wl1271 port
Other Parts Discussed in Thread: WL1271, OMAP3530, TEST2, 4430
Hi All,
  I want to port the the SDIO driver of an MCU from linux to threadx to interface with wl1271. Now the port that is available on linux is for MMC card using SDIO. My doubt is:
Can the WL1271 work using the MMC card interface? If not, then can someone help me with the basic low level SDIO API's needed to port on threadx for WL1271.
Vineet.
  • Hi guy .
    you can use the WL1271 SDIO API that will be define from TI ; and change the MMC layer to TI SDIO API ; the point that to implement the SDIO API eg sdioDrv_ReadSync  ,sdioDrv_ReadAsync,sdioDrv_WriteSync,sdioDrv_WriteAsync ,sdioDrv_ReadSyncBytes ,sdioDrv_WriteSyncBytes for cmd 52 and cmd53  ; the APi source in the WiLink\external_drivers
    also you have to initial the cmd0 and cmd5 and cmd3 and cmd 7 firstly as you use the WL1271 for SDIO inteference.
    B.Regard.
    DaCo.
  • Hi Vineet,
    In general you need to have a similar implementation of the SDIO  driver to the one located in:
    ../external_xrivers/<target-platform>/Linux/sdio
    Please pay attanation to the files "SdioDrv.h" and "SdioDrv.c" which has the APis that you need to expose to the WLAN driver.
    In addition to the SDIO driver itself, you need to have a similar threadx implementation for the file "...\platforms\hw\host_platform_xxx\linux\SdioAdapter.c" which uses the SDIO driver for initializng the WLAN chip.
    Hope this helps.
    Eyal Reizer
  • Hi Eyal,
       As I understand, I need to replace all the APIs in the SdioDrv.c file as I am not using a TI processor. So this will make the SDIOAdapter.c port with the least of changes.
    Is that correct?
    Vineet.
  • Hi Vineet,
    Yes, this is correct.
    Eyal
    my project is similar.
    I am new to the TI products and i have some problems finding the right source files for the WL 1271 driver and the files i have to port.
    Can you give me a link to the package, where i can find these files?
    Thanks very much!
    Christoph
    I would start by going to www.ti.com/connectivitywiki
    You can use the following link to get the complete package:
    http://processors.wiki.ti.com/index.php/ARM_Processor_Wireless_Connectivity_Downloads
    Eyal
  • Hi Christoph,
    The WiLink (WL1271) driver for OMAP35x Linux is available in the below given package.
    http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/ecs/WL1271_Linux_SDK/3_00_01_06//exports/V3.00.01.06-WL6.1.6.0-Linux-x86-Install
    Please install the package on a Linux machine. The driver (WiLink6.1.6.0.tar.bz2) is available in software/MS_TI_OMAP35x_WL1271_6.1.0.0.144/MS_TI_WL1271_Sources/common/wireless_src/
    Sinoj
  • Hello Sinoj,
    I downloaded the package V3.00.01.06-WL6.1.6.0-Linux-x86-Install and am trying to get the WL1271 source code out of the package. Does the package include all the WL1271 driver source code? How do I install the package? I tried it on Ubunto linux machine but it doesn;t know how to open the package.
    T. Li
  • Not an issue anymore. I got the package unstalled.
    Another question, why the driver version number from the source code is different from what is listed by the release package?
    Release package says WL6.1.6.0
    Actual source says  Driver: 6.1.0.0.144, Firmware 6.1.0.0.335
    Thanks!
    TL
  • Hi TL,
    Thanks for the update. The string "WL6.1.6.0" is used to say about complete package which includes WiLink driver, firmware, etc. Each module in the package has its own version.
    For example: omap35x-WL1271 beta2 release WL6.1.6.0 comprises:
    WLAN driver for Linux    6.1.0.0.144
    Firmware version    6.1.0.0.335
    omap35x-WL1271 beta release WL6.1.3.1 comprises:
    WLAN driver for Linux    6.0.0.130
    Firmware version    6.0.0.313
    Sinoj
  • Sinoj,
    Thank you for the explanation. I do have another question.
