Other Parts Discussed in Thread: SYSBIOS, TMS320F28379D
Hi Team
Good day.
My customer follow up the last post
information:
So for the past 2 weeks I have tried to use the rfPacketRx example with your advice on replacing where to post and open the rfHandle.
I have also tried integrating the semaphore function however, I find my program still halting and not receiving anything after the first load of data.
When I had a look to see where it was halting, it was at line 276 (See code as attached), where the program goes into an uncaught error event state, as described in rf_mailbox.h.
Do you know of a way I can get around this?
* Copyright (c) 2019, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/***** Includes *****/
/* Standard C Libraries */
#include <stdlib.h>
/* TI Drivers */
#include <ti/drivers/rf/RF.h>
#include <ti/drivers/PIN.h>
//#include <semaphore.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <BIOS.h>
/* Driverlib Header files */
#include DeviceFamily_constructPath(driverlib/rf_prop_mailbox.h)
/* Board Header files */
#include "Board.h"
/* Application Header files */
#include "RFQueue.h"
#include "smartrf_settings/smartrf_settings.h"
/***** Defines *****/
/* Packet RX Configuration */
#define DATA_ENTRY_HEADER_SIZE 8 /* Constant header size of a Generic Data Entry */
#define MAX_LENGTH 30 /* Max length byte the radio will accept */
#define NUM_DATA_ENTRIES 2 /* NOTE: Only two data entries supported at the moment */
#define NUM_APPENDED_BYTES 2 /* The Data Entries data field will contain:
* 1 Header byte (RF_cmdPropRx.rxConf.bIncludeHdr = 0x1)
* Max 30 payload bytes
* 1 status byte (RF_cmdPropRx.rxConf.bAppendStatus = 0x1) */
//static Semaphore_Struct semHandle;
static Semaphore_Handle semHandle;
//sem_t semHandle;
uint32_t cmdStatus;
/***** Prototypes *****/
static void callback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e);
/***** Variable declarations *****/
static RF_Object rfObject;
static RF_Handle rfHandle;
/* Pin driver handle */
static PIN_Handle ledPinHandle;
static PIN_State ledPinState;
int potatotrack = 0;
/* Buffer which contains all Data Entries for receiving data.
* Pragmas are needed to make sure this buffer is 4 byte aligned (requirement from the RF Core) */
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_ALIGN (rxDataEntryBuffer, 4);
static uint8_t rxDataEntryBuffer[RF_QUEUE_DATA_ENTRY_BUFFER_SIZE(
NUM_DATA_ENTRIES, MAX_LENGTH, NUM_APPENDED_BYTES)];
#elif defined(__IAR_SYSTEMS_ICC__)
#pragma data_alignment = 4
static uint8_t
rxDataEntryBuffer[RF_QUEUE_DATA_ENTRY_BUFFER_SIZE(NUM_DATA_ENTRIES,
MAX_LENGTH,
#elif defined(__GNUC__)
static uint8_t
MAX_LENGTH,
__attribute__((aligned(4)));
#else
#error This compiler is not supported.
#endif
/* Receive dataQueue for RF Core to fill in data */
static dataQueue_t dataQueue;
static rfc_dataEntryGeneral_t* currentDataEntry;
static uint8_t packetLength;
static uint8_t* packetDataPointer;
static uint8_t packet[MAX_LENGTH + NUM_APPENDED_BYTES - 1]; /* The length byte is stored in a separate variable */
* Application LED pin configuration table:
* - All LEDs board LEDs are off.
