Missing bluetooth sink audio in pulseaudio 6 with wl1831 + bluez 5
Other Parts Discussed in Thread: WL1831
Hi all.
I am using WL1831 bluetooth module on a custom board, whose main processor has to send audio to heasets through bluetooth. The board I am working on has just UART connection, since the main processor lacks PCM controller. So, I want audio to go through HCI.
My setup is the following:
- bluez 5.31
- pulseaudio 6.0 with bluez5 module support
- ti wl18xx driver and firmware 8.5R, TIInit_11.8.32.bts file
I am able to pair and connect to headsets, so I think driver + bluetooth stack is fine. After connection, pulseaudio creates bluetooth source (thorugh module-bluez5-device), but no sink device, the one I need for my streaming application.
* Question: why isn't pulseaudio creating sink device and how can I create it manually (i.e. thorugh pactl or pacmd)?
Please consider module-udev-detect is not loaded (only module-detect) because my linux distributions lacks udev support. So no hoytplug support is present.
Please find below my current PA configuration:
Module #0
        Argument:
        Usage counter: n/a
        Properties:
                module.author = "Lennart Poettering"
                module.description = "Automatically restore the volume/mute state of devices"
                module.version = "6.0"
Module #1
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Automatically restore profile of cards"
Module #3
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Augment the property sets of streams with additional static information"
Module #4
        Argument:
        Usage counter: n/a
        Properties:
Module #5
        Argument:
        Usage counter: 1
        Properties:
                module.description = "Clocked NULL sink"
Module #7
        Argument:
        Usage counter: n/a
        Properties:
                module.author = "Fr�éd�éric Dalleau"
                module.description = "When a bluetooth sink or source is added, load module-loopback"
Module #8
        Argument:
        Usage counter: n/a
        Properties:
                module.author = "Jo�ão Paulo Rechi Vita"
                module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #9
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #10
        Argument: auth-cookie=/var/run/pulse/cookie
        Usage counter: n/a
        Properties:
                module.description = "Native protocol (UNIX sockets)"
Module #11
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Automatically restore the default sink and source"
Module #12
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
Module #13
        Argument:
        Usage counter: n/a
        Properties:
                module.author = "Colin Guthrie"
                module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #14
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Automatically set device of streams based on intended roles of devices"
Module #15
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "When a sink/source is idle for too long, suspend it"
Module #16
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #17
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Mute & cork streams with certain roles while others exist"
Module #18
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Detect when various filters are desirable"
Module #19
        Argument:
        Usage counter: n/a
        Properties:
                module.description = "Load filter sinks automatically when needed"
Module #20
        Argument: path=/org/bluez/hci0/dev_D8_90_E8_5A_7B_AE
        Usage counter: 1
        Properties:
                module.description = "BlueZ 5 Bluetooth audio sink and source"
Module #21
        Argument: source="bluez_source.D8_90_E8_5A_7B_AE" source_dont_move="true" sink_input_properties="media.role=music"
        Usage counter: n/a
        Properties:
                module.author = "Pierre-Louis Bossart"
                module.description = "Loopback from source to sink"
Sink #0
        State: SUSPENDED
        Description: Null Output
        Driver: module-null-sink.c
        Sample Specification: s16le 2ch 44100Hz
        Channel Map: front-left,front-right
        Owner Module: 5
        Mute: no
        Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
                balance 0.00
        Base Volume: 65536 / 100% / 0.00 dB
        Monitor Source: null.monitor
        Latency: 0 usec, configured 0 usec
        Flags: DECIBEL_VOLUME LATENCY
        Properties:
                device.description = "Null Output"
                device.class = "abstract"
                device.icon_name = "audio-card"
        Formats:
                pcm
Source #0
        State: SUSPENDED
        Description: Monitor of Null Output
        Owner Module: 5
        Mute: no
                balance 0.00
        Monitor of Sink: null
        Properties:
                device.description = "Monitor of Null Output"
                device.class = "monitor"
                device.icon_name = "audio-input-microphone"
        Formats:
                pcm
Source #1
        State: SUSPENDED
        Description: Federico Wegher (Galax
        Driver: module-bluez5-device.c
        Owner Module: 20
        Mute: no
                balance 0.00
        Monitor of Sink: n/a
        Flags: HARDWARE DECIBEL_VOLUME LATENCY
        Properties:
                bluetooth.protocol = "a2dp_source"
                device.description = "Federico Wegher (Galax"
                device.string = "D8:90:E8:5A:7B:AE"
                device.api = "bluez"
                device.class = "sound"
                device.bus = "bluetooth"
                device.form_factor = "phone"
                bluez.path = "/org/bluez/hci0/dev_D8_90_E8_5A_7B_AE"
                bluez.class = "0x5a020c"
                bluez.alias = "Federico Wegher (Galax"
                device.icon_name = "audio-card-bluetooth"
        Ports:
                phone-input: Phone (priority: 0)
        Active Port: phone-input
        Formats:
                pcm
Sink Input #0
        Driver: module-loopback.c
        Owner Module: 21
        Client: n/a
        Sink: 0
        Format: pcm, format.sample_format = "\"s16le\""  format.rate = "44100"  format.channels = "2"  format.channel_map = "\"front-left,front-right\""
        Corked: yes
        Mute: no
                balance 0.00
        Buffer Latency: 0 usec
        Sink Latency: 0 usec
        Resample method: trivial
        Properties:
                media.role = "music"
                module-stream-restore.id = "sink-input-by-media-role:music"
                media.name = "Loopback from Federico Wegher (Galax"
                media.icon_name = "audio-card-bluetooth"
Source Output #0
        Owner Module: 21
        Client: n/a
        Source: 1
        Corked: yes
        Mute: no
                balance 0.00
        Source Latency: 0 usec
        Resample method: n/a
        Properties:
                media.role = "abstract"
                module-stream-restore.id = "source-output-by-media-role:abstract"
                media.name = "Loopback to Null Output"
                media.icon_name = "audio-card"
Client #0
        Driver: protocol-native.c
        Owner Module: 10
        Properties:
                application.name = "pactl"
                native-protocol.peer = "UNIX socket client"
                native-protocol.version = "30"
                application.process.id = "1439"
                application.process.user = "root"
                application.process.host = "freescale"
                application.process.binary = "pactl"
                application.language = "C"
                application.process.machine_id = "9b4bfdf4c569212bccf1963400000003"
Card #0
        Owner Module: 20
        Properties:
        Profiles:
                a2dp_source: High Fidelity Capture (A2DP Source) (sinks: 0, sources: 1, priority: 10, available: yes)
                headset_audio_gateway: Headset Audio Gateway (HSP/HFP) (sinks: 1, sources: 1, priority: 20, available: no)
                off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
        Active Profile: a2dp_source
        Ports:
                phone-output: Phone (priority: 0, latency offset: 0 usec, not available)
                        Part of profile(s): headset_audio_gateway
                phone-input: Phone (priority: 0, latency offset: 0 usec)
                        Part of profile(s): a2dp_source, headset_audio_gateway
Thanks for kind reply.
