Hi all,
we are using am335x processor and linux kernel 4.4.12 + TISDK v3.00.00.04.compiled wifi related modules .wl18xx.ko and wlcore.ko,cfg80211.ko,macfg.ko .and all.
inserted all modules on my custom board.All modules are inserted .I followed below steps .But my problem is not showing ip addres after running the script.
And we checked wifi enable pin and wifi irq .
cat /sys/class/kernel/debug/gpio=====>wifi gpio enable high.
cat /proc/interrupts==============>wifi interrupt gpio edge 22 wl18xx shown
we checked with lsmod .
root@am335x-evm:/home# lsmod
Module Size Used by
arc4 1822 2
wl18xx 84532 0
wlcore 180963 1 wl18xx
mac80211 350293 2 wl18xx,wlcore
cfg80211 218849 3 mac80211,wl18xx,wlcore
musb_dsps 8235 0
musb_hdrc 71102 1 musb_dsps
udc_core 12063 1 musb_hdrc
pru_rproc 9767 0
pm33xx 5577 0
snd_soc_simple_card 7712 0
ti_emif_sram 6242 1 pm33xx
wkup_m3_ipc 7587 1 pm33xx
wkup_m3_rproc 3669 1
pruss 11485 1 pru_rproc
remoteproc 26773 4 pruss,wkup_m3_rproc,pru_rproc,wkup_m3_ipc
omap_aes_driver 18393 0
omap_sham 20609 0
virtio 7614 1 remoteproc
virtio_ring 12035 1 remoteproc
wlcore_sdio 6643 0
omap_rng 4482 0
rng_core 7538 1 omap_rng
snd_soc_tlv320aic3x 48260 1
musb_am335x 1426 0
ti_am335x_tsc 5901 0
omap_wdt 4634 0
ti_am335x_tscadc 6098 1 ti_am335x_tsc
rtc_omap 8191 1
ago 2015.09 am335x-evm /dev/ttyO0
am335x-evm login: root
root@am335x-evm:~# cd /home/
$vi wpa_conf.sh
#!/bin/bash
ifconfig wlan0 hw ether 08:00:28:00:01:a4
ifconfig wlan0 up
sleep 2
wlist scan
wpa_supplicant -d -Dnl80211 -c/etc/wpa_supplicant1.conf -iwlan0 -B
udhcpc -i wlan0 -b -t 10
root@am335x-evm:/home# sh wpa_conf.sh
[ 50.248796] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 50.361559] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 50.378686] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
wpa_conf.sh: line 5: wlist: command not found
wpa_supplicant v2.5-devel
random: Trying to read entropy from /dev/random
Successfully initialized wpa_supplicant
Initializing interface 'wlan0' conf '/etc/wpa_supplicant1.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant1.conf' -> '/etc/wpa_supplicant1.conf'
Reading configuration file '/etc/wpa_supplicant1.conf'
ctrl_interface='/var/run/wpa_supplicant'
update_config=1
Priority group 2
id=0 ssid='fossilshale'
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-14-72:1
nl80211: Supports Probe Response offload in AP mode
nl80211: Using driver-based off-channel TX
nl80211: Supported vendor command: vendor_id=0x80028 subcmd=0
nl80211: Supported vendor command: vendor_id=0x80028 subcmd=1
nl80211: Supported vendor command: vendor_id=0x80028 subcmd=2
nl80211: Supported vendor event: vendor_id=0x80028 subcmd=0
nl80211: Supported vendor event: vendor_id=0x80028 subcmd=1
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: use P2P_DEVICE support
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 5 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0x182918
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=0104
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=040a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=040b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=040c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=040d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=090a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=090b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=090c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=090d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=0409506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=7f506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=0801
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=0a07
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=0a11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=0a1a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=1101
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=1102
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x182918 match=0505
netlink: Operstate: ifindex=5 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
nl80211: driver param='(null)'
Add interface wlan0 to a new radio phy0
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 40 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 160 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
wlan0: Own MAC address: 08:00:28:00:01:a4
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0
wlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
TDLS: TDLS operation not supported by driver
TDLS: Driver uses internal link setup
TDLS: Driver does not support TDLS channel switching
wlan0: WPS: UUID based on MAC address: a5295edd-6dd9-520b-b176-49b400e3bb3c
ENGINE: Loading dynamic engine
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Skip set_supp_port(unauthorized) while not associated
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
wlan0: Added interface wlan0
wlan0: State: DISCONNECTED -> DISCONNECTED
nl80211: Set wlan0 operstate 0->0 (DORMANT)
netlink: Operstate: ifindex=5 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
nl80211: Create interface iftype 10 (P2P_DEVICE)
nl80211: New P2P Device interface p2p-dev-wlan0 (0x2) created
Initializing interface 'p2p-dev-wlan0' conf '/etc/wpa_supplicant1.conf' driver 'nl80211' ctrl_interface '/var/run/wpa_supplicant' bridge 'N/A'
update_config=1
Priority group 2
Could not read interface p2p-dev-wlan0 flags: No such device
nl80211: interface p2p-dev-wlan0 in phy phy0
nl80211: Set mode ifindex 0 iftype 10 (P2P_DEVICE)
nl80211: Failed to set interface 0 to mode 10: -22 (Invalid argument)
nl80211: Subscribe to mgmt frames with non-AP handle 0x193940
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=0104
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=040a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=040b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=040c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=040d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=090a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=090b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=090c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=090d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=0409506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=7f506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=0801
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=0a07
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=0a11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=0a1a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=1101
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=1102
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x193940 match=0505
nl80211: Start P2P Device p2p-dev-wlan0 (0x2): Success
Add interface p2p-dev-wlan0 to existing radio phy0
p2p-dev-wlan0: Own MAC address: f4:b8:5e:26:72:a9
p2p-dev-wlan0: RSN: flushing PMKID list in the driver
p2p-dev-wlan0: State: DISCONNECTED -> INACTIVE
p2p-dev-wlan0: WPS: UUID from the first interface: a5295edd-6dd9-520b-b176-49b400e3bb3c
Using existing control interface directory.
P2P: Add operating class 81
P2P: Channels - hexdump(len=11): 01 02 03 04 05 06 07 08 09 0a 0b
P2P: Own listen channel: 81:1
P2P: Random operating channel: 81:1
P2P: initialized
P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11
P2P: cli_channels:
p2p-dev-wlan0: Added interface p2p-dev-wlan0
p2p-dev-wlan0: State: INACTIVE -> DISCONNECTED
nl80211: Set p2p-dev-wlan0 operstate 0->0 (DORMANT)
netlink: Operstate: ifindex=0 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
Daemonize..
udhcpc (v1.23.1) started
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 | VT102 | Offline | ttyUSB0
If i give manually ifconfig wlan0 ipaddrs up
its showing some ipaddres .But not taking from udhcpc server.
How to know wifi driver is working or not.
can you any body help me asap.
Thanks & Regards
veeranjaneyulu