    I just merged the Beta-2 release to my WinCE driver. I am still having problems with the poor ping test and disconnections as I had in the previous versions.
    This seems has something dto do with the power save mode enabled. The wlan gets disconnected (and reconnected automatically) very often and the ping lost is almost 10%. It seems work much better if I turn the power save off.
    Is this a known issue with the Beta-2 release?
    TL
  • Hello Sinoj,
    I am trying to figure out why the wlan gets disconnected so frequently. It seems that the Power-saving is not working well. There are times the driver stays in the state POWER_SRV_STATE_PS (2) and fails to transit to POWER_SRV_STATE_PEND_ACTIVE (3) and then to POWER_SRV_STATE_ACTIVE (4).  I was doing a continuous ping to the WL1271 device.
    There are also times when the device stays in PS for 5 to 6 seconds and the ping from other device got timed out.
    What could be the cause?
    TL
  • TL,
    Can you provide some more information on your setup (HW & SW)?
    Did you check the release notes? http://processors.wiki.ti.com/index.php/OMAP35x_Wireless_Connectivity_Release_Notes_beta_2_release
    Is there any interoperability issue with the Access Point you have? What is the model of AP? Is it possible to try Linux image on the setup?
    Sinoj
  • Sonoj,
    Thanks for the quick reply.
    The HW is OMAP3730+WL1271 running on WinCE6. There is no IOP issue since it works OK with PS disabled.
    I check the beta2 release notes and found that the waking from PS is a known issue. It is even listed as open in the beta-3 release notes. I just want to know if there is any workaround you can implement on the driver side. And when there will be a fix from TI?
    Another question is the performance in PS mode. Is there any parameters we can adjust?
    Thanks for help.
    TL
  • TL,
    To understand the problem exactly, please provide the following informations;
    1. AP details
    2. AP configuration
    3. Whether calibration has been done?
    4. Whether you are seeing this issue with several APs
    5. "check the beta2 release notes and found that the waking from PS is a known issue"  which issue you are talking about?
    6. Logs (if any).
    Sinoj
  • Hello Sinoj,
    Thanks for your help. Here are the information you requested for.
    1 & 2. AP & Config - We are using Aruba Networks Mobility Controller in 2.4 GHz g-mode on channel 11.
    The AP is close to my device with RRSI around -45 dbm so signal strength is not an issue.
    We use WPA2-PSK/AES for authentication/encryption. WMM and WMM power save enabled.
    3. Calibration is OK.
    4. Whether you are seeing this issue with several APs - Yes. Works better on one AP.
    5. Quotes from Release notes:
    Beta-2 release (the version I am using)
     Hardware Limitations In some cases, the WL127x device may fail to wake up when receiving a host request because of a timing issue in the POR module. The host driver should contain implementation to work around this issue
    Headline
    Calibration: Missed beacon when awake from ELP due to calibration process
    Internal numbering
    MCS00052838
    Description/Scenario
    System misses beacons when wakes up from ELP due to calibration process.
    Beta-3 release (The next release by the end of this month)
    Headline
    Power Save: Firmware stays in PS after failing to enter PS
    Internal numbering
    MCS00080203
    Power Save: Firmware stays in PS after failing to enter PS.
    6. Logs - I have captured some logs related to the Power Save. See the places marked in question marks.
    Note that the it works well using those APs when PS is disabled.
