CC3220SF-LAUNCHXL: Unable to write or read data from the SPI based external EEPROM 25LC1024
Part Number: CC3220SF-LAUNCHXL
Other Parts Discussed in Thread: CC3220SF
Hi community,
I'm working on SPI based EEPROM write read operation.
Using CC3220SF-LAUNCHXL Rev.A to write and read operation to/from the 25LC1024 SPI based EEPROM with the help of simplelink cc32xx sdk 6.10.00.05
Searched for NORTOS example code for SPI based EEPROM operation, did not found if find any Example(s) code for SimpleLink CC3220SF to EEPROM read write operation please do share.
So i modified the TI RTOS bases SPI master example code as per requirement.
After that modification when tried to write data 0xAA to the EEPROM and read back from the same address (0x0010FF) i'm getting 0xFF as output i changed address to 0x001000 then also same output. Can any one help me out to solve this.
The modified code as follows:
 *  ======== spi_eeprom.c ========
#include <stdint.h>
#include <stdio.h>
#include <stddef.h>
#include <unistd.h>
#include <string.h>
/* Driver Header files */
#include <ti/drivers/GPIO.h>
#include <ti/drivers/SPI.h>
/* Driver configuration */
#include "ti_drivers_config.h"
#define SPI_MSG_LENGTH (8)
unsigned char controllerRxBuffer[SPI_MSG_LENGTH];
unsigned char controllerTxBuffer[SPI_MSG_LENGTH];
/* EEPROM instructions */
#define EEPROM_WRITE_ENABLE     (0x06)
#define EEPROM_WRITE_DISABLE    (0x04)
#define EEPROM_READ             (0x03)
#define EEPROM_WRITE            (0x02)
#define EEPROM_ID               (0xAB)
SPI_Handle      controllerSpi;
SPI_Handle Init_SPI(void){
    SPI_Params      spiParams;
    //printf("SPI initiating\n");
    SPI_Params_init(&spiParams);  // Initialize SPI parameters
    spiParams.dataSize = 8;       // 8-bit data size
    spiParams.frameFormat = SPI_POL0_PHA0;
    spiParams.bitRate     = 1000000;
    controllerSpi = SPI_open(CONFIG_SPI_0, &spiParams);
    if (controllerSpi == NULL)
            printf("Error initializing controller SPI\n");
        else
            printf("SPI initialized\n");
    return controllerSpi;
int writeToEEPROM(uint32_t address, uint8_t* data, uint32_t dataSize)
    SPI_Transaction spiTransaction;
    bool            transferOK;
    printf("To write\n");
    uint8_t tmp_txBuffer[SPI_MSG_LENGTH];
    tmp_txBuffer[0] = EEPROM_WRITE_ENABLE;          // EEPROM write enable latch
    tmp_txBuffer[1] = EEPROM_WRITE;                 // EEPROM write command
    tmp_txBuffer[2] = (address >> 16) & 0xFF;       // Address MSB
    tmp_txBuffer[3] = (address >> 8) & 0xFF;        // Address middle byte
    tmp_txBuffer[4] = address & 0xFF;               // Address LSB
    tmp_txBuffer[5] = data;                         // data to be written to 25LC1024
    strncpy((char *)controllerTxBuffer, tmp_txBuffer, sizeof(SPI_MSG_LENGTH));
    memset((void *)controllerRxBuffer, 0, SPI_MSG_LENGTH);
    spiTransaction.count = SPI_MSG_LENGTH;
    spiTransaction.txBuf = (void *)controllerTxBuffer;
    spiTransaction.rxBuf = (void *)controllerRxBuffer;
    /* Toggle user LED, indicating a SPI transfer is in progress */
    GPIO_toggle(CONFIG_GPIO_LED_1);
    /* Perform SPI transfer */
    transferOK = SPI_transfer(controllerSpi, &spiTransaction);
    if (transferOK)
        printf("Master transmitted data: %x\n", *(char *)controllerTxBuffer);
        //printf("bufr address of transmitted data: %#x\n", controllerTxBuffer);
    else
        printf("Unsuccessful SPI transfer");
        return -1;
    return 0;
int readFromEEPROM(uint32_t address, uint8_t* receiveBuffer, uint32_t dataSize)
    printf("To read\n");
    // Prepare the read command and address
    bool            transferOK;
    tmp_txBuffer[0] = EEPROM_READ;                     // Read command
    tmp_txBuffer[1] = (address >> 16) & 0xFF;       // Address MSB
    tmp_txBuffer[2] = (address >> 8) & 0xFF;        // Address middle byte
    tmp_txBuffer[3] = address & 0xFF;               // Address LSB
    tmp_txBuffer[4] = 0xBB;                         // dummy data
    strncpy((char *)controllerTxBuffer, tmp_txBuffer, sizeof(SPI_MSG_LENGTH-1));
    memset((void *)controllerRxBuffer, 0, SPI_MSG_LENGTH-1);
    spiTransaction.count = SPI_MSG_LENGTH - 1;          // Read command + address + dummy with dataSize
    if (transferOK)
        printf("Master received data: %x\n", *(char *)controllerRxBuffer);
        //printf("bufr address of received data : %#x\n", controllerRxBuffer);
    else
        return -1;
    return 0;
void *mainThread(void *arg0)
    uint8_t writeData[] = {0xAA};  // Data to write to the EEPROM
    uint32_t address = 0x000010FF;                  // Address to write to and read from
    uint32_t dataSize = sizeof(writeData);          // Size of data to write and read
    uint8_t receiveBuffer[dataSize];
    /* Call driver init functions. */
    GPIO_init();
    SPI_init();
    /* Configure the LED pins */
    GPIO_setConfig(CONFIG_GPIO_LED_0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
