I'm facing the same trouble... beacon lost. very often (I’ve been testing) with different access points... seems to happen on all the access points I’ve been testing.
Distance to access point: 4 meters
Any recommendations on how to proceed / solve ?
Noel
# cat /var/log/messages.0 | grep wlcore
Mar 22 15:05:11 DU9 kern.info kernel: wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
Mar 22 15:05:11 DU9 kern.info kernel: wlcore: loaded
Mar 22 15:05:11 DU9 kern.info kernel: wlcore: driver version: R8.5
Mar 22 15:05:11 DU9 kern.info kernel: wlcore: compilation time: Mon Jan 12 14:49:48 2015
Mar 22 15:05:15 DU9 kern.info kernel: wlcore: PHY firmware version: Rev 8.2.0.0.233
Mar 22 15:05:16 DU9 kern.info kernel: wlcore: firmware booted (Rev 8.9.0.1.55)
Mar 22 15:05:20 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:08:22 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:08:26 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:08:39 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:08:43 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:08:48 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:08:52 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:09:20 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:09:25 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:09:29 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:09:35 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:09:38 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:09:40 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:09:44 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:09:49 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:09:52 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:09:54 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:09:58 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:11:42 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:11:47 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:11:59 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:12:08 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:12:13 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:12:17 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:13:21 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:13:25 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:13:29 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:14:36 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:14:40 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:15:10 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:15:52 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:15:56 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
Mar 22 15:16:00 DU9 kern.info kernel: wlcore: Association completed.
Mar 22 15:16:00 DU9 kern.info kernel: wlcore: Beacon loss detected. roles:0x1
Mar 22 15:16:05 DU9 kern.info kernel: wlcore: Connection loss work (role_id: 0).
