Hi I am working on Nitrogen6x EVM board (NXP), with Android 5.1.1. and kernel version 3.14.28
I have connected extern wl18xx module and module is up and running and able to connected with WiFi and also board is able to create with P2P Go and P2P client is connected.
After P2P connection when i am starting the WFDsink application for miracast, then i am not able to get the connected device display,
and on log it showing the below MSG:
I/SinkDisplay( 1356): rtsp connected failed
I/wpa_supplicant( 1295): wpa_driver_nl80211_driver_cmd: Unsupported command MIRACAST 0
I have attached the complete log also , can please suggest why this fail is happed ,
I have follow this integration guide for wifi bringup.
I have attached complete
--------- beginning of system I/ValidateNoPeople( 488): skipping global notification I/ValidateNoPeople( 488): skipping global notification --------- beginning of main D/MtpService( 564): updating state; isCurrentUser=true, mMtpLocked=false D/MtpService( 564): addStorageLocked 65537 /storage/emulated/0 D/MtpService( 564): updating state; isCurrentUser=true, mMtpLocked=false D/MtpService( 564): starting MTP server in MTP mode D/MtpService( 564): addStorageLocked 65537 /storage/emulated/0 W/AudioTrack( 488): AUDIO_OUTPUT_FLAG_FAST denied by client I/audio_hw_primary( 200): start_output_stream... 1971955904, device 2 W/audio_hw_primary( 200): card 0, port 0 device 0x2 W/audio_hw_primary( 200): rate 44100, channel 2 period_size 0xc0 W/AudioTrack( 488): AUDIO_OUTPUT_FLAG_FAST denied by client I/ActivityManager( 488): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.example.p2pgo/.P2pGo (has extras)} from uid 10006 on display 0 V/WindowManager( 488): addAppToken: AppWindowToken{3b87eafd token=Token{4a29b54 ActivityRecord{2ce90aa7 u0 com.example.p2pgo/.P2pGo t49}}} to stack=1 task=49 at 0 I/art ( 1313): Late-enabling -Xcheck:jni I/ActivityManager( 488): Start proc 1313:com.example.p2pgo/u0a45 for activity com.example.p2pgo/.P2pGo V/WindowManager( 488): Adding window Window{38e17d1c u0 Starting com.example.p2pgo} at 2 of 7 (after Window{119189a8 u0 com.android.launcher/com.android.launcher2.Launcher}) D/sandip ( 1313): Starting Autonomous GO... D/Tethering( 488): sendTetherStateChangedBroadcast 1, 0, 0 D/OpenGLRenderer( 1313): Use EGL_SWAP_BEHAVIOR_PRESERVED: true I/imx6.gralloc( 1313): open gpu gralloc module! D/Tethering( 488): InitialState.processMessage what=4 D/Tethering( 488): sendTetherStateChangedBroadcast 0, 0, 0 D/Atlas ( 1313): Validating map... V/WindowManager( 488): Adding window Window{2c8c654c u0 com.example.p2pgo/com.example.p2pgo.P2pGo} at 2 of 8 (before Window{38e17d1c u0 Starting com.example.p2pgo}) I/OpenGLRenderer( 1313): Initialized EGL, version 1.4 D/OpenGLRenderer( 1313): Enabling debug mode 0 E/BufferQueueProducer( 194): [com.example.p2pgo/com.example.p2pgo.P2pGo] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count E/wpa_supplicant( 1295): Using interface p2p-p2p0-0 with hwaddr 02:19:b8:01:02:03 and ssid "DIRECT-5k-Android_ab58" D/Tethering( 488): sendTetherStateChangedBroadcast 1, 0, 0 I/wpa_supplicant( 1295): p2p-p2p0-0: interface state UNINITIALIZED->ENABLED I/wpa_supplicant( 1295): p2p-p2p0-0: AP-ENABLED I/wpa_supplicant( 1295): p2p-p2p0-0: CTRL-EVENT-CONNECTED - Connection to 02:19:b8:01:02:03 completed [id=0 id_str=] I/wpa_supplicant( 1295): P2P-GROUP-STARTED p2p-p2p0-0 GO ssid="DIRECT-5k-Android_ab58" freq=2462 go_dev_addr=00:19:b8:01:02:04 [PERSISTENT] D/CommandListener( 