Other Parts Discussed in Thread: CC1101, CC1310
How can I increase the communication distance between CC1101 and CC1310 I use.
antenna distance 100 meters on average
The smartRF studio outputs I use are as follows
<?xml version="1.0" encoding="ISO-8859-1"?> <!DOCTYPE configuration SYSTEM "C:/Program Files (x86)/Texas Instruments/SmartRF Tools/SmartRF Studio 7/config/xml/configdata.dtd"[]> <dcpanelconfiguration> <Devicename>CC1101</Devicename> <Description>Saved configuration data</Description> <registersettings> <Register> <Name>AGCCTRL0</Name> <Value>0x92</Value> </Register> <Register> <Name>DEVIATN</Name> <Value>0x15</Value> </Register> <Register> <Name>FIFOTHR</Name> <Value>0x47</Value> </Register> <Register> <Name>FOCCFG</Name> <Value>0x14</Value> </Register> <Register> <Name>FREND0</Name> <Value>0x11</Value> </Register> <Register> <Name>FREQ0</Name> <Value>0x76</Value> </Register> <Register> <Name>FREQ1</Name> <Value>0x62</Value> </Register> <Register> <Name>FREQ2</Name> <Value>0x21</Value> </Register> <Register> <Name>FSCAL0</Name> <Value>0x1f</Value> </Register> <Register> <Name>FSCAL1</Name> <Value>0x00</Value> </Register> <Register> <Name>FSCAL2</Name> <Value>0x2a</Value> </Register> <Register> <Name>FSCAL3</Name> <Value>0xe9</Value> </Register> <Register> <Name>FSCTRL1</Name> <Value>0x06</Value> </Register> <Register> <Name>IOCFG0</Name> <Value>0x06</Value> </Register> <Register> <Name>LQI</Name> <Value>0x7f</Value> </Register> <Register> <Name>MARCSTATE</Name> <Value>0x01</Value> </Register> <Register> <Name>MCSM0</Name> <Value>0x18</Value> </Register> <Register> <Name>MDMCFG2</Name> <Value>0x33</Value> </Register> <Register> <Name>MDMCFG3</Name> <Value>0x83</Value> </Register> <Register> <Name>MDMCFG4</Name> <Value>0xf7</Value> </Register> <Register> <Name>PA_TABLE1</Name> <Value>0x50</Value> </Register> <Register> <Name>PKTCTRL0</Name> <Value>0x05</Value> </Register> <Register> <Name>RSSI</Name> <Value>0x80</Value> </Register> <Register> <Name>TEST0</Name> <Value>0x09</Value> </Register> <Register> <Name>TEST1</Name> <Value>0x35</Value> </Register> <Register> <Name>TEST2</Name> <Value>0x81</Value> </Register> <Register> <Name>VCO_VC_DAC</Name> <Value>0x94</Value> </Register> <Register> <Name>WORCTRL</Name> <Value>0xfb</Value> </Register> </registersettings> <dcpanel> <Property role="44" name="m_chkRegView">2</Property> <Property role="44" name="m_chkCmdView">0</Property> <Property role="44" name="m_chkRfParameters">2</Property> <Property role="46" name="m_cmbUserMode">1</Property> <Property role="33" name="m_easyModeSettings">-1</Property> <Property role="33" name="m_typicalSettings">-1</Property> <Property role="37" name="m_testFuncPanel">3</Property> </dcpanel> <rfparameters> <Property role="46" name="m_cmbFrontends">0</Property> <Property role="44" name="m_chkHGMorBYP">2</Property> <Property role="46" name="m_cmbEmRevs">-1</Property> <Property role="46" name="Xtal Frequency">26.000000</Property> </rfparameters> <conttx> <Property role="45" name="m_rbtModulated">1</Property> <Property role="45" name="m_rbtUnmodulated">0</Property> <Property role="46" name="m_cmbDataFormat">-1</Property> <Property role="44" name="m_chkFreqSweep">0</Property> <Property role="44" name="m_chkChanSweep">0</Property> </conttx> <contrx> <Property role="46" name="m_cmbDataFormat">-1</Property> <Property role="44" name="m_chkAutoScroll">2</Property> </contrx> <packettx> <Property role="42" name="m_edtPayloadSize">30</Property> <Property role="42" name="m_edtPacketCount">100</Property> <Property role="42" name="m_edtPacketCountEsy">100</Property> <Property role="42" name="m_edtRandomPacketData">13 0d 89 0a 1c db ae 32 20 9a 50 ee 40 78 36 fd 12 49 32 f6 9e 7d 49 dc ad 4f 14 f2 </Property> <Property role="42" name="m_edtPacketData"></Property> <Property role="42" name="m_edtAccessAddress"></Property> <Property role="42" name="m_edtDeviceAddress"></Property> <Property