Other Parts Discussed in Thread: UNIFLASH, SYSCONFIG, CC3235SF
I'm just getting started with CC3235MOD Launchpad Kit. I'm trying to walk through the QuickStartGuide for SimpleLink CC32xxSDK.
My development environment is Linux using GNU ARM embedded toolchain.
I've installed the SDK, FreeRTOS10.1.1 and Uniflash; then I skipped to section 7 "Quick Start for Makefile Users".
I updated the <SDK_INSTALL_DIR>/imports.makefile, but there is no directory path to the SYSCONFIG_TOOL.
The imports.mak file has
SYSCONFIG_TOOL ?= /home/username/ti/ccs1030/ccs/utils/sysconfig_1.8.0/sysconfig_cli.sh
but there is no ccs1030/ directory below, and after searching the entire sdk tree, there is no sysconfig_cli.sh file to be found.
I tried skipping over that to section 7.2 "Build Kernel configuration"
So, I just removed that line from imports.mak and I was able to build tirtos-release and freertos-release.
The makefile doesn't support "nortos-release" but I was able to build it manually with "make -C nortos.
Section 7.3 & 7.4 almost entirely bombed (make failed) because files are not found.
Am I starting in the right place? Is there supposed to be a "sysconfig_cli.sh" file in the SDK?
Thanks in advance,
Ed