197): Setting iface cfg D/CommandListener( 197): Trying to bring up p2p-p2p0-0 D/TetherController( 197): tetherInterface(p2p-p2p0-0) D/sandip ( 1313): Successfully started AutoGO. D/TetherController( 197): Starting tethering services I/ActivityManager( 488): Displayed com.example.p2pgo/.P2pGo: +487ms D/TetherController( 197): Sending update msg to dnsmasq [update_ifaces:p2p-p2p0-0] D/TetherController( 197): Tethering services running D/WifiP2pService( 488): Started Dhcp server on p2p-p2p0-0 I/dnsmasq ( 1353): started, version 2.51 cachesize 150 I/dnsmasq ( 1353): compile time options: no-IPv6 GNU-getopt no-DBus no-I18N DHCP no-scripts no-TFTP W/dnsmasq ( 1353): warning: no upstream servers configured I/dnsmasq ( 1353): DHCP, IP range 192.168.49.2 -- 192.168.49.254, lease time 1h I/dnsmasq ( 1353): DHCP, IP range 192.168.48.2 -- 192.168.48.254, lease time 1h I/dnsmasq ( 1353): DHCP, IP range 192.168.47.2 -- 192.168.47.254, lease time 1h I/dnsmasq ( 1353): DHCP, IP range 192.168.46.2 -- 192.168.46.254, lease time 1h I/dnsmasq ( 1353): DHCP, IP range 192.168.45.2 -- 192.168.45.254, lease time 1h I/dnsmasq ( 1353): DHCP, IP range 192.168.44.2 -- 192.168.44.254, lease time 1h I/dnsmasq ( 1353): DHCP, IP range 192.168.43.2 -- 192.168.43.254, lease time 1h I/dnsmasq ( 1353): DHCP, IP range 192.168.42.2 -- 192.168.42.254, lease time 1h I/dnsmasq ( 1353): read /etc/hosts - 1 addresses D/dnsmasq ( 1353): now still use this interfaces so keep it alive D/dnsmasq ( 1353): now still use this interfaces so keep it alive W/audio_hw_primary( 200): do_out_standby... 1971955904 D/TaskPersister( 488): removeObsoleteFile: deleting file=47_task.xml W/AudioTrack( 488): AUDIO_OUTPUT_FLAG_FAST denied by client D/PermissionCache( 194): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (244 us) I/audio_hw_primary( 200): start_output_stream... 1971955904, device 2 W/audio_hw_primary( 200): card 0, port 0 device 0x2 W/audio_hw_primary( 200): rate 44100, channel 2 period_size 0xc0 E/BufferQueueProducer( 194): [com.android.launcher/com.android.launcher2.Launcher] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count W/ResourceType( 601): No package identifier when getting value for resource number 0x00000000 W/PackageManager( 601): Failure retrieving resources for com.example.p2pgo: Resource ID #0x0 W/OpenGLRenderer( 820): Incorrectly called buildLayer on View: ShortcutAndWidgetContainer, destroying layer... W/AudioTrack( 488): AUDIO_OUTPUT_FLAG_FAST denied by client I/ActivityManager( 488): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.freescale.wfdsink/.WfdSinkActivity (has extras)} from uid 10006 on display 0 V/WindowManager( 488): addAppToken: AppWindowToken{ef5c25a token=Token{1bdff205 ActivityRecord{1a99b97c u0 com.freescale.wfdsink/.WfdSinkActivity t50}}} to stack=1 task=50 at 0 V/WindowManager( 488): Adding window Window{321f5cbd u0 Starting com.freescale.wfdsink} at 2 of 7 (after Window{119189a8 u0 com.android.launcher/com.android.launcher2.Launcher}) I/ActivityManager( 488): Start proc 1356:com.freescale.wfdsink/1000 for activity com.freescale.wfdsink/.WfdSinkActivity I/WfdSink ( 1356): initialize success I/InputDispatcher( 488): Dropping event because there is no touchable window at (339, 371). D/WifiService( 488): New client listening to asynchronous messages I/InputDispatcher( 488): Dropping event because there is no touchable window at (340, 371). D/OpenGLRenderer( 1356): Use EGL_SWAP_BEHAVIOR_PRESERVED: true I/imx6.gralloc( 