Hi Team,
Can you please check and advise following request;
1- TI example “6lowpan_mesh_ti_15_4_cc1312_tirtos_ccs” uses UDP not TCP please confirm?
2- Can I use the TCP instead of UDP? If it is possible, which components need to be modified?
3- Is there any reason for you using UDP instead of TCP in this example?
4- Where can I find the “path cost” from coordinator to the end node in this project?
Thanks in advance
Best Regards
Furkan Sefiloglu
