hi
is there a code example for implementig a sotware serial port?
marco
Check here: https://dev.ti.com/tirex/explore/node?node=AAVKTSdWgfpJH7V3Rbdf4A__eCfARaV__LATEST
You are not stating which serial interface.
Uart serial works fine . i need another way to comunicate with another micro . i need only to send some bytes , eventualy also to read
the uart is already used . i would be perfect to have 1 wire slave code
marco
You can use the Sensor Controller for an additional UART.
We don't have drivers for 1 wire interface, you can look into writing your own driver if needed.