1356): open gpu gralloc module! I/InputDispatcher( 488): Dropping event because there is no touchable window at (343, 370). D/Atlas ( 1356): Validating map... V/WindowManager( 488): Adding window Window{325ae8d6 u0 com.freescale.wfdsink/com.freescale.wfdsink.WfdSinkActivity} at 2 of 8 (before Window{321f5cbd u0 Starting com.freescale.wfdsink}) I/WfdSink ( 1356): mWifiP2pEnabled I/WfdSink ( 1356): p2p this deviceDevice: Android_ab58 I/WfdSink ( 1356): deviceAddress: 00:19:b8:01:02:04 I/WfdSink ( 1356): primary type: 10-0050F204-5 I/WfdSink ( 1356): secondary type: null I/WfdSink ( 1356): wps: 0 I/WfdSink ( 1356): grpcapab: 0 I/WfdSink ( 1356): devcapab: 0 I/WfdSink ( 1356): status: 0 I/WfdSink ( 1356): wfdInfo: WFD enabled: falseWFD DeviceInfo: 0 I/WfdSink ( 1356): WFD CtrlPort: 0 I/WfdSink ( 1356): WFD MaxThroughput: 0 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$1.onReceive:194 android.app.LoadedApk$ReceiverDispatcher$Args.run:866 android.os.Handler.handleCallback:739 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073743104heightMeasureSpec 1073742576 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742576 I/InputDispatcher( 488): Dropping event because there is no touchable window at (344, 370). I/InputDispatcher( 488): Dropping event because there is no touchable window at (345, 370). I/InputDispatcher( 488): Dropping event because there is no touchable window at (348, 369). I/WfdSink ( 1356): Successfully set WFD info. I/InputDispatcher( 488): Dropping event because there is no touchable window at (349, 368). I/InputDispatcher( 488): Dropping event because there is no touchable window at (352, 367). I/InputDispatcher( 488): Dropping event because there is no touchable window at (354, 367). I/InputDispatcher( 488): Dropping event because there is no touchable window at (355, 367). I/InputDispatcher( 488): Dropping event because there is no touchable window at (357, 367). I/OpenGLRenderer( 1356): Initialized EGL, version 1.4 D/OpenGLRenderer( 1356): Enabling debug mode 0 E/BufferQueueProducer( 194): [com.freescale.wfdsink/com.freescale.wfdsink.WfdSinkActivity] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073743104heightMeasureSpec 1073742624 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 V/WindowManager( 488): Adding window Window{3f6641f3 u0 SurfaceView} at 2 of 9 (before Window{325ae8d6 u0 com.freescale.wfdsink/com.freescale.wfdsink.WfdSinkActivity}) D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/WfdSink ( 1356): p2p this deviceDevice: Android_ab58 I/WfdSink ( 1356): deviceAddress: 00:19:b8:01:02:04 I/WfdSink ( 1356): primary type: 10-0050F204-5 I/WfdSink ( 1356): secondary type: null I/WfdSink ( 1356): wps: 0 I/WfdSink ( 1356): grpcapab: 0 I/WfdSink ( 1356): devcapab: 0 I/WfdSink ( 1356): status: 0 I/WfdSink ( 1356): wfdInfo: WFD enabled: trueWFD DeviceInfo: 17 I/WfdSink ( 1356): WFD CtrlPort: 7236 I/WfdSink ( 1356): WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$1.onReceive:194 android.app.LoadedApk$ReceiverDispatcher$Args.run:866 android.os.Handler.handleCallback:739 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073743104heightMeasureSpec 1073742624 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/ActivityManager( 488): Displayed com.freescale.wfdsink/.WfdSinkActivity: +668ms D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073743104heightMeasureSpec 1073742624 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 D/TaskPersister( 488): removeObsoleteFile: deleting file=43_task.xml D/TaskPersister( 488): removeObsoleteFile: deleting file=43_task_thumbnail.png W/audio_hw_primary( 200): do_out_standby... 