Hi Team,
Such as the question, the configuration is no problem, because it was generated. I changed the name of the output file that was generated, it could not be generated. I tried many times in the middle, sometimes it can be generated, sometimes it cannot be generated, why?
There is no problem with compiling, and the clean is regenerated, but it does not work
It seems that only by changing the , syscfg will a new flash file be generated!
Susan Ren
