Hi Team,
We have received this inquiry from our customer,
We are using WL1837MOD in our device and R8.8 driver.
We are using a custom Yocto build based on Gatesgarth. Linux kernel version 5.4.47.
We wanted to have ACS feature for AP, but we were not able to make it work with default Hostapd. Now we are building TI version of Hostapd from your Git that contains changes related to ACS. However, we still can't manage to use ACS.
Please see config we are using and logs from hostapd attached.
driver=nl80211 country_code=BE hw_mode=a channel=acs_survey ssid=ti_5 ieee80211n=1 auth_algs=1 wpa=2 wpa_passphrase=westtest wmm_enabled=1 rsn_pairwise=CCMP ht_capab=[HT40+][HT40-][SHORT-GI-20][SHORT-GI-40]
1608139542.039181: random: Trying to read entropy from /dev/random 1608139542.039479: Configuration file: host_1.conf 1608139542.043125: nl80211: Supported cipher 00-0f-ac:1 1608139542.043202: nl80211: Supported cipher 00-0f-ac:5 1608139542.043234: nl80211: Supported cipher 00-0f-ac:2 1608139542.043262: nl80211: Supported cipher 00-0f-ac:4 1608139542.043287: nl80211: Supported cipher 00-14-72:1 1608139542.043313: nl80211: Supports Probe Response offload in AP mode 1608139542.043533: nl80211: Using driver-based off-channel TX 1608139542.043598: nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 04 00 00 00 00 00 00 40 1608139542.043640: nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8): 04 00 00 00 00 00 00 40 1608139542.043687: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=0 1608139542.043718: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=1 1608139542.043743: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=2 1608139542.043767: nl80211: Supported vendor event: vendor_id=0x80028 subcmd=0 1608139542.043809: nl80211: Supported vendor event: vendor_id=0x80028 subcmd=1 1608139542.043886: nl80211: Use separate P2P group interface (driver advertised support) 1608139542.043917: nl80211: Enable multi-channel concurrent (driver advertised support) 1608139542.043942: nl80211: use P2P_DEVICE support 1608139542.043966: nl80211: interface wlan0 in phy phy0 1608139542.044145: nl80211: Set mode ifindex 10 iftype 3 (AP) 1608139542.067129: nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=0 1608139542.067269: nl80211: Subscribe to mgmt frames with AP handle 0xb3f2a0 1608139542.067312: nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xb3f2a0 match= 1608139542.067430: nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0xb3f2a0 match= 1608139542.067533: nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0xb3f2a0 match= 1608139542.067630: nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0xb3f2a0 match= 1608139542.067742: nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0xb3f2a0 match= 1608139542.067839: nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xb3f2a0 match= 1608139542.067950: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=04 1608139542.068047: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=0501 1608139542.068143: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=0503 1608139542.068236: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=0504 1608139542.068333: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=06 1608139542.068431: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=09 1608139542.068531: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=0a 1608139542.068627: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=11 1608139542.068735: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3f2a0 match=7f 1608139542.069757: rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0 1608139542.071023: nl80211: Add own interface ifindex 10 (ifidx_reason -1) 1608139542.071088: nl80211: if_indices[16]: 10(-1) 1608139542.071165: phy: phy0 1608139542.071204: BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits) 1608139542.071241: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE 1608139542.080352: Previous country code 00, new country code BE 1608139542.080419: Continue interface setup after channel list update 1608139542.080457: ctrl_iface not configured! 