    GPIO_setConfig(CONFIG_GPIO_LED_1, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
    Init_SPI();
    /* Turn on user LED */
    GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON);
    // Write data to the EEPROM
    writeToEEPROM(address, writeData, dataSize);
    // Read data from the EEPROM
    readFromEEPROM(address, receiveBuffer, dataSize);
    SPI_close(controllerSpi);
    printf("\nDone");
Output which i got for the above code:
To write
Master transmitted data: 6
To read
Master received data: ff
Here is the pin configuration of SPI for SimpleLink board
Hardware is configured as follows:
Simple Link 25LC1024
SCLK SCK
MISO SO
MOSI SI
SS CS bar
3V3 VCC
GND VSS
Thanks and Regards,
Ajaykumar V
  • Hi Ajaykumar V,
    from what I see from the code you supplied, you are calling SPI transaction that contains the write command for the EEPROM.
    you then write a SPI transaction that contains the read command for the EEPROM.
    however the EEPROM has not yet procced this request and placed it onto the peripheral SPI tx, so you are not reading anything from the EEPROM on the SPI controller and you get 0xff.
    Id try 2 things:
    1) making sure the EEPROM processed your read request and placed it onto the EEPROM SPI tx.
    2) add another call to SPI transfer again on the controller side .
    Hope this helps,
    best regards, Avi Epstein.
  • Hi Avi,
    • strncpy((char *)controllerTxBuffer, tmp_txBuffer, sizeof(SPI_MSG_LENGTH)); This string copy instruction copied part of data to controllerTxBuffer from tmp_txBuffer (i.e., only Read or Write Instructions are copied rest of data is not copied), so using following instruction
      memcpy(controllerTxBuffer, tmp_txBuffer, sizeof(tmp_txBuffer) / sizeof(tmp_txBuffer[0]));
      may solve that issue.
    • When i did loopback (Launchpad MOSI to Launchpad MISO on same board), data in controllerTxBuffer  getting transferred to controllerRxBuffer.
    • If i tried to read Manufacturing ID of 25LC1024, i thought IC is not responding viewed in Memory Browser is responding, data is controllerRxBuffer, is not printed on the console. As shown below
      for below code:
       *  ======== eeprom_id_spi.c ========
      #include <stdint.h>
      #include <stdio.h>
      #include <stddef.h>
      #include <unistd.h>
      #include <string.h>
      #include <ti/display/Display.h>
       *  ======== spi.c ========
      #define EEPROM_SIZE     131072  // Size of 25LC1024 in bytes
      #define WRITE_CMD       (0x02)
      #define READ_CMD        (0x03)
      #define WRITE_EN_CMD    (0x06)
      void Read_MFGID_EEPROM(void)
          SPI_Transaction transaction;
          uint32_t i;
          bool transferOK;
          int32_t status;
          /* Open SPI as controller (default) */
          controllerSpi = SPI_open(CONFIG_SPI_CONTROLLER, &spiParams);
          else
          tmp_txBuffer[0] = EEPROM_ID;                    // instruction for EEPROM MFG ID
          tmp_txBuffer[1] = 0x00;                         // Dummy Address
          tmp_txBuffer[2] = 0x10;                         //
          tmp_txBuffer[3] = 0xFF;                         //
          tmp_txBuffer[4] = 0x00;                         // dummy data
          memset(controllerRxBuffer, 0, sizeof(controllerRxBuffer));
          printf("Master before transmit: %#016X\n", *(int *)controllerTxBuffer);
          printf("Master before received: %#016X\n", *(int *)controllerRxBuffer);
              /* Initialize controller SPI transaction structure */
              transaction.count = SPI_MSG_LENGTH;
              transaction.txBuf = (void *)controllerTxBuffer;
              transaction.rxBuf = (void *)controllerRxBuffer;
              transferOK = SPI_transfer(controllerSpi, &transaction);
              if (transferOK)
                  printf("Master transmitted addrs: %#X\n", controllerTxBuffer);
                  printf("Master transmitted: %016X\n", *(int *)controllerTxBuffer);
                  printf("Master receive addrs: %#X\n", controllerRxBuffer);
                  printf("Master received: %#016X\n", *(int *)controllerRxBuffer);
              if (transferOK)
                  printf("Master transmitted: %#08X\n", *(int *)controllerTxBuffer);
                  printf("Master received: %#08X\n", *(int *)controllerRxBuffer);
              else
                  printf("Unsuccessful SPI transfer\n");
                  printf("Master transmitted loop: %#016X\n", *(int *)controllerTxBuffer);
          printf("\nDone");
       *  ======== mainThread ========
          GPIO_init();
          SPI_init();
          printf("Starting the SPI Transfer\n");
          /* Read MFG ID of EEPROM */
          Read_MFGID_EEPROM();
    In the above code it self i have tried what you were suggested
    • Gave some delay to EEPROM process before read / after write operation also called SPI transfer at the time of Read operation for the original code is sent at the time of this thread creation.
