CC3235SF: In the Matter Over Wi-Fi example, as the Matter controller, can Google Home replace the CHIPTool App over Wi-Fi?
Part Number: CC3235SF
Hi, I am running the lock-app in the Matter example.
I tried to use Google Home as a controller to control the Matter device (CC3235SF) to get things done, but ran into a tricky problem. My Matter device has been successfully added to Google Home, but it always appears offline as described in the image below.
As shown in the following two pictures, I can view the information of the Matter device through the Google Home App, and I can also print logs from the device console.
Prior to this, I had successfully connected and controlled the Matter device (CC3235SF) on the CHIPTool Android APP. A few weeks ago, I had the Matter Over Thread example running successfully on Google Home. This is enough to prove that the firmware in the Matter device is fine, also shows that Google Home supports the matter protocol. Unfortunately, Google Home does not work as a controller in the Matter Over Thread example.
I have a question, in the case of Matter Over Wi-Fi, as a Matter controller, can Google Home replace the CHIPTool App Over Wi-Fi?
I appreciate your assistance!
Joey