1608139542.080566: random: Got 20/20 bytes from /dev/random 1608139542.176543: nl80211: Event message available 1608139542.176643: nl80211: Drv Event 36 (NL80211_CMD_REG_CHANGE) received for wlan0 1608139542.176681: nl80211: Regulatory domain change 1608139542.176707: * initiator=1 1608139542.176731: * type=0 1608139542.176816: * alpha2=BE 1608139542.176860: wlan0: Event CHANNEL_LIST_CHANGED (27) received 1608139542.176947: Channel list updated - continue setup 1608139542.178016: nl80211: Regulatory information - country=BE (DFS-ETSI) 1608139542.178079: nl80211: 2400-2483 @ 40 MHz 20 mBm 1608139542.178119: nl80211: 5150-5250 @ 80 MHz 23 mBm (no outdoor) 1608139542.178155: nl80211: 5250-5350 @ 80 MHz 20 mBm (no outdoor) (DFS) 1608139542.178191: nl80211: 5470-5725 @ 160 MHz 26 mBm (DFS) 1608139542.178224: nl80211: 5725-5875 @ 80 MHz 13 mBm 1608139542.178256: nl80211: 57000-66000 @ 2160 MHz 40 mBm 1608139542.178341: nl80211: Added 802.11b mode based on 802.11g information 1608139542.178399: nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484[DISABLED][NO_IR] 1608139542.178464: nl80211: Mode IEEE 802.11a: 5040[DISABLED] 5060[DISABLED] 5080[DISABLED] 5170 5180 5190 5200 5210 5220 5230 5240 5260[RADAR] 5280[RADAR] 5300[RADAR] 5320[RADAR] 5500[RADAR] 5520[RADAR] 5540[RADAR] 5560[RADAR] 5580[RA] 1608139542.178533: nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484[DISABLED][NO_IR] 1608139542.178561: Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm 1608139542.178591: Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm 1608139542.178615: Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm 1608139542.178639: Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm 1608139542.178664: Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm 1608139542.178687: Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm 1608139542.178712: Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm 1608139542.178736: Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm 1608139542.178759: Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm 1608139542.178782: Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm 1608139542.178805: Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm 1608139542.178836: Allowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=20 dBm 1608139542.178863: Allowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=20 dBm 1608139542.178887: Allowed channel: mode=2 chan=34 freq=5170 MHz max_tx_power=23 dBm 1608139542.178911: Allowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=23 dBm 1608139542.178934: Allowed channel: mode=2 chan=38 freq=5190 MHz max_tx_power=23 dBm 1608139542.178958: Allowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=23 dBm 1608139542.178982: Allowed channel: mode=2 chan=42 freq=5210 MHz max_tx_power=23 dBm 1608139542.179005: Allowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=23 dBm 1608139542.179029: Allowed channel: mode=2 chan=46 freq=5230 MHz max_tx_power=23 dBm 1608139542.179055: Allowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=23 dBm 1608139542.179079: Allowed channel: mode=2 chan=149 freq=5745 MHz max_tx_power=13 dBm 1608139542.179103: Allowed channel: mode=2 chan=153 freq=5765 MHz max_tx_power=13 dBm 1608139542.179136: Allowed channel: mode=2 chan=157 freq=5785 MHz max_tx_power=13 dBm 1608139542.179163: Allowed channel: mode=2 chan=161 freq=5805 MHz max_tx_power=13 dBm 1608139542.179188: Allowed channel: mode=2 chan=165 freq=5825 MHz max_tx_power=13 dBm 1608139542.179212: Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm 1608139542.179236: Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm 1608139542.179260: Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm 1608139542.179284: Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm 1608139542.179308: Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm 1608139542.179331: Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm 1608139542.179355: Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm 1608139542.179379: Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm 1608139542.179404: Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm 1608139542.179473: Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm 1608139542.179503: Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm 1608139542.179529: Allowed channel: mode=0 chan=12 freq=2467 MHz max_tx_power=20 dBm 1608139542.179553: Allowed channel: mode=0 chan=13 freq=2472 MHz max_tx_power=20 dBm 1608139542.179582: Scan for neighboring BSSes to select channel 1608139542.179613: wlan0: nl80211: scan request 1608139542.179649: nl80211: Passive scan requested 1608139542.186779: Scan requested (ret=0) - scan timeout 10 seconds 1608139542.186849: ACS: Automatic channel selection started, this may take a bit 1608139542.186887: ACS: Scanning 1 / 5 1608139542.186921: wlan0: nl80211: scan request 1608139542.186959: nl80211: Passive scan requested 1608139542.186986: nl80211: Scan frequency 5170 MHz 1608139542.187014: nl80211: Scan frequency 5180 MHz 1608139542.187037: nl80211: Scan frequency 5190 MHz 1608139542.187061: nl80211: Scan frequency 5200 MHz 1608139542.187101: nl80211: Scan frequency 5210 MHz 1608139542.187130: nl80211: Scan frequency 5220 MHz 1608139542.187154: nl80211: Scan frequency 5230 MHz 1608139542.187177: nl80211: Scan frequency 5240 MHz 1608139542.187201: nl80211: Scan frequency 5745 MHz 1608139542.187225: nl80211: Scan frequency 5765 MHz 1608139542.187247: nl80211: Scan frequency 5785 MHz 1608139542.187270: nl80211: Scan frequency 5805 MHz 1608139542.187293: nl80211: Scan frequency 5825 MHz 1608139542.187403: nl80211: Scan trigger failed: ret=-16 (Device or resource busy) 1608139542.187440: nl80211: Set mode ifindex 10 iftype 2 (STATION) 1608139542.212087: nl80211: Teardown AP(wlan0) - device_ap_sme=0 use_monitor=0 1608139542.212167: nl80211: Unsubscribe mgmt frames handle 0x883b7a29 (AP teardown) 1608139542.212355: nl80211: Subscribe to mgmt frames with non-AP handle 0xb3e850 1608139542.212410: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3e850 match=06 1608139542.212541: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3e850 match=0a07 1608139542.212672: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3e850 match=0a11 1608139542.212777: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3e850 match=1101 1608139542.212879: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3e850 match=1102 1608139542.212982: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3e850 match=0505 1608139542.213079: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3e850 match=0500 1608139542.213191: wlan0: nl80211: scan request 1608139542.213236: nl80211: Passive scan requested 1608139542.213265: nl80211: Scan frequency 5170 MHz 1608139542.213294: nl80211: Scan frequency 5180 MHz 1608139542.213320: nl80211: Scan frequency 5190 MHz 1608139542.213346: nl80211: Scan frequency 5200 MHz 1608139542.213371: nl80211: Scan frequency 5210 MHz 1608139542.213396: nl80211: Scan frequency 5220 MHz 1608139542.213420: nl80211: Scan frequency 5230 MHz 1608139542.213457: nl80211: Scan frequency 5240 MHz 1608139542.213485: nl80211: Scan frequency 5745 MHz 1608139542.213510: nl80211: Scan frequency 5765 MHz 1608139542.213534: nl80211: Scan frequency 5785 MHz 1608139542.213558: nl80211: Scan frequency 5805 MHz 1608139542.213583: nl80211: Scan frequency 5825 MHz 1608139542.214380: Scan requested (ret=0) - scan timeout 10 seconds 1608139542.214444: Scan requested (ret=0) - scan timeout 10 seconds 1608139542.214479: wlan0: interface state COUNTRY_UPDATE->ACS 1608139542.214513: wlan0: ACS-STARTED 1608139542.214542: Interface initialization will be completed in a callback (ACS) 1608139542.214608: nl80211: Event message available 1608139542.214672: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 1608139542.214712: wlan0: nl80211: Scan trigger 1608139542.214748: wlan0: Event SCAN_STARTED (47) received 1608139542.214774: Unknown event 47 1608139542.214825: nl80211: Event message available 1608139542.214879: nl80211: Drv Event 35 (NL80211_CMD_SCAN_ABORTED) received for wlan0 1608139542.214970: nl80211: Set mode ifindex 10 iftype 3 (AP) 1608139542.246324: nl80211: Unsubscribe mgmt frames handle 0x883b60d9 (start AP) 1608139542.246452: nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=0 1608139542.246550: nl80211: Subscribe to mgmt frames with AP handle 0xb4a730 1608139542.246590: nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xb4a730 match= 1608139542.246713: nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0xb4a730 match= 1608139542.246819: nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0xb4a730 match= 1608139542.246919: nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0xb4a730 match= 1608139542.247015: nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0xb4a730 match= 1608139542.247114: nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xb4a730 match= 1608139542.247230: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=04 1608139542.247355: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=0501 1608139542.247457: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=0503 1608139542.247560: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=0504 1608139542.247663: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=06 1608139542.247764: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=09 1608139542.247865: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=0a 1608139542.247962: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=11 1608139542.248059: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a730 match=7f 1608139542.248226: wlan0: nl80211: Scan aborted 1608139542.248305: nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 5170 5180 5190 5200 5210 5220 5230 5240 5260 5280 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5 1608139542.248352: wlan0: Event SCAN_RESULTS (3) received 1608139542.248380: ACS: Using survey based algorithm (acs_num_scans=5) 1608139542.248415: nl80211: Fetch survey data 1608139542.248527: wlan0: Event SURVEY (46) received 1608139542.248564: No survey data received 1608139542.248600: ACS: Scanning 2 / 5 1608139542.248630: wlan0: nl80211: scan request 1608139542.248665: nl80211: Passive scan requested 1608139542.248694: nl80211: Scan frequency 5170 MHz 1608139542.248721: nl80211: Scan frequency 5180 MHz 1608139542.248745: nl80211: Scan frequency 5190 MHz 1608139542.248769: nl80211: Scan frequency 5200 MHz 1608139542.248796: nl80211: Scan frequency 5210 MHz 1608139542.248819: nl80211: Scan frequency 5220 MHz 1608139542.248844: nl80211: Scan frequency 5230 MHz 1608139542.248869: nl80211: Scan frequency 5240 MHz 1608139542.248894: nl80211: Scan frequency 5745 MHz 1608139542.248930: nl80211: Scan frequency 5765 MHz 1608139542.248957: nl80211: Scan frequency 5785 MHz 1608139542.248984: nl80211: Scan frequency 5805 MHz 1608139542.249008: nl80211: Scan frequency 5825 MHz 1608139542.249106: nl80211: Scan trigger failed: ret=-16 (Device or resource busy) 1608139542.249144: nl80211: Set mode ifindex 10 iftype 2 (STATION) 1608139542.276221: nl80211: Teardown AP(wlan0) - device_ap_sme=0 use_monitor=0 1608139542.276298: nl80211: Unsubscribe mgmt frames handle 0x883c2fb9 (AP teardown) 1608139542.276426: nl80211: Subscribe to mgmt frames with non-AP handle 0xb3d178 1608139542.276475: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3d178 match=06 1608139542.276603: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3d178 match=0a07 1608139542.276716: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3d178 match=0a11 1608139542.276820: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3d178 match=1101 1608139542.276989: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3d178 match=1102 1608139542.277094: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3d178 match=0505 1608139542.277196: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb3d178 