role="44" name="m_chkAddSeqNbr">2</Property> <Property role="44" name="m_chkInfinite">0</Property> <Property role="44" name="m_chkInfiniteEsy">0</Property> <Property role="45" name="m_rbtRandom">1</Property> <Property role="45" name="m_rbtText">0</Property> <Property role="45" name="m_rbtHex">0</Property> <Property role="44" name="m_chkAdvanced">0</Property> </packettx> <packetrx> <Property role="42" name="m_edtPacketCount">100</Property> <Property role="42" name="m_edtPacketCountEsy">100</Property> <Property role="42" name="m_edtAccessAddress"></Property> <Property role="44" name="m_chkInfinite">0</Property> <Property role="44" name="m_chkInfiniteEsy">0</Property> <Property role="46" name="m_cmbViewFormat">0</Property> <Property role="44" name="m_chkSeqNbrIncluded">2</Property> <Property role="42" name="m_edtDumpFile"></Property> <Property role="44" name="m_chkAdvanced">0</Property> <Property role="44" name="m_chk802154gMode">0</Property> </packetrx> <commandpanel> <Property role="44" name="m_chkInsertLength">0</Property> <Property role="42" name="m_edtTxFifo"></Property> <Property role="42" name="m_edtRxFifo"></Property> <Property role="46" name="m_cmbInstrInput">-1</Property> </commandpanel> </dcpanelconfiguration>
<?xml version="1.0" encoding="ISO-8859-1"?> <!DOCTYPE configuration SYSTEM "C:/Program Files (x86)/Texas Instruments/SmartRF Tools/SmartRF Studio 7/config/xml/configdata.dtd"[]> <dcpanelconfiguration> <Devicename>CC1310_PG21</Devicename> <Description>Saved configuration data</Description> <Patch> <Define>RF_MODE_PROPRIETARY_SUB_1</Define> <Cpe>rf_patch_cpe_genook</Cpe> <Mce>rf_patch_mce_genook</Mce> <Rfe>rf_patch_rfe_genook</Rfe> </Patch> <commandsettings> <Command name="CMD_TX_TEST"> <Field name="commandNo">0x00000808</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="config">0x00000002</Field> <Field name="txWord">0x0000aaaa</Field> <Field name="endTrigger">0x00000001</Field> <Field name="syncWord">0xd391d391</Field> <Field name="endTime">0x00000000</Field> </Command> <Command name="CMD_SYNC_STOP_RAT"> <Field name="commandNo">0x00000809</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> <Field name="rat0">0x00000000</Field> </Command> <Command name="CMD_SYNC_START_RAT"> <Field name="commandNo">0x0000080a</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> <Field name="rat0">0x00000000</Field> </Command> <Command name="CMD_STOP"> <Field name="commandNo">0x00000402</Field> </Command> <Command name="CMD_SCH_IMM"> <Field name="commandNo">0x00000810</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> <Field name="cmdrVal">0x00000000</Field> <Field name="cmdstaVal">0x00000000</Field> </Command> <Command name="CMD_RX_TEST"> <Field name="commandNo">0x00000807</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="config">0x00000004</Field> <Field name="endTrigger">0x00000001</Field> <Field name="syncWord">0xd391d391</Field> <Field name="endTime">0x00000000</Field> </Command> <Command name="CMD_RADIO_SETUP"> <Field name="commandNo">0x00000802</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="mode">0x00000001</Field> <Field name="loDivider">0x00000000</Field> <Field name="config">0x00000000</Field> <Field name="txPower">0x00000000</Field> <Field name="pRegOverride">0x00000000</Field> </Command> <Command name="CMD_PROP_TX_ADV"> <Field name="commandNo">0x00003803</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="pktConf">0x00000000</Field> <Field name="numHdrBits">0x00000010</Field> <Field name="pktLen">0x00000014</Field> <Field name="startConf">0x00000000</Field> <Field name="preTrigger">0x00000000</Field> <Field name="preTime">0x00000000</Field> <Field name="syncWord">0xd391d391</Field> <Field name="pPkt">0x00000000</Field> </Command> <Command name="CMD_PROP_TX"> <Field name="commandNo">0x00003801</Field> <Field name="status">0x00003400</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="pktConf">0x00000018</Field> <Field