1971955904 I/WfdSink ( 1356): start discoverPeers I/WfdSink ( 1356): start discoverPeers I/WfdSink ( 1356): discover success I/wpa_supplicant( 1295): p2p0: P2P: Reject scan trigger since one is already pending I/WfdSink ( 1356): discover success I/WfdSink ( 1356): Received list of peers. W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 I/WfdSink ( 1356): Received list of peers. W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): setSourcePeers D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/WfdSink ( 1356): start discoverPeers I/WfdSink ( 1356): start discoverPeers I/wpa_supplicant( 1295): p2p0: P2P: Reject scan trigger since one is already pending I/WfdSink ( 1356): discover success I/wpa_supplicant( 1295): p2p0: P2P: Reject scan trigger since one is already pending I/WfdSink ( 1356): discover success I/WfdSink ( 1356): Received list of peers. W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 I/WfdSink ( 1356): Received list of peers. W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): setSourcePeers D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 3c:a3:08:97:0f:f7 p2p_dev_addr=3c:a3:08:97:0f:f7 pri_dev_type=10-0050F204-5 name='nitrogen6x' config_methods=0x88 dev_capab=0x27 group_capab=0x0 I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 3a:d2:69:b7:a8:cc p2p_dev_addr=38:d2:69:b7:a8:cd pri_dev_type=10-0050F204-5 name='Endo_38d269b7a8cc' config_methods=0x88 dev_capab=0x25 group_capab=0x9 wfd_dev_info=0x00111c440032 I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 3c:a3:08:92:10:9a p2p_dev_addr=3c:a3:08:92:10:9a pri_dev_type=10-0050F204-5 name='nitrogen6x' config_methods=0x88 dev_capab=0x27 group_capab=0x0 I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 3a:d2:69:b7:aa:87 p2p_dev_addr=38:d2:69:b7:aa:88 pri_dev_type=10-0050F204-5 name='Endo_38d269b7aa87' config_methods=0x88 dev_capab=0x25 group_capab=0x9 wfd_dev_info=0x00111c440032 I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): setSourcePeers D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 9c:6c:15:09:c5:c6 p2p_dev_addr=9c:6c:15:09:c5:c5 pri_dev_type=10-0050F200-0 name='Windows Phone' config_methods=0x188 dev_capab=0x24 group_capab=0x3b vendor_elems=1 I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Windows Phone, deviceAddress: 9c:6c:15:09:c5:c5, primary type: 10-0050F200-0, secondary type: null, wps: 392, grpcapab: 59, devcapab: 36, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 76:23:44:9a:11:6f p2p_dev_addr=76:23:44:9a:11:6f pri_dev_type=10-0050F204-5 name='nik' config_methods=0x188 dev_capab=0x25 group_capab=0x0 wfd_dev_info=0x00101c440032 I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: nik, deviceAddress: 76:23:44:9a:11:6f, primary type: 10-0050F204-5, secondary type: null, wps: 392, grpcapab: 0, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 16, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Windows Phone, deviceAddress: 9c:6c:15:09:c5:c5, primary type: 10-0050F200-0, secondary type: null, wps: 392, grpcapab: 59, devcapab: 36, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): getItem:nik W/WfdSinkActivity( 1356): getItem:nik D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 W/WfdSinkActivity( 1356): getItem:nik I/wpa_supplicant( 1295): p2p-p2p0-0: AP-STA-CONNECTED 76:23:44:9a:11:6f p2p_dev_addr=76:23:44:9a:11:6f