I am trying to fill out the Range Estimator Spreadsheet for debugging range issues. I am not sure what value to input for Noise Floor when it has some time-variance. Also, the cells in the spreadsheet are color coded, -100dBm is red which seems to indicate that the spreadsheet creator thought this is "noisier than typical". This is in the United States, suburban environment, 915MHz band, this level seems typical for me.
My application can tolerate retransmissions, so I believe using the approximate "mean" value of the noise floor would be appropriate for range calculations. Should I call this -100dBm?
Arthur