match=0500 1608139542.277315: wlan0: nl80211: scan request 1608139542.277360: nl80211: Passive scan requested 1608139542.277391: nl80211: Scan frequency 5170 MHz 1608139542.277419: nl80211: Scan frequency 5180 MHz 1608139542.277443: nl80211: Scan frequency 5190 MHz 1608139542.277468: nl80211: Scan frequency 5200 MHz 1608139542.277493: nl80211: Scan frequency 5210 MHz 1608139542.277516: nl80211: Scan frequency 5220 MHz 1608139542.277540: nl80211: Scan frequency 5230 MHz 1608139542.277563: nl80211: Scan frequency 5240 MHz 1608139542.277585: nl80211: Scan frequency 5745 MHz 1608139542.277608: nl80211: Scan frequency 5765 MHz 1608139542.277631: nl80211: Scan frequency 5785 MHz 1608139542.277668: nl80211: Scan frequency 5805 MHz 1608139542.277696: nl80211: Scan frequency 5825 MHz 1608139542.278485: Scan requested (ret=0) - scan timeout 10 seconds 1608139542.278547: Scan requested (ret=0) - scan timeout 10 seconds 1608139542.278621: nl80211: Event message available 1608139542.278684: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 1608139542.278724: wlan0: nl80211: Scan trigger 1608139542.278760: wlan0: Event SCAN_STARTED (47) received 1608139542.278786: Unknown event 47 1608139542.278836: nl80211: Event message available 1608139542.278891: nl80211: Drv Event 35 (NL80211_CMD_SCAN_ABORTED) received for wlan0 1608139542.278923: nl80211: Set mode ifindex 10 iftype 3 (AP) 1608139542.299320: nl80211: Unsubscribe mgmt frames handle 0x883b59f1 (start AP) 1608139542.299449: nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=0 1608139542.299546: nl80211: Subscribe to mgmt frames with AP handle 0xb4a830 1608139542.299589: nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xb4a830 match= 1608139542.299734: nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0xb4a830 match= 1608139542.299842: nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0xb4a830 match= 1608139542.299941: nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0xb4a830 match= 1608139542.300040: nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0xb4a830 match= 1608139542.300137: nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xb4a830 match= 1608139542.300253: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=04 1608139542.300356: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0501 1608139542.300459: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0503 1608139542.300561: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0504 1608139542.300663: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=06 1608139542.300775: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=09 1608139542.300876: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0a 1608139542.300979: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=11 1608139542.301077: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=7f 1608139542.301241: wlan0: nl80211: Scan aborted 1608139542.301300: nl80211: Scan included frequencies: 5170 5180 5190 5200 5210 5220 5230 5240 5745 5765 5785 5805 5825 1608139542.301339: wlan0: Event SCAN_RESULTS (3) received 1608139542.301368: ACS: Using survey based algorithm (acs_num_scans=5) 1608139542.301403: nl80211: Fetch survey data 1608139542.301512: wlan0: Event SURVEY (46) received 1608139542.301550: No survey data received 1608139542.301584: ACS: Scanning 3 / 5 1608139542.301617: wlan0: nl80211: scan request 1608139542.301652: nl80211: Passive scan requested 1608139542.301738: nl80211: Scan frequency 5170 MHz 1608139542.301770: nl80211: Scan frequency 5180 MHz 1608139542.301796: nl80211: Scan frequency 5190 MHz 1608139542.301821: nl80211: Scan frequency 5200 MHz 1608139542.301846: nl80211: Scan frequency 5210 MHz 1608139542.301869: nl80211: Scan frequency 5220 MHz 1608139542.301893: nl80211: Scan frequency 5230 MHz 1608139542.301916: nl80211: Scan frequency 5240 MHz 1608139542.301940: nl80211: Scan frequency 5745 MHz 1608139542.301963: nl80211: Scan frequency 5765 MHz 1608139542.301987: nl80211: Scan frequency 5785 MHz 1608139542.302011: nl80211: Scan frequency 5805 MHz 1608139542.302034: nl80211: Scan frequency 5825 MHz 1608139542.306863: Scan requested (ret=0) - scan timeout 10 seconds 1608139542.306974: nl80211: Event message available 1608139542.307041: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 1608139542.307082: wlan0: nl80211: Scan trigger 1608139542.307117: wlan0: Event SCAN_STARTED (47) received 1608139542.307158: Unknown event 47 1608139542.307211: nl80211: Event message available 1608139542.307265: nl80211: Drv Event 35 (NL80211_CMD_SCAN_ABORTED) received for wlan0 1608139542.307301: wlan0: nl80211: Scan aborted 1608139542.307343: nl80211: Scan included frequencies: 5170 5180 5190 5200 5210 5220 5230 5240 5745 5765 5785 5805 5825 1608139542.307377: wlan0: Event SCAN_RESULTS (3) received 1608139542.307403: ACS: Using survey based algorithm (acs_num_scans=5) 1608139542.307439: nl80211: Fetch survey data 1608139542.307552: wlan0: Event SURVEY (46) received 1608139542.307589: No survey data received 1608139542.307623: ACS: Scanning 4 / 5 1608139542.307655: wlan0: nl80211: scan request 1608139542.307690: nl80211: Passive scan requested 1608139542.307717: nl80211: Scan frequency 5170 MHz 1608139542.307744: nl80211: Scan frequency 5180 MHz 1608139542.307769: nl80211: Scan frequency 5190 MHz 1608139542.307793: nl80211: Scan frequency 5200 MHz 1608139542.307817: nl80211: Scan frequency 5210 MHz 1608139542.307840: nl80211: Scan frequency 5220 MHz 1608139542.307876: nl80211: Scan frequency 5230 MHz 1608139542.307904: nl80211: Scan frequency 5240 MHz 1608139542.307929: nl80211: Scan frequency 5745 MHz 1608139542.307952: nl80211: Scan frequency 5765 MHz 1608139542.307976: nl80211: Scan frequency 5785 MHz 1608139542.308000: nl80211: Scan frequency 5805 MHz 1608139542.308026: nl80211: Scan frequency 5825 MHz 1608139542.308120: nl80211: Scan trigger failed: ret=-16 (Device or resource busy) 1608139542.308157: nl80211: Set mode ifindex 10 iftype 2 (STATION) 1608139542.336674: nl80211: Teardown AP(wlan0) - device_ap_sme=0 use_monitor=0 1608139542.336752: nl80211: Unsubscribe mgmt frames handle 0x883c20b9 (AP teardown) 1608139542.336884: nl80211: Subscribe to mgmt frames with non-AP handle 0xb4a830 1608139542.336934: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=06 1608139542.337063: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0a07 1608139542.337175: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0a11 1608139542.337297: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=1101 1608139542.337403: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=1102 1608139542.337502: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0505 1608139542.337608: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0500 1608139542.337721: wlan0: nl80211: scan request 1608139542.337767: nl80211: Passive scan requested 1608139542.337797: nl80211: Scan frequency 5170 MHz 1608139542.337825: nl80211: Scan frequency 5180 MHz 1608139542.337851: nl80211: Scan frequency 5190 MHz 1608139542.337875: nl80211: Scan frequency 5200 MHz 1608139542.337902: nl80211: Scan frequency 5210 MHz 1608139542.337925: nl80211: Scan frequency 5220 MHz 1608139542.337948: nl80211: Scan frequency 5230 MHz 1608139542.337971: nl80211: Scan frequency 5240 MHz 1608139542.338049: nl80211: Scan frequency 5745 MHz 1608139542.338080: nl80211: Scan frequency 5765 MHz 1608139542.338106: nl80211: Scan frequency 5785 MHz 1608139542.338129: nl80211: Scan frequency 5805 MHz 1608139542.338153: nl80211: Scan frequency 5825 MHz 1608139542.338249: nl80211: Scan trigger failed: ret=-16 (Device or resource busy) 1608139542.338287: nl80211: Set mode ifindex 10 iftype 3 (AP) 1608139542.357497: nl80211: Unsubscribe mgmt frames handle 0x883c20b9 (start AP) 1608139542.357621: nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=0 1608139542.357717: nl80211: Subscribe to mgmt frames with AP handle 0xb4a830 1608139542.357755: nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xb4a830 