Is there anything explicit that can be done to prevent roaming/hopping between APs in the CC3100?
Thank you
Thank you
Does the CC3100 not already fill in the BSSID when connecting to an AP in a profile or does the BSSID need to explicitly be added when adding a profile?
When you set SSID only, device will connect to strongest found AP. When you set SSID + BSSID device will connect to exact AP.
You can modify saved profile by calling sl_ APIs. You can read parameters of profile by API sl_WlanProfileGet() and after that you can create new profile with BSSID using sl_WlanProfileAdd(). Old profile can be removed by API sl_WlanProfileDel(). But there is one big limitation. API sl_WlanProfileGet() will not return key (password for WiFi). This behaviour is due to security reason.
Jan