    TIWLAN: 0.837404: ************ NEW CONNECTION ************
    TIWLAN: 0.837409: -- SSID = TTMACT
    TIWLAN: 0.837412: -- BSSID = 0-b-86-53-5-c2
    TIWLAN: 0.837416: ****************************************
    TIWLAN: 0.837422: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x1
    TIWLAN: 0.837438: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 0.837450: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x2
    TIWLAN: 0.838346: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 0.838362: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 0.838456: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 0.838478: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 0.935101: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    >>>>>>>>>>>>>>> DELETED SOME LOG HERE <<<<<<<<<<<<<<<<<<<<<
    TIWLAN: 0.990921: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 0.990982: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 0.991002: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    ??????? NOW THE POWER SAVING STAYS IN PS STATE AND FAILED TO WAKE UP
    TIWLAN: 1.001255: ***conn_infraSMEvent(): currentState 0x6, nextState 0x7
    TIWLAN: 1.001263: ***conn_infraSMEvent(): currentState 0x7, nextState 0x8
    TIWLAN: 1.001278: ***rsn_stop(): removeKeys = 0x0
    TIWLAN: 1.001290: ***mainKeys_smEvent(): currentState 0x4, nextState 0x0
    TIWLAN: 1.001304: ***unicastKey802_1x_event(): currentState 0x2, nextState 0x0
    TIWLAN: 1.001318: ***broadcastKey802_1x_event(): currentState 0x2, nextState 0x0
    TIWLAN: 1.001333: ***mlme_smEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.001347: ***assoc_smEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 1.001361: ***auth_osSMEvent(): currentState 0x2, nextState 0x0
    ??????? HERE IT GOT DISCONNECTED EVENTUALLY
    TIWLAN: 1.001375: ***connInfra_ScrWaitDisconn_to_disconnect: calling stopModules and prepare_send_disconnect.
    TIWLAN: 1.001385: ***stopModules
    TIWLAN: 1.001388: ***measurementMgrSM_event(): currentState 0x0, nextState 0x0
    TIWLAN: 1.001402: ***switchChannel_smEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 1.001417: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.001431: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.001446: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.001460: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.001475: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.001490: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.001506: ***conn_infraSMEvent(): currentState 0x8, nextState 0x0
    TIWLAN: 1.001518: ***DISCONNECT***connInfra_WaitDisconnectToIdle:
    disAssocEventReason 1
    disAssocEventStatusCode = 0
    connType=0
    disConnType=0
    TIWLAN: 1.001533: ***conn_infraSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.001545: ***conn_infraSMEvent(): currentState 0x1, nextState 0x2
    WZC: Close EAPOL session
    TIWLAN: 1.001626: ***conn_infraSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.001635: ***mlme_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.001649: ***auth_osSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.001668: ***auth_osSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.001677: ***mlme_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.001691: ***assoc_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.001712: ***assoc_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.001720: ***mlme_smEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.001734: ***conn_infraSMEvent(): currentState 0x3, nextState 0x4
    TIWLAN: 1.001756: ***mainKeys_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.001770: ***unicastKey802_1x_event(): currentState 0x0, nextState 0x1
    TIWLAN: 1.001784: ***broadcastKey802_1x_event(): currentState 0x0, nextState 0x1
    TIWLAN: 1.004756: ***conn_infraSMEvent(): currentState 0x4, nextState 0x8
    TIWLAN: 1.004764: ***rsn_stop(): removeKeys = 0x1
    TIWLAN: 1.004777: ***mainKeys_smEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 1.004791: ***unicastKey802_1x_event(): currentState 0x1, nextState 0x0
    TIWLAN: 1.004805: ***broadcastKey802_1x_event(): currentState 0x1, nextState 0x0
    TIWLAN: 1.004820: ***rsn_stop(): resetPmkidList()
    TIWLAN: 1.004825: ***mlme_smEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.004838: ***assoc_smEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 1.004852: ***auth_osSMEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 1.004866: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.004881: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.004896: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.004910: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.004928: ***conn_infraSMEvent(): currentState 0x8, nextState 0x0
    TIWLAN: 1.004939: ***DISCONNECT***connInfra_WaitDisconnectToIdle:
    connType=0
    disConnType=1
    TIWLAN: 1.004954: ***conn_infraSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.004966: ***conn_infraSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.005010: ***conn_infraSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.005019: ***mlme_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.005032: ***auth_osSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.005050: ***auth_osSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.005060: ***mlme_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.005074: ***assoc_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.005096: ***assoc_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.005104: ***mlme_smEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.005118: ***conn_infraSMEvent(): currentState 0x3, nextState 0x4
