Now I use CC1310, TI 15.4 stack, china 433 band.
In actual use, should a repeater be added to link the collector and sensor?
There is no need for a repeater to link the collector and sensor, are you actually asking if it is possible to have an repeater?
If that is the case, the answer is that the stack as such does not provide any such support but there have been costumers that implement their own repeater applications based on the examples in the SDK (even if they showcase a collector / sensor setup, you could really use the MAC in other ways if you want as well).
