I was trying to get tcpechotls to work wit Windows .net framework 4.8.1 after getting it to run with the python script(see https://e2e.ti.com/support/wireless-connectivity/wi-fi-group/wifi/f/wi-fi-forum/1276970/launchcc3235mod-getting-tcpechotls-to-work-with-python-script-from-windows/), and keep getting "RemoteCertificateNameMismatch" in " Console.WriteLine("Certificate error: {0}", sslPolicyErrors);". I had modified some things in the tcpechotls to run in station mode with a hostname and changed theport, but those moifications worked with python script "python tcpSendReceiveTLS.py 192.168.1.99 58800 1 certs/caCert.pem -s100" in "C:\ti\simplelink_cc32xx_sdk_7_10_00_13\tools\cc32xx_tools". Primitive but altered connect code from Microsoft example at SslStream Class (System.Net.Security) | Microsoft Learn
using System; using System.Collections; using System.Net.Security; using System.Net.Sockets; using System.Security.Authentication; using System.Security.Cryptography.X509Certificates; using System.Text; using System.Threading.Tasks; namespace tlsMSG { public class SslTcpClient { private static Hashtable certificateErrors = new Hashtable(); // The following method is invoked by the RemoteCertificateValidationDelegate. public static bool ValidateServerCertificate( object sender, X509Certificate certificate, X509Chain chain, SslPolicyErrors sslPolicyErrors) { if (sslPolicyErrors == SslPolicyErrors.None) return true; Console.WriteLine("Certificate error: {0}", sslPolicyErrors); // Do not allow this client to communicate with unauthenticated servers. return false; } public static void RunClient(string machineName, string serverName) { // Create a TCP/IP client socket. // machineName is the host running the server application. TcpClient client = new TcpClient(machineName, 58800); Console.WriteLine("Client connected."); // Create an SSL stream that will close the client's stream. SslStream sslStream = new SslStream( client.GetStream(), false, new RemoteCertificateValidationCallback(ValidateServerCertificate), null ); // The server name must match the name on the server certificate. try { sslStream.AuthenticateAsClient(serverName); } catch (AuthenticationException e) { Console.WriteLine("Exception: {0}", e.Message); if (e.InnerException != null) { Console.WriteLine("Inner exception: {0}", e.InnerException.Message); } Console.WriteLine("Authentication failed - closing the connection."); client.Close(); return; } // Encode a test message into a byte array. // Signal the end of the message using the "<EOF>". byte[] messsage = Encoding.UTF8.GetBytes("Hello from the client.<EOF>"); // Send hello message to the server. sslStream.Write(messsage); sslStream.Flush(); // Read message from the server. string serverMessage = ReadMessage(sslStream); Console.WriteLine("Server says: {0}", serverMessage); // Close the client connection. client.Close(); Console.WriteLine("Client closed."); } static string ReadMessage(SslStream sslStream) { // Read the message sent by the server. // The end of the message is signaled using the // "<EOF>" marker. byte[] buffer = new byte[2048]; StringBuilder messageData = new StringBuilder(); int bytes = -1; do { bytes = sslStream.Read(buffer, 0, buffer.Length); // Use Decoder class to convert from bytes to UTF8 // in case a character spans two buffers. Decoder decoder = Encoding.UTF8.GetDecoder(); char[] chars = new char[decoder.GetCharCount(buffer, 0, bytes)]; decoder.GetChars(buffer, 0, bytes, chars, 0); messageData.Append(chars); // Check for EOF. if (messageData.ToString().IndexOf("<EOF>") != -1) { break; } } while (bytes != 0); return messageData.ToString(); } private static void DisplayUsage() { Console.WriteLine("To start the client specify:"); Console.WriteLine("clientSync machineName [serverName]"); Environment.Exit(1); } public static int Main(string[] args) { string serverCertificateName = null; string machineName = "trog3235"; // null; //if (args == null || args.Length < 1) //{ // DisplayUsage(); //} // User can specify the machine name and server name. // Server name must match the name on the server's certificate. //machineName = args[0]; if (args.Length < 2) { //serverCertificateName = machineName; serverCertificateName = "D:\\c\\vs2022\\CC3235\\tlsMSG\\certs\\caCert.pem";// machineName; } else { serverCertificateName = args[1]; } SslTcpClient.RunClient(machineName, serverCertificateName); return 0; } } }
