I see that the PCB trace antenna for the LAUNCHXL-CC1352P1 design is dual band - 868MHz/2440MHz. Can you share the performance characteristics of this antenna at these two frequencies ?
Refer to attached documents for the antenna performance.
The measurements at 868 MHz exceed 100% efficiency but this is due to the tolerance of an EMC chamber.
The antenna on CC1352Px is primary targeted for 868-928 MHz operation and secondary at 2.4GHz.
Will you be operating at 868 MHz and 2.4 GHz or 868/915 MHz and 2.4 GHz ?
CC1352P1 - CC1352P-2 - 5p6F LP series 3n3H HP series - 868 MHz.Pdf
CC1352P1 - CC1352P-2 - 5p6F LP series 3n3H HP series - 915 MHz.Pdf
CC1352P1 - CC1352P-2 - 5p6F LP series 3n3H HP series - 2400 MHz.Pdf
CC1352P1 - CC1352P-2 - 5p6F LP series 3n3H HP series - 2480 MHz.Pdf