I/wpa_supplicant( 1295): AP-STA-CONNECTED 76:23:44:9a:11:6f p2p_dev_addr=76:23:44:9a:11:6f I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: nik, deviceAddress: 76:23:44:9a:11:6f, primary type: 10-0050F204-5, secondary type: null, wps: 392, grpcapab: 0, devcapab: 37, status: 0, wfdInfo: WFD enabled: trueWFD DeviceInfo: 16, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Windows Phone, deviceAddress: 9c:6c:15:09:c5:c5, primary type: 10-0050F200-0, secondary type: null, wps: 392, grpcapab: 59, devcapab: 36, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers I/WfdSink ( 1356): Received group info: network: DIRECT-5k-Android_ab58, isGO: true, GO: Device: , deviceAddress: 00:19:b8:01:02:04, primary type: null, secondary type: null, wps: 0, grpcapab: 0, devcapab: 0, status: 4, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0, Client: Device: nik, deviceAddress: 76:23:44:9a:11:6f, primary type: 10-0050F204-5, secondary type: null, wps: 392, grpcapab: 0, devcapab: 37, status: 0, wfdInfo: WFD enabled: trueWFD DeviceInfo: 16, WFD CtrlPort: 7236, WFD MaxThroughput: 50, interface: p2p-p2p0-0, networkId: 0 I/WfdSink ( 1356): ConnectedDevice is Device: nik, deviceAddress: 76:23:44:9a:11:6f, primary type: 10-0050F204-5, secondary type: null, wps: 392, grpcapab: 0, devcapab: 37, status: 0, wfdInfo: WFD enabled: trueWFD DeviceInfo: 16, WFD CtrlPort: 7236, WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$3.onGroupInfoAvailable:267 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:766 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): getItem:nik W/WfdSinkActivity( 1356): getItem:nik D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 W/WfdSinkActivity( 1356): getItem:nik I/wpa_supplicant( 1295): P2P-FIND-STOPPED I/WfdSink ( 1356): stop peers discovery success I/WfdSinkActivity( 1356): surfaceCreated. I/WfdSinkActivity( 1356): surfaceChanged. w=1. h=1 I/wpa_supplicant( 1295): wpa_driver_nl80211_driver_cmd: Unsupported command MIRACAST 2 I/MediaFocusControl( 488): AudioFocus requestAudioFocus() from android.media.AudioManager@295c26bb req=1flags=0x0 I/WfdSinkActivity( 1356): requestAudioFocus Successfully! D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073743104heightMeasureSpec 1073742624 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/WfdSink ( 1356): startRtsp D/WfdSink ( 1356): wifi sink get devicep2p-p2p0-0 D/WfdSink ( 1356): wifi sink get devicep2p-p2p0-0 D/WfdSink ( 1356): wifi sink get devicep2p-p2p0-0 D/WfdSink ( 1356): wifi sink get devicep2p-p2p0-0 D/WfdSink ( 1356): wifi sink get devicep2p-p2p0-0 D/WfdSink ( 1356): wifi sink get devicep2p-p2p0-0 D/WfdSink ( 1356): wifi sink get devicep2p-p2p0-0 I/dnsmasq ( 1353): DHCPDISCOVER(p2p-p2p0-0) 76:23:44:9a:11:6f I/dnsmasq ( 1353): DHCPOFFER(p2p-p2p0-0) 192.168.49.216 76:23:44:9a:11:6f I/dnsmasq ( 1353): DHCPREQUEST(p2p-p2p0-0) 192.168.49.216 76:23:44:9a:11:6f I/dnsmasq ( 1353): DHCPACK(p2p-p2p0-0) 192.168.49.216 76:23:44:9a:11:6f MI5-nik D/WfdSink ( 1356): wifi sink get devicep2p-p2p0-0 D/WfdSink ( 1356): Arp and dnsmasq already sync I/WfdSink ( 1356): Will connnect to 192.168.49.216:7236 from Wifi display I/WifiDisplaySink( 1356): sendrolon Main display is 1280x800 @60.00fps, so pick best resolution type=1, index=8 I/WifiDisplaySink( 1356): sendrolon:prepareUIBCdata: Wrk: 1280.000000 Hrk: 800.000000 Wnk: 1280.000000 Hnk: 800.000000 Sk: 1.000000 Bw: 0.000000 Bh: 0.000000 E/WifiDisplaySink( 1356): no hdcp library I/ ( 1356): address:192.168.49.216, port:7236 