Other Parts Discussed in Thread: CC1120
My customers send and receive using products with CC1121.
CC1121 is set to append RSSI to the packet.(PKT_CFG1.APPEND_STATUS=1)
After communicating for a few minutes, the RSSI value of the packet will be abnormal.
They compared packet's RSSI value with register's RSSI value. It is usually the same value, but sometimes the packet's value becomes abnormal.
Question 1:
How is the RSSI value of a packet calculated? Is it the same as the register value?
Question 2:
Their product outputs the RSSI of the packet to the LCD. They want this value to be normal. Would you tell me the solution?
Register settings (SmartRF Studio & EVM)
Tx
// Rf settings for CC1120 RF_SETTINGS code rfSettings = { 0xB0, // IOCFG3 GPIO3 IO Pin Configuration 0x06, // IOCFG2 GPIO2 IO Pin Configuration 0xB0, // IOCFG1 GPIO1 IO Pin Configuration 0x40, // IOCFG0 GPIO0 IO Pin Configuration 0x08, // SYNC_CFG1 Sync Word Detection Configuration Reg. 1 0x17, // SYNC_CFG0 Sync Word Length Configuration Reg. 0 0x9A, // DEVIATION_M Frequency Deviation Configuration 0x0D, // MODCFG_DEV_E Modulation Format and Frequency Deviation Configur.. 0x1C, // DCFILT_CFG Digital DC Removal Configuration 0x14, // PREAMBLE_CFG1 Preamble Length Configuration Reg. 1 0x2A, // PREAMBLE_CFG0 Preamble Detection Configuration Reg. 0 0x40, // FREQ_IF_CFG RX Mixer Frequency Configuration 0x00, // IQIC Digital Image Channel Compensation Configuration 0x02, // CHAN_BW Channel Filter Configuration 0x46, // MDMCFG1 General Modem Parameter Configuration Reg. 1 0x05, // MDMCFG0 General Modem Parameter Configuration Reg. 0 0x99, // SYMBOL_RATE2 Symbol Rate Configuration Exponent and Mantissa [1.. 0x99, // SYMBOL_RATE1 Symbol Rate Configuration Mantissa [15:8] 0x9A, // SYMBOL_RATE0 Symbol Rate Configuration Mantissa [7:0] 0x36, // AGC_REF AGC Reference Level Configuration 0x19, // AGC_CS_THR Carrier Sense Threshold Configuration 0x00, // AGC_GAIN_ADJUST RSSI Offset Configuration 0x91, // AGC_CFG3 Automatic Gain Control Configuration Reg. 3 0x20, // AGC_CFG2 Automatic Gain Control Configuration Reg. 2 0xA9, // AGC_CFG1 Automatic Gain Control Configuration Reg. 1 0xCF, // AGC_CFG0 Automatic Gain Control Configuration Reg. 0 0x00, // FIFO_CFG FIFO Configuration 0x00, // DEV_ADDR Device Address Configuration 0x03, // SETTLING_CFG Frequency Synthesizer Calibration and Settling Con.. 0x12, // FS_CFG Frequency Synthesizer Configuration 0x08, // WOR_CFG1 eWOR Configuration Reg. 1 0x21, // WOR_CFG0 eWOR Configuration Reg. 0 0x00, // WOR_EVENT0_MSB Event 0 Configuration MSB 0x00, // WOR_EVENT0_LSB Event 0 Configuration LSB 0x04, // PKT_CFG2 Packet Configuration Reg. 2 0x45, // PKT_CFG1 Packet Configuration Reg. 1 0x20, // PKT_CFG0 Packet Configuration Reg. 0 0x0F, // RFEND_CFG1 RFEND Configuration Reg. 1 0x00, // RFEND_CFG0 RFEND Configuration Reg. 0 0x7F, // PA_CFG2 Power Amplifier Configuration Reg. 2 0x56, // PA_CFG1 Power Amplifier Configuration Reg. 1 0x7B, // PA_CFG0 Power Amplifier Configuration Reg. 0 0xFF, // PKT_LEN Packet Length Configuration 0x00, // IF_MIX_CFG IF Mix Configuration 0x22, // FREQOFF_CFG Frequency Offset Correction Configuration 0x0B, // TOC_CFG Timing Offset Correction