While going through and using the reference design, I cannot get the sub 1 Ghz network up on the gateway. When I open the webpage on the gateway it will not connect to the IBM cloud. (shows red light) Any ideas on how I can debug this?
Hi Nicholas,
1. Have you followed the steps in the Reference Design User's Guide without errors, set up an IBM account, and edited the json code?
2. Are you using the SimpleLink Starter Pro app (section 3.2.1.1.9.1 o or Local Provisioning webpage (section 3.2.1.1.9.2)?
3. Are you seeing any error messages? What behavior are you seeing when you try to connect?
Sarah
Thanks Sarah! This now connects to the cloud.
It still is giving the Network Mode: Not Started though and none of the sensors connect to it. I've worked through again to make sure I've followed this properly. Is there a way to see where the Sub 1G is either starting up or failing to start up?