I/NetworkSession( 1356): connecting socket 40 to 192.168.49.216:7236 E/NetworkSession( 1356): writeMore on socket 40 failed w/ error -111 (Connection refused) E/WifiDisplaySink( 1356): An error occurred in session 1 (-111, 'Connection failed/Connection refused'). I/WifiDisplaySink( 1356): Lost control connection. D/WifiDisplaySink( 1356): RTSP retry left 3 times I/NetworkSession( 1356): connecting socket 41 to 192.168.49.216:7236 E/NetworkSession( 1356): writeMore on socket 41 failed w/ error -111 (Connection refused) E/WifiDisplaySink( 1356): An error occurred in session 2 (-111, 'Connection failed/Connection refused'). I/WifiDisplaySink( 1356): Lost control connection. D/WifiDisplaySink( 1356): RTSP retry left 2 times I/NetworkSession( 1356): connecting socket 42 to 192.168.49.216:7236 E/NetworkSession( 1356): writeMore on socket 42 failed w/ error -111 (Connection refused) E/WifiDisplaySink( 1356): An error occurred in session 3 (-111, 'Connection failed/Connection refused'). I/WifiDisplaySink( 1356): Lost control connection. D/WifiDisplaySink( 1356): RTSP retry left 1 times I/NetworkSession( 1356): connecting socket 43 to 192.168.49.216:7236 E/NetworkSession( 1356): writeMore on socket 43 failed w/ error -111 (Connection refused) E/WifiDisplaySink( 1356): An error occurred in session 4 (-111, 'Connection failed/Connection refused'). I/WifiDisplaySink( 1356): Lost control connection. D/WifiDisplaySink( 1356): RTSP retry left 0 times I/NetworkSession( 1356): connecting socket 44 to 192.168.49.216:7236 E/NetworkSession( 1356): writeMore on socket 44 failed w/ error -111 (Connection refused) E/WifiDisplaySink( 1356): An error occurred in session 5 (-111, 'Connection failed/Connection refused'). I/WifiDisplaySink( 1356): Lost control connection. D/WifiDisplaySink( 1356): RTSP retry over. It's dead. I/SinkDisplay( 1356): rtsp connected failed I/wpa_supplicant( 1295): wpa_driver_nl80211_driver_cmd: Unsupported command MIRACAST 0 I/WfdSink ( 1356): stopRtsp I/WifiDisplaySink( 1356): wfd sink teardown W/WifiDisplaySink( 1356): Session is not in PLAYING State for teardown I/WfdSink ( 1356): stopRtp W/WfdSinkActivity( 1356): setSourcePeers I/WfdSinkActivity( 1356): surfaceDestroyed. D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073743104heightMeasureSpec 1073742624 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/WfdSink ( 1356): Successfully set WFD info. I/WfdSink ( 1356): p2p this deviceDevice: Android_ab58 I/WfdSink ( 1356): deviceAddress: 00:19:b8:01:02:04 I/WfdSink ( 1356): primary type: 10-0050F204-5 I/WfdSink ( 1356): secondary type: null I/WfdSink ( 1356): wps: 0 I/WfdSink ( 1356): grpcapab: 0 I/WfdSink ( 1356): devcapab: 0 I/WfdSink ( 1356): status: 0 I/WfdSink ( 1356): wfdInfo: WFD enabled: trueWFD DeviceInfo: 19 I/WfdSink ( 1356): WFD CtrlPort: 7236 I/WfdSink ( 1356): WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$1.onReceive:194 android.app.LoadedApk$ReceiverDispatcher$Args.run:866 android.os.Handler.handleCallback:739 D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 I/WfdSink ( 1356): start discoverPeers I/WfdSink ( 1356): discover success I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: nik, deviceAddress: 76:23:44:9a:11:6f, primary type: 10-0050F204-5, secondary type: null, wps: 392, grpcapab: 0, devcapab: 37, status: 0, wfdInfo: WFD enabled: trueWFD DeviceInfo: 16, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Windows Phone, deviceAddress: 9c:6c:15:09:c5:c5, primary