name="pktLen">0x00000014</Field> <Field name="syncWord">0xd391d391</Field> <Field name="pPkt">0x00000000</Field> </Command> <Command name="CMD_PROP_RX_SNIFF"> <Field name="commandNo">0x00003808</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="pktConf">0x00000000</Field> <Field name="rxConf">0x00000000</Field> <Field name="syncWord">0x00000000</Field> <Field name="maxPktLen">0x00000000</Field> <Field name="address0">0x00000000</Field> <Field name="address1">0x00000000</Field> <Field name="endTrigger">0x00000000</Field> <Field name="endTime">0x00000000</Field> <Field name="pQueue">0x00000000</Field> <Field name="pOutput">0x00000000</Field> <Field name="csConf">0x00000000</Field> <Field name="rssiThr">0x00000000</Field> <Field name="numRssiIdle">0x00000000</Field> <Field name="numRssiBusy">0x00000000</Field> <Field name="corrPeriod">0x00000000</Field> <Field name="corrConfig">0x00000000</Field> <Field name="csEndTrigger">0x00000000</Field> <Field name="csEndTime">0x00000000</Field> </Command> <Command name="CMD_PROP_RX_ADV_SNIFF"> <Field name="commandNo">0x00003809</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="pktConf">0x00000000</Field> <Field name="rxConf">0x00000000</Field> <Field name="syncWord0">0x00000000</Field> <Field name="syncWord1">0x00000000</Field> <Field name="maxPktLen">0x00000000</Field> <Field name="hdrConf">0x00000000</Field> <Field name="addrConf">0x00000000</Field> <Field name="lenOffset">0x00000000</Field> <Field name="endTrigger">0x00000000</Field> <Field name="endTime">0x00000000</Field> <Field name="pAddr">0x00000000</Field> <Field name="pQueue">0x00000000</Field> <Field name="pOutput">0x00000000</Field> <Field name="csConf">0x00000000</Field> <Field name="rssiThr">0x00000000</Field> <Field name="numRssiIdle">0x00000000</Field> <Field name="numRssiBusy">0x00000000</Field> <Field name="corrPeriod">0x00000000</Field> <Field name="corrConfig">0x00000000</Field> <Field name="csEndTrigger">0x00000000</Field> <Field name="csEndTime">0x00000000</Field> </Command> <Command name="CMD_PROP_RX_ADV"> <Field name="commandNo">0x00003804</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="pktConf">0x00000000</Field> <Field name="rxConf">0x00000000</Field> <Field name="syncWord0">0xd391d391</Field> <Field name="syncWord1">0x00000000</Field> <Field name="maxPktLen">0x000000ff</Field> <Field name="hdrConf">0x00000000</Field> <Field name="addrConf">0x00000000</Field> <Field name="lenOffset">0x00000000</Field> <Field name="endTrigger">0x00000000</Field> <Field name="endTime">0x00000000</Field> <Field name="pAddr">0x00000000</Field> <Field name="pQueue">0x00000000</Field> <Field name="pOutput">0x00000000</Field> </Command> <Command name="CMD_PROP_RX"> <Field name="commandNo">0x00003802</Field> <Field name="status">0x00000002</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="pktConf">0x00000018</Field> <Field name="rxConf">0x00000088</Field> <Field name="syncWord">0xd391d391</Field> <Field name="maxPktLen">0x000000ff</Field> <Field name="address0">0x000000aa</Field> <Field name="address1">0x000000bb</Field> <Field name="endTrigger">0x00000001</Field> <Field name="endTime">0x00000000</Field> <Field name="pQueue">0x00000000</Field> <Field name="pOutput">0x00000000</Field> </Command> <Command name="CMD_PROP_RADIO_SETUP"> <Field name="commandNo">0x00003806</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="modulation">0x00000000</Field> <Field name="symbolRate">0x00000000</Field> <Field name="rxBw">0x00000000</Field> <Field name="preamConf">0x00000000</Field> <Field name="formatConf">0x00000000</Field> <Field name="config">0x00000000</Field> <Field name="txPower">0x00000000</Field> <Field name="pRegOverride">0x00000000</Field> </Command> <Command name="CMD_PROP_RADIO_DIV_SETUP"> <Field name="commandNo">0x00003807</Field> <Field