    TIWLAN: 1.005140: ***mainKeys_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.005154: ***unicastKey802_1x_event(): currentState 0x0, nextState 0x1
    TIWLAN: 1.005169: ***broadcastKey802_1x_event(): currentState 0x0, nextState 0x1
    TIWLAN: 1.008138: ***conn_infraSMEvent(): currentState 0x4, nextState 0x8
    TIWLAN: 1.008146: ***rsn_stop(): removeKeys = 0x1
    TIWLAN: 1.008158: ***mainKeys_smEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 1.008173: ***unicastKey802_1x_event(): currentState 0x1, nextState 0x0
    TIWLAN: 1.008187: ***broadcastKey802_1x_event(): currentState 0x1, nextState 0x0
    TIWLAN: 1.008202: ***rsn_stop(): resetPmkidList()
    TIWLAN: 1.008207: ***mlme_smEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.008220: ***assoc_smEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 1.008234: ***auth_osSMEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 1.008248: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.008263: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.008278: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.008292: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.008313: ***conn_infraSMEvent(): currentState 0x8, nextState 0x0
    TIWLAN: 1.008321: ***DISCONNECT***connInfra_WaitDisconnectToIdle:
    connType=0
    disConnType=1
    TIWLAN: 1.008340: set OID_802_11_SSID |JUNK|
    TIWLAN: 1.008342: ***scanSRVSM_SMEvent(): currentState 0x0, nextState 0x2
    TIWLAN: 1.008562: ***scanSRVSM_SMEvent(): currentState 0x2, nextState 0x4
    TIWLAN: 1.008570: ***scanSRVSM_SMEvent(): currentState 0x4, nextState 0x0
    TIWLAN: 1.013405: set OID_802_11_SSID |TTMACT|
    WZC: Associating with TTMACT
    TIWLAN: 1.013873: ***conn_infraSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.013881: ***conn_infraSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.013914: ***conn_infraSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.013923: ***mlme_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.013936: ***auth_osSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.013954: ***auth_osSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.013964: ***mlme_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.013978: ***assoc_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.014000: ***assoc_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.014008: ***mlme_smEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.014022: ***conn_infraSMEvent(): currentState 0x3, nextState 0x4
    TIWLAN: 1.014044: ***mainKeys_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.014058: ***unicastKey802_1x_event(): currentState 0x0, nextState 0x1
    TIWLAN: 1.014072: ***broadcastKey802_1x_event(): currentState 0x0, nextState 0x1
    WZC: WZC_ASSOCIATED_REQUIRES_8021X - Associated with TTMACT
    WZC: Reauthenticating with TTMACT
    WZC: configured
    TIWLAN: 1.014172: ***unicastKey802_1x_event(): currentState 0x1, nextState 0x2
    TIWLAN: 1.014181: ***mainKeys_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.014197: ***broadcastKey802_1x_event(): currentState 0x1, nextState 0x2
    TIWLAN: 1.014210: ***mainKeys_smEvent(): currentState 0x2, nextState 0x4
    TIWLAN: 1.014231: ***conn_infraSMEvent(): currentState 0x4, nextState 0x5
    TIWLAN: 1.014246: ***switchChannel_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.014260: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    on function from state 0x0 to 0x1
    TIWLAN: 1.014288: ***conn_infraSMEvent(): currentState 0x5, nextState 0x6
    TIWLAN: 1.014297: ************ NEW CONNECTION ************
    TIWLAN: 1.014302: -- SSID = TTMACT
    TIWLAN: 1.014305: -- BSSID = 0-1a-1e-b6-ff-42
    TIWLAN: 1.014309: ****************************************
    TIWLAN: 1.014314: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x1
    TIWLAN: 1.014329: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.014343: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x2
    TIWLAN: 1.014396: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.014412: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.014500: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.014521: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.387925: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.387936: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.387998: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.388019: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    ???????? IT STUCK IN THE PS STATE
    TIWLAN: 1.932292: ***conn_infraSMEvent(): currentState 0x6, nextState 0x7
    TIWLAN: 1.932300: ***conn_infraSMEvent(): currentState 0x7, nextState 0x8
    TIWLAN: 1.932315: ***rsn_stop(): removeKeys = 0x0
    TIWLAN: 1.932327: ***mainKeys_smEvent(): currentState 0x4, nextState 0x0
    TIWLAN: 1.932341: ***unicastKey802_1x_event(): currentState 0x2, nextState 0x0
    TIWLAN: 1.932355: ***broadcastKey802_1x_event(): currentState 0x2, nextState 0x0
    TIWLAN: 1.932370: ***mlme_smEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.932384: ***assoc_smEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 1.932398: ***auth_osSMEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 1.932412: ***connInfra_ScrWaitDisconn_to_disconnect: calling stopModules and prepare_send_disconnect.