    Ajaykumar V
  • Hi Ajaykumar V,
    1) Can you explain exactly what you are trying to achieve?
    2) what is your current issue?
    3) why are you running a loopback?
    From what I see in your code change you are calling spi transfer twice with the same data on controller tx. what are you trying to achieve by this?
    SPI transfer(called from the controller) simultaneously writes to the peripheral and reads from the peripheral (although spi is bidirectional I think in your application it should be used as request response).
    if you want a cycle of write/read to your eeprom you need to:
    1) write command (from controller): call spi transfer containing EEPROM write command with the data you intend to write(the eeprom will receive and save it in the address you specified)
    2) read command(from controller): call spi transfer containing EEPROM read command( the eeprom will process your request and place the data you requested on the peripheral tx, this is probably not immediate that's why you need step 3)
    3) read operation(from controller): now that the EEPROM placed the data on the peripheral tx, the controller is ready to receive so call spi transfer again to fetch the data.
    go over your EEPROM data sheet and see the exact details.
    best regards,
    Avi Epstein.
  • Hi Avi,
    I wanted to achieve External EEPROM write/read operation using SimpleLink CC3220SF Launch pad.
    Issue was with the reading writing and reading is not happening.
    Only to test transmitted data is get transmitted fully or not, over SPI. Loopback is not related to EEPROM write/ read operation.
    i miss understood above statement.
    below Instructions solved my issue.
    below code solve my issues:
        SPI_init();  // Initialize the SPI driver
            else
                printf("Controller SPI initialized\n");
    int EEPROM_WriteLatch(void){
        bool            transferOK;
        spiTransaction.count = 1;
        spiTransaction.rxBuf = NULL;
        if (transferOK)
            printf("EEPROM is ready to write data\n");
            return 0;
        else
            printf("Unsuccessful in Latching Write EEPROM\n");
            return -1;
        EEPROM_WriteLatch();
        bool            transferOK;
        int i;
        tmp_txBuffer[0] = EEPROM_WRITE;                 // EEPROM write command
        tmp_txBuffer[4] = 0xAA;                         // data to be written to 25LC1024
        if (transferOK)
            for(i = SPI_MSG_LENGTH -1 ; i > 3; i--){
            printf("Master transmitted data: %#X\n", *(char *)(controllerTxBuffer + i));
            printf("bufr transmitted data: %#X\n", *(int *)(controllerTxBuffer + 4));
            printf("bufr address of transmitted data: %#X\n", controllerTxBuffer);
        else
            printf("Unsuccessful controller SPI transfer");
            return -1;
        return 0;
        /* Prepare the read command and address */
        bool            transferOK;
        int i;
        memset((void *)controllerRxBuffer, 0,SPI_MSG_LENGTH);
        spiTransaction.count = sizeof(tmp_txBuffer) / sizeof(tmp_txBuffer[0]);    // Read command + address + dummy data to transmit while receiving
        if (transferOK)
            printf("Master received data: %#X\n", *(char *)(controllerRxBuffer + i));
            printf("bufr received data: %#X\n", *(int *)(controllerRxBuffer + 4));
            printf("bufr address of received data : %#X\n", controllerRxBuffer);
        else
            return -1;
        return 0;
    Thank you for your patience and continuous support Avi E. while bringing up the External EEPROM 25LC1024 write read operation.
    Thanks and regards,
    Ajaykumar V