name="status">0x00003400</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="modulation">0x00000002</Field> <Field name="symbolRate">0x000c4a0f</Field> <Field name="rxBw">0x00000020</Field> <Field name="preamConf">0x00000004</Field> <Field name="formatConf">0x000000a0</Field> <Field name="config">0x00000008</Field> <Field name="txPower">0x0000a73f</Field> <Field name="pRegOverride">0x00000000</Field> <Field name="centerFreq">0x00000364</Field> <Field name="intFreq">0x00008000</Field> <Field name="loDivider">0x00000005</Field> <OverrideField name="pRegOverride"> <OverrideBuffer name="override_use_patch_prop_genook_nrz.xml"> <Element32b>MCE_RFE_OVERRIDE(1,0,0,1,0,0)</Element32b> </OverrideBuffer> <OverrideBuffer name="override_synth_prop_863_930_div5.xml"> <Element32b>HW_REG_OVERRIDE(0x4038,0x0037)</Element32b> <Element32b>0x000684A3</Element32b> <Element32b>HW_REG_OVERRIDE(0x4020,0x7F00)</Element32b> <Element32b>HW_REG_OVERRIDE(0x4064,0x0040)</Element32b> <Element32b>0xB1070503</Element32b> <Element32b>0x05330523</Element32b> <Element32b>0x0A480583</Element32b> <Element32b>0x7AB80603</Element32b> <Element32b>ADI_REG_OVERRIDE(1,4,0x9F)</Element32b> <Element32b>ADI_HALFREG_OVERRIDE(1,7,0x4,0x4)</Element32b> <Element32b>0x02010403</Element32b> <Element32b>0x00108463</Element32b> <Element32b>0x04B00243</Element32b> </OverrideBuffer> <OverrideBuffer name="override_synth_disable_bias_div5.xml"> <Element32b>HW32_ARRAY_OVERRIDE(0x405C,1)</Element32b> <Element32b>0x18000200</Element32b> </OverrideBuffer> <OverrideBuffer name="override_phy_rx_aaf_bw_0xd.xml"> <Element32b>ADI_HALFREG_OVERRIDE(0,61,0xF,0xD)</Element32b> </OverrideBuffer> <OverrideBuffer name="override_phy_agc_reflevel_0x19.xml"> <Element32b>HW_REG_OVERRIDE(0x6088,0x0019)</Element32b> </OverrideBuffer> <OverrideBuffer name="override_phy_ook_rx.xml"> <Element32b>0x00038883</Element32b> <Element32b>HW_REG_OVERRIDE(0x6084,0x35F1)</Element32b> </OverrideBuffer> <OverrideBuffer name="override_phy_ook_rx_filter_iir_k_1div4.xml"> <Element32b>HW_REG_OVERRIDE(0x5204,0x0002)</Element32b> </OverrideBuffer> <OverrideBuffer name="override_phy_ook_tx_power_max.xml"> <Element32b>HW_REG_OVERRIDE(0x6098,0x7200)</Element32b> <Element32b>HW_REG_OVERRIDE(0x52B8,0x8078)</Element32b> </OverrideBuffer> <OverrideBuffer name="override_phy_rx_rssi_offset_5db.xml"> <Element32b>0x00FB88A3</Element32b> </OverrideBuffer> </OverrideField> </Command> <Command name="CMD_PROP_CS"> <Field name="commandNo">0x00003805</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="csFsConf">0x00000000</Field> <Field name="csConf">0x00000000</Field> <Field name="rssiThr">0x00000000</Field> <Field name="numRssiIdle">0x00000000</Field> <Field name="numRssiBusy">0x00000000</Field> <Field name="corrPeriod">0x00000000</Field> <Field name="corrConfig">0x00000000</Field> <Field name="csEndTrigger">0x00000000</Field> <Field name="csEndTime">0x00000000</Field> </Command> <Command name="CMD_PATTERN_CHECK"> <Field name="commandNo">0x00000813</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> <Field name="patternOpt">0x00000000</Field> <Field name="pNextOpIfOk">0x00000000</Field> <Field name="pValue">0x00000000</Field> <Field name="mask">0x00000000</Field> <Field name="compareVal">0x00000000</Field> </Command> <Command name="CMD_NOP"> <Field name="commandNo">0x00000801</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> </Command> <Command name="CMD_FS_POWERUP"> <Field name="commandNo">0x0000080c</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> <Field name="pRegOverride">0x00000000</Field> </Command> <Command name="CMD_FS_POWERDOWN"> <Field name="commandNo">0x0000080d</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> </Command> <Command name="CMD_FS_OFF"> <Field name="commandNo">0x00000804</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> </Command> <Command name="CMD_FS"> <Field name="commandNo">0x00000803</Field> <Field