    TIWLAN: 1.932422: ***stopModules
    TIWLAN: 1.932425: ***measurementMgrSM_event(): currentState 0x0, nextState 0x0
    TIWLAN: 1.932439: ***switchChannel_smEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 1.932454: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.932468: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.932483: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.932497: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.932512: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.932527: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.932543: ***conn_infraSMEvent(): currentState 0x8, nextState 0x0
    TIWLAN: 1.932555: ***DISCONNECT***connInfra_WaitDisconnectToIdle:
    connType=0
    disConnType=0
    TIWLAN: 1.932570: ***conn_infraSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.932582: ***conn_infraSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.932665: ***conn_infraSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.932674: ***mlme_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.932688: ***auth_osSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.933203: ***auth_osSMEvent(): currentState 0x1, nextState 0x1
    TIWLAN: 1.933713: ***auth_osSMEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 1.933722: ***mlme_smEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 1.933735: -------------------------------------
    TIWLAN: 1.933740: CONN LOST
    TIWLAN: 1.933745: -------------------------------------
    TIWLAN: 1.933750: ***DISCONNECT*** conn_reportMlmeStatus CONN_TYPE_ESS:
    disAssocEventReason 2
    disAssocEventStatusCode = 65535
    connType=0
    disConnType=1
    TIWLAN: 1.933765: ***conn_infraSMEvent(): currentState 0x3, nextState 0x8
    TIWLAN: 1.933779: ***mlme_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.933818: ***conn_infraSMEvent(): currentState 0x8, nextState 0x0
    TIWLAN: 1.933826: ***DISCONNECT***connInfra_WaitDisconnectToIdle:
    connType=0
    disConnType=1
    TIWLAN: 1.933840: ***conn_infraSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.933854: ***conn_infraSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.933890: ***conn_infraSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.933898: ***mlme_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.933912: ***auth_osSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.934427: ***auth_osSMEvent(): currentState 0x1, nextState 0x1
    TIWLAN: 1.934937: ***auth_osSMEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 1.934946: ***mlme_smEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 1.934959: -------------------------------------
    TIWLAN: 1.934964: CONN LOST
    TIWLAN: 1.934969: -------------------------------------
    TIWLAN: 1.934974: ***DISCONNECT*** conn_reportMlmeStatus CONN_TYPE_ESS:
    connType=0
    disConnType=1
    TIWLAN: 1.934989: ***conn_infraSMEvent(): currentState 0x3, nextState 0x8
    TIWLAN: 1.935003: ***mlme_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 1.935065: ***conn_infraSMEvent(): currentState 0x8, nextState 0x0
    TIWLAN: 1.935073: ***DISCONNECT***connInfra_WaitDisconnectToIdle:
    connType=0
    disConnType=1
    TIWLAN: 1.935092: set OID_802_11_SSID |JUNK|
    TIWLAN: 1.940138: set OID_802_11_SSID |TTMACT|
    TIWLAN: 1.940606: ***conn_infraSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.940615: ***conn_infraSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.940649: ***conn_infraSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.940657: ***mlme_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.940671: ***auth_osSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.940694: ***auth_osSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.940702: ***mlme_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.940716: ***assoc_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.940742: ***assoc_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.940750: ***mlme_smEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.940764: ***conn_infraSMEvent(): currentState 0x3, nextState 0x4