PIN_Config pinTable[] = {
Board_PIN_LED2 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL
| PIN_DRVSTR_MAX,
PIN_TERMINATE };
/***** Function definitions *****/
void *mainThread(void *arg0)
// sem_init(&semHandle, 0, 0);
potatotrack = 1;
RF_Params rfParams;
RF_Params_init(&rfParams);
potatotrack = 2;
/* Open LED pins */
ledPinHandle = PIN_open(&ledPinState, pinTable);
if (ledPinHandle == NULL)
while (1)
potatotrack = 3;
if (RFQueue_defineQueue(&dataQueue, rxDataEntryBuffer,
sizeof(rxDataEntryBuffer),
NUM_DATA_ENTRIES,
MAX_LENGTH + NUM_APPENDED_BYTES))
/* Failed to allocate space for all data entries */
while (1)
potatotrack = 4;
/* Modify CMD_PROP_RX command for application needs */
/* Set the Data Entity queue for received data */
RF_cmdPropRx.pQueue = &dataQueue;
/* Discard ignored packets from Rx queue */
RF_cmdPropRx.rxConf.bAutoFlushIgnored = 1;
/* Discard packets with CRC error from Rx queue */
RF_cmdPropRx.rxConf.bAutoFlushCrcErr = 1;
/* Implement packet length filtering to avoid PROP_ERROR_RXBUF */
RF_cmdPropRx.maxPktLen = MAX_LENGTH;
RF_cmdPropRx.pktConf.bRepeatOk = 1;
RF_cmdPropRx.pktConf.bRepeatNok = 1;
potatotrack = 5;
/* Request access to the radio */
#if defined(DeviceFamily_CC26X0R2)
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioSetup, &rfParams);
#else
(RF_RadioSetup*) &RF_cmdPropRadioDivSetup, &rfParams);
#endif// DeviceFamily_CC26X0R2
potatotrack = 6;
/* Set the frequency */
RF_postCmd(rfHandle, (RF_Op*) &RF_cmdFs, RF_PriorityNormal, NULL, 0);
potatotrack = 61;
/* Enter RX mode and stay forever in RX */
RF_EventMask terminationReason = RF_postCmd(rfHandle,
(RF_Op*) &RF_cmdPropRx,
RF_PriorityNormal, &callback,
RF_EventRxEntryDone);
potatotrack = 7;
switch (terminationReason)
case RF_EventLastCmdDone:
// A stand-alone radio operation command or the last radio
// operation command in a chain finished.
break;
case RF_EventCmdCancelled:
// Command cancelled before it was started; it can be caused
// by RF_cancelCmd() or RF_flushCmd().
break;
case RF_EventCmdAborted:
// Abrupt command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
case RF_EventCmdStopped:
// Graceful command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
default:
// Uncaught error event
while (1)
potatotrack = 8;
cmdStatus = ((volatile RF_Op*) &RF_cmdPropRx)->status;
switch (cmdStatus)
case PROP_DONE_OK:
// Packet received with CRC OK
potatotrack = 81;
break;
case PROP_DONE_RXERR:
// Packet received with CRC error
potatotrack = 82;
break;
case PROP_DONE_RXTIMEOUT:
// Observed end trigger while in sync search
potatotrack = 83;
break;
case PROP_DONE_BREAK:
// Observed end trigger while receiving packet when the command is
// configured with endType set to 1
potatotrack = 84;
break;
case PROP_DONE_ENDED:
// Received packet after having observed the end trigger; if the
// command is configured with endType set to 0, the end trigger
// will not terminate an ongoing reception
potatotrack = 85;
break;
case PROP_DONE_STOPPED:
// received CMD_STOP after command started and, if sync found,
// packet is received
potatotrack = 86;
break;
case PROP_DONE_ABORT:
// Received CMD_ABORT after command started
potatotrack = 87;
break;
case PROP_ERROR_RXBUF:
// No RX buffer large enough for the received data available at
// the start of a packet
potatotrack = 88;
break;
case PROP_ERROR_RXFULL:
// Out of RX buffer space during reception in a partial read
potatotrack = 89;
break;
case PROP_ERROR_PAR:
// Observed illegal parameter
potatotrack = 810;
break;
case PROP_ERROR_NO_SETUP:
// Command sent without setting up the radio in a supported
// mode using CMD_PROP_RADIO_SETUP or CMD_RADIO_SETUP
potatotrack = 811;
break;
case PROP_ERROR_NO_FS:
// Command sent without the synthesizer being programmed
potatotrack = 812;
break;
case PROP_ERROR_RXOVF:
// RX overflow observed during operation
potatotrack = 813;
break;
default:
// Uncaught error event - these could come from the
// pool of states defined in rf_mailbox.h
potatotrack = 814;
while (1)
potatotrack = 9;
while (1)
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER);
potatotrack = 91;
if (e & RF_EventRxEntryDone)
potatotrack = 10;
/* Toggle pin to indicate RX */
PIN_setOutputValue(ledPinHandle, Board_PIN_LED2,
!PIN_getOutputValue(Board_PIN_LED2));
potatotrack = 11;
/* Get current unhandled data entry */
currentDataEntry = RFQueue_getDataEntry();
potatotrack = 12;
/* Handle the packet data, located at ¤tDataEntry->data:
* - Length is the first byte with the current configuration
* - Data starts from the second byte */
packetLength = *(uint8_t*) (¤tDataEntry->data);
packetDataPointer = (uint8_t*) (¤tDataEntry->data + 1);
potatotrack = 13;
/* Copy the payload + the status byte to the packet variable */
memcpy(packet, packetDataPointer, (packetLength + 1));
potatotrack = 14;
RFQueue_nextEntry();
potatotrack = 15;
Semaphore_post(semHandle);
Aosker