type: 10-0050F200-0, secondary type: null, wps: 392, grpcapab: 59, devcapab: 36, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): getItem:nik W/WfdSinkActivity( 1356): getItem:nik D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 W/WfdSinkActivity( 1356): getItem:nik I/WfdSink ( 1356): start discoverPeers I/wpa_supplicant( 1295): p2p0: P2P: Reject scan trigger since one is already pending I/WfdSink ( 1356): discover success I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: nik, deviceAddress: 76:23:44:9a:11:6f, primary type: 10-0050F204-5, secondary type: null, wps: 392, grpcapab: 0, devcapab: 37, status: 0, wfdInfo: WFD enabled: trueWFD DeviceInfo: 16, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Windows Phone, deviceAddress: 9c:6c:15:09:c5:c5, primary type: 10-0050F200-0, secondary type: null, wps: 392, grpcapab: 59, devcapab: 36, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): getItem:nik W/WfdSinkActivity( 1356): getItem:nik D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 W/WfdSinkActivity( 1356): getItem:nik I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 3a:d2:69:b7:aa:87 p2p_dev_addr=38:d2:69:b7:aa:88 pri_dev_type=10-0050F204-5 name='Endo_38d269b7aa87' config_methods=0x88 dev_capab=0x25 group_capab=0x9 wfd_dev_info=0x00111c440032 I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 3a:d2:69:b7:a8:cc p2p_dev_addr=38:d2:69:b7:a8:cd pri_dev_type=10-0050F204-5 name='Endo_38d269b7a8cc' config_methods=0x88 dev_capab=0x25 group_capab=0x9 wfd_dev_info=0x00111c440032 I/wpa_supplicant( 1295): P2P-DEVICE-FOUND 9c:6c:15:09:c5:c6 p2p_dev_addr=9c:6c:15:09:c5:c5 pri_dev_type=10-0050F200-0 name='Windows Phone' config_methods=0x188 dev_capab=0x24 group_capab=0x3b vendor_elems=1 I/WfdSink ( 1356): start discoverPeers I/WfdSink ( 1356): discover success I/WfdSink ( 1356): Received list of peers. I/WfdSink ( 1356): Device: nik, deviceAddress: 76:23:44:9a:11:6f, primary type: 10-0050F204-5, secondary type: null, wps: 392, grpcapab: 0, devcapab: 37, status: 0, wfdInfo: WFD enabled: trueWFD DeviceInfo: 16, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:92:10:9a, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: nitrogen6x, deviceAddress: 3c:a3:08:97:0f:f7, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 0, devcapab: 39, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Windows Phone, deviceAddress: 9c:6c:15:09:c5:c5, primary type: 10-0050F200-0, secondary type: null, wps: 392, grpcapab: 59, devcapab: 36, status: 3, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0 I/WfdSink ( 1356): Device: Endo_38d269b7a8cc, deviceAddress: 38:d2:69:b7:a8:cd, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 I/WfdSink ( 1356): Device: Endo_38d269b7aa87, deviceAddress: 38:d2:69:b7:aa:88, primary type: 10-0050F204-5, secondary type: null, wps: 136, grpcapab: 9, devcapab: 37, status: 3, wfdInfo: WFD enabled: trueWFD DeviceInfo: 17, WFD CtrlPort: 7236, WFD MaxThroughput: 50 W/ContextImpl( 1356): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 android.content.ContextWrapper.sendBroadcast:377 com.fsl.wfd.WfdSink$4.onPeersAvailable:309 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:754 android.os.Handler.dispatchMessage:102 W/WfdSinkActivity( 1356): setSourcePeers W/WfdSinkActivity( 1356): getItem:nik W/WfdSinkActivity( 1356): getItem:nik D/SinkView( 1356): onMeasure mVideoW 0mVideoH 0widthMeasureSpec 1073741825heightMeasureSpec 1073742624 W/WfdSinkActivity( 1356): getItem:nik