name="status">0x00000400</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000001</Field> <Field name="frequency">0x00000364</Field> <Field name="fractFreq">0x00000000</Field> <Field name="synthConf">0x00000000</Field> </Command> <Command name="CMD_COUNT_BRANCH"> <Field name="commandNo">0x00000812</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> <Field name="counter">0x00000000</Field> <Field name="pNextOpIfOk">0x00000000</Field> </Command> <Command name="CMD_COUNT"> <Field name="commandNo">0x0000080b</Field> <Field name="status">0x00000000</Field> <Field name="pNextOp">0x00000000</Field> <Field name="startTime">0x00000000</Field> <Field name="startTrigger">0x00000000</Field> <Field name="condition">0x00000000</Field> <Field name="counter">0x00000000</Field> </Command> <Command name="CMD_ABORT"> <Field name="commandNo">0x00000401</Field> </Command> </commandsettings> <dcpanel> <Property name="m_chkCmdView" role="44">2</Property> <Property name="m_chkRfParameters" role="44">2</Property> <Property name="m_typicalSettings" role="33">Settings for 779 - 930 MHz band;4.8 kbps, OOK, 40 kHz RX BW (max Tx power)</Property> <Property name="m_testFuncPanel" role="37">2</Property> </dcpanel> <targetconfig> <Property name="m_cmbBoardSelection" role="46">0</Property> <Property name="m_chkDcDc" role="44">2</Property> </targetconfig> <rfparameters> <Property name="txPower" role="65535">14</Property> </rfparameters> <conttx> <Property name="m_rbtModulated" role="45">1</Property> <Property name="m_rbtUnmodulated" role="45">0</Property> <Property name="m_cmbDataFormat" role="46">-1</Property> <Property name="m_chkFreqSweep" role="44">0</Property> <Property name="m_chkChanSweep" role="44">0</Property> </conttx> <contrx> <Property name="m_cmbDataFormat" role="46">0</Property> <Property name="m_chkAutoScroll" role="44">2</Property> </contrx> <packettx> <Property name="m_edtPacketCount" role="42">100</Property> <Property name="m_edtFixedPktLength" role="42">20</Property> <Property name="m_edtPacketData" role="42">7f f1 29 0e 25 38 e7 55 0d 90 f6 25 e1 85 fe 9a 1e 38 </Property> <Property name="m_edtAccessAddress" role="42"></Property> <Property name="m_chkAddSeqNbr" role="44">2</Property> <Property name="m_chkInfinite" role="44">0</Property> <Property name="m_rbtRandom" role="45">1</Property> <Property name="m_rbtText" role="45">0</Property> <Property name="m_rbtHex" role="45">0</Property> <Property name="m_chkAdvanced" role="44">0</Property> <Property name="m_cmbLengthConfig" role="46">0</Property> <Property name="m_edtFixedPktLength" role="42">20</Property> <Property name="m_grp802154g" role="20">0</Property> <Property name="m_edt802154gPktLength" role="42">20</Property> <Property name="m_rbt802154g2BCrc" role="45">1</Property> <Property name="m_rbt802154g4BCrc" role="45">0</Property> <Property name="m_chk802154gWhitening" role="44">2</Property> <Property name="m_chkFEC" role="44">0</Property> <Property name="m_cmbPreambleCount" role="46">5</Property> <Property name="m_chkAddress" role="44">0</Property> <Property name="m_cmbSyncMode" role="46">24</Property> </packettx> <packetview> <Property name="m_edtPktLength" role="42">20</Property> <Property name="m_edtAddress" role="42"></Property> <Property name="m_lblFrmPayload" role="41">7f f1 29 0e 25 38 e7 55 0d 90 f6 25 e1 85 fe 9a 1e 38 </Property> </packetview> <packetrx> <Property name="m_edtPacketCount" role="42">100</Property> <Property name="m_edtAccessAddress" role="42">0xD391D391</Property> <Property name="m_chkInfinite" role="44">0</Property> <Property name="m_cmbViewFormat" role="46">0</Property> <Property name="m_chkSeqNbrIncluded" role="44">2</Property> <Property name="m_edtDumpFile" role="42"></Property> <Property name="m_chkAdvanced" role="44">0</Property> <Property name="m_chk802154gMode" role="44">0</Property> </packetrx> </dcpanelconfiguration>
How do I solve the problem of distance.
