART/TIMER,the jumpToPrgEntry(0) function could not jump to the APP and device got crashed. He put the bootloader in the last few pages in flash and app at 0x00, add #define SET_CCFG_IMAGE_VALID_CONF_IMAGE_VALID 0x50000 in bootloader.Please check the following configuration[icf of bootloader]:
// Memory Sizes
define symbol FLASH_BASE = 0x00000000;
define symbol RAM_BASE = 0x20000000;
define symbol ROM_BASE = 0x10000000;
if ( isdefinedsymbol(CC2650) )
define symbol RAM_SIZE = 0x00005000; // 20K
define symbol FLASH_SIZE = 0x00020000; // 128K
define symbol ROM_SIZE = 0x0001C000; // 115K
else if ( isdefinedsymbol(CC2642) )
define symbol RAM_SIZE = 0x00014000; // 80K
define symbol FLASH_SIZE = 0x00058000; // 352K
define symbol ROM_SIZE = 0x00040000; // 256K
// Memory Definitions
// RAM
//define symbol RESERVED_RAM_SIZE = 0x00000EB3;
define symbol RESERVED_RAM_SIZE = 0x00000ED4;
define symbol RAM_START = RAM_BASE + 0x0000012C + RESERVED_RAM_SIZE; // PG 2.0 & PG2.1 Agama RAM_START
define symbol RAM_END = RAM_BASE+RAM_SIZE-1;
// Flash
define symbol WORD_SIZE = 4;
define symbol PAGE_SIZE = 0x1000;
define symbol PAGE_SIZE = 0x2000;
export symbol PAGE_SIZE;
if (isdefinedsymbol(PAGE_ALIGN))
define symbol FLASH_MEM_ALIGN = PAGE_SIZE;
else
define symbol FLASH_MEM_ALIGN = WORD_SIZE;
define symbol FLASH_START = FLASH_BASE;
define symbol PAGE_MASK = 0xFFFFF000;
define symbol PAGE_MASK = 0xFFFFE000;
// BIM is allocated at flash sector.
define symbol FLASH_PAGE_BIMSTART = 0x50000;//FLASH_BASE + FLASH_SIZE - PAGE_SIZE;
define symbol FLASH_PAGE_BIMEND = FLASH_BASE + FLASH_SIZE; //0x0001FFFF;
else
// leaving 4 bytes of buffer between CCFG and veify function pointer
define symbol FLASH_FNPTR_START = 0x00057fa0;
define symbol FLASH_FNPTR_END = 0x00057fa3;
//storing cert element in fixed flash region,
//length of region is size of cert_element_t
define symbol CERT_END = FLASH_FNPTR_START - 1;
define symbol CERT_SIZE = 0x4C; // For version 1 ECDSA-P256
define symbol CERT_START = CERT_END - CERT_SIZE + 1;
// Stack
define symbol STACK_SIZE = 0x400;
define symbol STACK_START = RAM_END;
define symbol STACK_END = STACK_START - STACK_SIZE;
define block CSTACK with alignment = 8, size = STACK_SIZE { section .stack };
define symbol STACK_TOP = RAM_END + 1;
export symbol STACK_TOP;
// Flash Interrupt Vector Table
define symbol INTVEC_NUM_ENTRIES = 50 + 1; // first entry is stack location
define symbol INTVEC_SIZE = INTVEC_NUM_ENTRIES + 4;
// Memory Regions
define memory mem with size = 4G;
define region RAM = mem:[from RAM_START to RAM_END];
define region BIM = mem:[from FLASH_PAGE_BIMSTART
to FLASH_PAGE_BIMEND];
define region FLASH_FN_PTR = mem:[from FLASH_FNPTR_START
to FLASH_FNPTR_END];
define region CERT_ELEMENT = mem:[from CERT_START
to CERT_END];
// Memory Placement
// Function pointer table address
place at start of FLASH_FN_PTR { readonly section .fnPtr };
keep { readonly section .fnPtr };
define block CERT { ro section .cert_element};
keep { ro section .cert_element};
place at start of CERT_ELEMENT { block CERT};
// Interrupt Vector Table
place at address mem:FLASH_PAGE_BIMSTART { readonly section .intvec_boot };
//keep { readonly section .intvec_boot };
// CCFG
place at end of BIM { readonly section .ccfg };
keep { section .ccfg };
// RAM Vector Table
place at start of RAM { section .vtable_ram };
define block RWDATA { rw };
define section .heap_start { public heapStart: };
define section .heap_end { public heapEnd: };
define block HEAP_END with size = 1 { section .heap_end };
define block END_OF_RAM with fixed order {
block HEAP_END,
block CSTACK
place at end of RAM { block END_OF_RAM };
place in RAM { block RWDATA,
last section .heap_start};
// Stack
//place at end of RAM { block CSTACK };
/* Primary Heap configuration */
//define symbol HEAPSIZE = 2048;
//define block HEAP with alignment = 8, size = HEAPSIZE { };
/* Place heap just before CSTACK */
//place in RAM { block HEAP };
//place in RAM { readwrite };
place in BIM { readonly };
// Initialization
initialize by copy { readwrite };