match= 1608139542.357879: nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0xb4a830 match= 1608139542.357986: nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0xb4a830 match= 1608139542.358085: nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0xb4a830 match= 1608139542.358203: nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0xb4a830 match= 1608139542.358299: nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xb4a830 match= 1608139542.358414: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=04 1608139542.358519: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0501 1608139542.358619: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0503 1608139542.358722: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0504 1608139542.358819: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=06 1608139542.358921: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=09 1608139542.359020: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=0a 1608139542.359118: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=11 1608139542.359231: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb4a830 match=7f 1608139542.359389: ACS: Failed to request initial scan 1608139542.359430: ACS: Failed to request scan 1608139542.359459: Interface initialization failed 1608139542.359483: wlan0: interface state ACS->DISABLED 1608139542.359514: wlan0: AP-DISABLED 1608139542.359540: ACS: Failed to start 1608139542.359569: wlan0: AP-DISABLED 1608139542.359659: wlan0: Deauthenticate all stations 1608139542.359700: nl80211: send_mlme - da= ff:ff:ff:ff:ff:ff noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0xc0 (WLAN_FC_STYPE_DEAUTH) nlmode=3 1608139542.359738: nl80211: send_mlme -> send_frame 1608139542.359762: nl80211: send_frame - Use bss->freq=0 1608139542.359784: nl80211: send_frame -> send_frame_cmd 1608139542.359805: nl80211: CMD_FRAME freq=0 wait=0 no_cck=0 no_ack=0 offchanok=0 1608139542.359833: CMD_FRAME - hexdump(len=26): c0 00 00 00 ff ff ff ff ff ff a4 06 e9 af d6 2b a4 06 e9 af d6 2b 00 00 03 00 1608139542.359978: nl80211: Frame command failed: ret=-22 (Invalid argument) (freq=0 wait=0) 1608139542.360022: hostapd_free_hapd_data: Interface wlan0 wasn't started 1608139542.360050: hostapd_deinit_driver: driver=0x59b5c0 drv_priv=0xb3dae0 -> hapd_deinit 1608139542.360078: nl80211: deinit ifname=wlan0 disabled_11b_rates=0 1608139542.386147: nl80211: Remove monitor interface: refcount=0 1608139542.386203: nl80211: Remove beacon (ifindex=10) 1608139542.416216: netlink: Operstate: ifindex=10 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP) 1608139542.416328: nl80211: Set mode ifindex 10 iftype 2 (STATION) 1608139542.443180: nl80211: Teardown AP(wlan0) - device_ap_sme=0 use_monitor=0 1608139542.443256: nl80211: Unsubscribe mgmt frames handle 0x883c20b9 (AP teardown) 1608139542.443359: hostapd_deinit_driver:bss[0]->drv_priv=0xb3dae0 1608139542.443399: hostapd_cleanup_iface_partial(0xb3b8d8) 1608139542.443439: Interface wlan0 disabled 1608139542.443465: wlan0: interface state DISABLED->DISABLED 1608139542.443562: hostapd_interface_deinit_free(0xb3b8d8) 1608139542.443596: hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1 1608139542.443622: hostapd_interface_deinit(0xb3b8d8) 1608139542.443647: wlan0: interface state DISABLED->DISABLED 1608139542.443672: hostapd_bss_deinit: deinit bss wlan0 1608139542.443705: wlan0: AP-DISABLED 1608139542.443733: hostapd_cleanup(hapd=0xb3cac0 (wlan0)) 1608139542.443761: wlan0: CTRL-EVENT-TERMINATING 1608139542.443789: hostapd_free_hapd_data: Interface wlan0 wasn't started 1608139542.443816: hostapd_interface_deinit_free: driver=0x59b5c0 drv_priv=(nil) -> hapd_deinit 1608139542.443845: hostapd_interface_free(0xb3b8d8) 1608139542.443870: hostapd_interface_free: free hapd 0xb3cac0 1608139542.443895: hostapd_cleanup_iface(0xb3b8d8) 1608139542.443918: hostapd_cleanup_iface_partial(0xb3b8d8) 1608139542.443951: hostapd_cleanup_iface: free iface=0xb3b8d8
Danilo
