Part Number: WL1835MOD
Below are some questions for which answers are needed:
- For the WLAN set_tx_power command, the regulatory lab will adjust the output_power setting for the highest passing levels, but they need to know what value they should use for the “channel_limitation” parameter in that command. The parameter description says “Disable/Enable whether to use the channel power limits from the ini file”. I have found that this parameter setting does make a difference in the measured output power level, so I need to know whether it should be enabled or disabled while running regulatory tests.
regards
FFatima
