Hi ,
I am using TI-CC1352P for development with ROM Bootloader preflashed by TI.
And I want to enable the secure boot,so Is that support and how we can achieve this ?
Hi ,
Hi Yogesh,
Your post does not contain enough information for us to help you solve this issue.
Please provide as much information as possible about your use-case and implementation, for example:
Are you using a custom board or a LaunchPad?
Which technology do you use?
Which version of the SDK are you using?
Can you specify what you mean by "secure boot"?
Elin
Hi Yogesh,
Then I would suggest you to use the BIM. Here you can read about the examples here: https://dev.ti.com/tirex/explore/node?node=AGfuec0PGs.jirzW4DBCIg__pTTHBmu__LATEST&r=pTTHBmu__4.10.00.78&r=pTTHBmu__4.20.00.35
Elin