Configuration 0x00, // MARC_SPARE MARC Spare 0x00, // ECG_CFG External Clock Frequency Configuration 0x00, // CFM_DATA_CFG Custom frequency modulation enable 0x01, // EXT_CTRL External Control Configuration 0x00, // RCCAL_FINE RC Oscillator Calibration Fine 0x00, // RCCAL_COARSE RC Oscillator Calibration Coarse 0x00, // RCCAL_OFFSET RC Oscillator Calibration Clock Offset 0x00, // FREQOFF1 Frequency Offset MSB 0x00, // FREQOFF0 Frequency Offset LSB 0x73, // FREQ2 Frequency Configuration [23:16] 0xF9, // FREQ1 Frequency Configuration [15:8] 0x99, // FREQ0 Frequency Configuration [7:0] 0x02, // IF_ADC2 Analog to Digital Converter Configuration Reg. 2 0xA6, // IF_ADC1 Analog to Digital Converter Configuration Reg. 1 0x04, // IF_ADC0 Analog to Digital Converter Configuration Reg. 0 0x00, // FS_DIG1 Frequency Synthesizer Digital Reg. 1 0x5F, // FS_DIG0 Frequency Synthesizer Digital Reg. 0 0x00, // FS_CAL3 Frequency Synthesizer Calibration Reg. 3 0x20, // FS_CAL2 Frequency Synthesizer Calibration Reg. 2 0x40, // FS_CAL1 Frequency Synthesizer Calibration Reg. 1 0x0E, // FS_CAL0 Frequency Synthesizer Calibration Reg. 0 0x28, // FS_CHP Frequency Synthesizer Charge Pump Configuration 0x03, // FS_DIVTWO Frequency Synthesizer Divide by 2 0x00, // FS_DSM1 FS Digital Synthesizer Module Configuration Reg. 1 0x33, // FS_DSM0 FS Digital Synthesizer Module Configuration Reg. 0 0xFF, // FS_DVC1 Frequency Synthesizer Divider Chain Configuration .. 0x17, // FS_DVC0 Frequency Synthesizer Divider Chain Configuration .. 0x00, // FS_LBI Frequency Synthesizer Local Bias Configuration 0x50, // FS_PFD Frequency Synthesizer Phase Frequency Detector Con.. 0x6E, // FS_PRE Frequency Synthesizer Prescaler Configuration 0x14, // FS_REG_DIV_CML Frequency Synthesizer Divider Regulator Configurat.. 0xAC, // FS_SPARE Frequency Synthesizer Spare 0x14, // FS_VCO4 FS Voltage Controlled Oscillator Configuration Reg.. 0x00, // FS_VCO3 FS Voltage Controlled Oscillator Configuration Reg.. 0x00, // FS_VCO2 FS Voltage Controlled Oscillator Configuration Reg.. 0x00, // FS_VCO1 FS Voltage Controlled Oscillator Configuration Reg.. 0xB4, // FS_VCO0 FS Voltage Controlled Oscillator Configuration Reg.. 0x00, // GBIAS6 Global Bias Configuration Reg. 6 0x02, // GBIAS5 Global Bias Configuration Reg. 5 0x00, // GBIAS4 Global Bias Configuration Reg. 4 0x00, // GBIAS3 Global Bias Configuration Reg. 3 0x10, // GBIAS2 Global Bias Configuration Reg. 2 0x00, // GBIAS1 Global Bias Configuration Reg. 1 0x00, // GBIAS0 Global Bias Configuration Reg. 0 0x01, // IFAMP Intermediate Frequency Amplifier Configuration 0x01, // LNA Low Noise Amplifier Configuration 0x01, // RXMIX RX Mixer Configuration 0x0E, // XOSC5 Crystal Oscillator Configuration Reg. 5 0xA0, // XOSC4 Crystal Oscillator Configuration Reg. 4 0x03, // XOSC3 Crystal Oscillator Configuration Reg. 3 0x04, // XOSC2 Crystal Oscillator Configuration Reg. 2 0x03, // XOSC1 Crystal Oscillator Configuration Reg. 1 0x00, // XOSC0 Crystal Oscillator Configuration Reg. 0 0x00, // ANALOG_SPARE Analog Spare 0x00, // PA_CFG3 Power Amplifier Configuration Reg. 3 0x00, // WOR_TIME1 eWOR Timer Counter Value MSB 0x00, // WOR_TIME0 eWOR Timer Counter Value LSB 0x00, // WOR_CAPTURE1 