Hi team,
Here's an issue from the customer may need your help:
Regarding the example on the doc above, the customer has following 2 questions:
1) How many bytes of data does this program actually want to transfer, 2000 bytes or?
2) What is the relationship between the three txBuff and the two rxBuff? TxBuff1\2\3 each point to a separate memory?
Or txBuff1/txbuff2 are both the beginning of a section of memory, and txbuff3 is the middle of this section of memory?
Could you help check this case? Thanks.
Cherry