do not initialize
section .noinit,
section .stack,
在app的icf:
/* Intvec start */
define symbol FLASH_BASE__ = 0x00000000;
if (!isdefinedsymbol(NVOCMP_NVPAGES)) {
define symbol NVOCMP_NVPAGES = 2;
/* Memory Regions*/
//define symbol FLASH_SIZE = 0x00058000; // 352K
//define symbol PAGE_SIZE = 0x2000;
define symbol FLASH_LAST_base__ = 0x0004C000;//0x0004C000;//(FLASH_SIZE-(PAGE_SIZE*6));// boot
define symbol FLASH_LAST_size__ = 0x00002000;
define symbol FLASH_CCFG_BASE = 0x00057FA8;
define symbol FLASH_CCFG_SIZE = 0x00000058;
define symbol FLASH_NV_base__ = (0x4C000 - (NVOCMP_NVPAGES * 0x2000)); // NV Flash base
define symbol FLASH_NV_size__ = (NVOCMP_NVPAGES * 0x2000);
define symbol FLASH_SIZE__ = (0x4C000 - (NVOCMP_NVPAGES * 0x2000));
define symbol RAM_base__ = 0x20000000;
define symbol RAM_size__ = 0x14000;
/* Define a memory region that covers the entire 4 GB addressable space */
/* Define a region for the on-chip flash */
define region FLASH_region = mem:[from FLASH_BASE__ size FLASH_SIZE__];
/* Define a region for the on-chip flash used for NV storage */
define region FLASH_NV_region = mem:[from FLASH_NV_base__ size FLASH_NV_size__];
/* Define a region for the last flash page */
define region FLASH_last_region__ = mem:[from FLASH_LAST_base__ size FLASH_LAST_size__];
//define a region for ccfg flash
define region FLASH_ccfg_region__ = mem:[from FLASH_CCFG_BASE size FLASH_CCFG_SIZE];
/* Internal RAM for data used by application */
define region RAM_region = mem:[from RAM_base__ size RAM_size__];
/* Place the interrupt vectors at the start of flash */
place at address mem:FLASH_BASE__ { readonly section .intvec };
keep { section .intvec};
/* Place the CCA area at the end of flash */
//place at end of FLASH_last_region__ { readonly section .ccfg };
//place at end of FLASH_ccfg_region__ { readonly section .ccfg };
//keep { section .ccfg };
"AGAMA_CCFG_AREA":
place noload in FLASH_ccfg_region__ { readonly section .ccfg };
place in FLASH_last_region__ { section .text object nvoctp.o };
place in FLASH_last_region__ { section .text object macTask.o };
place in FLASH_last_region__ { section .text object api_mac.o };
place in FLASH_last_region__ { section .text object osal_port.o };
place in FLASH_last_region__ { section .text object saddr.o };
place in FLASH_region { section .text };
place in FLASH_region { readonly section .const object mac_user_config.o };
section .const,
section .constdata,
section .rodata,
section .cinit,
section .pinit,
section .init_array,
section .emb_text
/* Place remaining 'read only' in Flash */
place in FLASH_region { readonly };
/* Mark the beginning of the NV Flash page */
place at start of FLASH_NV_region { readonly section .snvSectors };
/* Place .vtable_ram in start of RAM */
place at start of RAM_region { section .vtable_ram };
place in RAM_region {
section .data,
section .bss,
section .vtable,
section .vtable_ram,
section .sysmem,
section .nonretenvar,
* Define CSTACK block to contain .stack section. This enables the IAR IDE
* to properly show the stack content during debug. Place stack at end of
* retention RAM, do not initialize (initializing the stack will destroy the
* return address from the initialization code, causing the processor to branch
* to zero and fault)
define symbol STACKSIZE = 1024;
define block CSTACK with alignment = 8, size = STACKSIZE { section .stack };
//place at end of RAM_region { block CSTACK };
if (isdefinedsymbol(ROM_TIMACDataAddr)) {
place at address mem:ROM_TIMACDataAddr {section .data_RAM_BASE_ADDR };
/* Export stack top symbol. Used by startup file */
define exported symbol STACK_TOP = end(RAM_region) + 1;
block HEAP_END,
block CSTACK
place at end of RAM_region { block END_OF_RAM };
place in RAM_region { block RWDATA,
do not initialize { section .stack, section .noinit};
* The USE_TIRTOS_ROM symbol is defined internally in the build flow (using
* --config_def USE_TIRTOS_ROM=1) for TI-RTOS applications whose app.cfg file
* specifies to use the ROM.
if (isdefinedsymbol(USE_TIRTOS_ROM)) {
include "TIRTOS_ROM.icf";