eWOR Timer Capture Value MSB 0x00, // WOR_CAPTURE0 eWOR Timer Capture Value LSB 0x00, // BIST MARC Built-In Self-Test 0x00, // DCFILTOFFSET_I1 DC Filter Offset I MSB 0x00, // DCFILTOFFSET_I0 DC Filter Offset I LSB 0x00, // DCFILTOFFSET_Q1 DC Filter Offset Q MSB 0x00, // DCFILTOFFSET_Q0 DC Filter Offset Q LSB 0x00, // IQIE_I1 IQ Imbalance Value I MSB 0x00, // IQIE_I0 IQ Imbalance Value I LSB 0x00, // IQIE_Q1 IQ Imbalance Value Q MSB 0x00, // IQIE_Q0 IQ Imbalance Value Q LSB 0x80, // RSSI1 Received Signal Strength Indicator Reg. 1 0x00, // RSSI0 Received Signal Strength Indicator Reg.0 0x41, // MARCSTATE MARC State 0x00, // LQI_VAL Link Quality Indicator Value 0xFF, // PQT_SYNC_ERR Preamble and Sync Word Error 0x00, // DEM_STATUS Demodulator Status 0x00, // FREQOFF_EST1 Frequency Offset Estimate MSB 0x00, // FREQOFF_EST0 Frequency Offset Estimate LSB 0x00, // AGC_GAIN3 Automatic Gain Control Reg. 3 0xD1, // AGC_GAIN2 Automatic Gain Control Reg. 2 0x00, // AGC_GAIN1 Automatic Gain Control Reg. 1 0x3F, // AGC_GAIN0 Automatic Gain Control Reg. 0 0x00, // CFM_RX_DATA_OUT Custom Frequency Modulation RX Data 0x00, // CFM_TX_DATA_IN Custom Frequency Modulation TX Data 0x30, // ASK_SOFT_RX_DATA ASK Soft Decision Output 0x7F, // RNDGEN Random Number Generator Value 0x00, // MAGN2 Signal Magnitude after CORDIC [16] 0x00, // MAGN1 Signal Magnitude after CORDIC [15:8] 0x00, // MAGN0 Signal Magnitude after CORDIC [7:0] 0x00, // ANG1 Signal Angular after CORDIC [9:8] 0x00, // ANG0 Signal Angular after CORDIC [7:0] 0x08, // CHFILT_I2 Channel Filter Data Real Part [18:16] 0x00, // CHFILT_I1 Channel Filter Data Real Part [15:8] 0x00, // CHFILT_I0 Channel Filter Data Real Part [7:0] 0x00, // CHFILT_Q2 Channel Filter Data Imaginary Part [18:16] 0x00, // CHFILT_Q1 Channel Filter Data Imaginary Part [15:8] 0x00, // CHFILT_Q0 Channel Filter Data Imaginary Part [7:0] 0x00, // GPIO_STATUS General Purpose Input/Output Status 0x01, // FSCAL_CTRL Frequency Synthesizer Calibration Control 0x00, // PHASE_ADJUST Frequency Synthesizer Phase Adjust 0x48, // PARTNUMBER Part Number 0x21, // PARTVERSION Part Revision 0x00, // SERIAL_STATUS Serial Status 0x10, // MODEM_STATUS1 Modem Status Reg. 1 0x00, // MODEM_STATUS0 Modem Status Reg. 0 0x00, // MARC_STATUS1 MARC Status Reg. 1 0x00, // MARC_STATUS0 MARC Status Reg. 0 0x00, // PA_IFAMP_TEST Power Amplifier Intermediate Frequency Amplifier T.. 0x00, // FSRF_TEST Frequency Synthesizer Test 0x00, // PRE_TEST Frequency Synthesizer Prescaler Test 0x00, // PRE_OVR Frequency Synthesizer Prescaler Override 0x00, // ADC_TEST Analog to Digital Converter Test 0x0B, // DVC_TEST Digital Divider Chain Test 0x40, // ATEST Analog Test 0x00, // ATEST_LVDS Analog Test LVDS 0x00, // ATEST_MODE Analog Test Mode 0x3C, // XOSC_TEST1 Crystal Oscillator Test Reg. 1 0x00, // XOSC_TEST0 Crystal Oscillator Test Reg. 0 0x00, // RXFIRST RX FIFO Pointer First Entry 0x00, // TXFIRST TX FIFO Pointer First Entry 0x00, // RXLAST RX FIFO Pointer Last Entry 0x00, // TXLAST TX FIFO Pointer Last Entry 0x00, // NUM_TXBYTES TX FIFO Status 0x00, // NUM_RXBYTES RX FIFO Status 0x0F, // FIFO_NUM_TXBYTES TX FIFO Status 0x00, // FIFO_NUM_RXBYTES RX FIFO Status };
Rx
Rei