    TIWLAN: 1.940786: ***mainKeys_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.940800: ***unicastKey802_1x_event(): currentState 0x0, nextState 0x1
    TIWLAN: 1.940814: ***broadcastKey802_1x_event(): currentState 0x0, nextState 0x1
    WZC: configured
    TIWLAN: 1.940911: ***unicastKey802_1x_event(): currentState 0x1, nextState 0x2
    TIWLAN: 1.940920: ***mainKeys_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.940936: ***broadcastKey802_1x_event(): currentState 0x1, nextState 0x2
    TIWLAN: 1.940949: ***mainKeys_smEvent(): currentState 0x2, nextState 0x4
    TIWLAN: 1.940971: ***conn_infraSMEvent(): currentState 0x4, nextState 0x5
    TIWLAN: 1.940985: ***switchChannel_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.940999: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    sition function from state 0x0 to 0x1
    TIWLAN: 1.941025: ***conn_infraSMEvent(): currentState 0x5, nextState 0x6
    TIWLAN: 1.941033: ************ NEW CONNECTION ************
    TIWLAN: 1.941038: -- SSID = TTMACT
    TIWLAN: 1.941042: -- BSSID = 0-1a-1e-aa-ab-42
    TIWLAN: 1.941046: ****************************************
    TIWLAN: 1.941051: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x1
    TIWLAN: 1.941066: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 1.941079: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x2
    TIWLAN: 1.941257: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 1.941273: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 1.941362: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 1.941383: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    ??????? failed to exit from PS
    TIWLAN: 2.037108: ***conn_infraSMEvent(): currentState 0x6, nextState 0x7
    TIWLAN: 2.037116: ***conn_infraSMEvent(): currentState 0x7, nextState 0x8
    TIWLAN: 2.037131: ***rsn_stop(): removeKeys = 0x0
    TIWLAN: 2.037143: ***mainKeys_smEvent(): currentState 0x4, nextState 0x0
    TIWLAN: 2.037157: ***unicastKey802_1x_event(): currentState 0x2, nextState 0x0
    TIWLAN: 2.037171: ***broadcastKey802_1x_event(): currentState 0x2, nextState 0x0
    TIWLAN: 2.037186: ***mlme_smEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 2.037200: ***assoc_smEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 2.037214: ***auth_osSMEvent(): currentState 0x2, nextState 0x0
    TIWLAN: 2.037228: ***connInfra_ScrWaitDisconn_to_disconnect: calling stopModules and prepare_send_disconnect.
    TIWLAN: 2.037238: ***stopModules
    TIWLAN: 2.037241: ***measurementMgrSM_event(): currentState 0x0, nextState 0x0
    TIWLAN: 2.037255: ***switchChannel_smEvent(): currentState 0x1, nextState 0x0
    TIWLAN: 2.037270: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 2.037284: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 2.037299: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 2.037313: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 2.037328: ***trafficAdmCtrl_smEvent(): currentState 0x0, nextState 0x0
    TIWLAN: 2.037343: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 2.037359: ***conn_infraSMEvent(): currentState 0x8, nextState 0x0
    TIWLAN: 2.037371: ***DISCONNECT***connInfra_WaitDisconnectToIdle:
    connType=0
    disConnType=0
    TIWLAN: 2.037397: set OID_802_11_SSID |JUNK|
    TIWLAN: 2.037399: ***scanSRVSM_SMEvent(): currentState 0x0, nextState 0x2
    TIWLAN: 2.037633: ***scanSRVSM_SMEvent(): currentState 0x2, nextState 0x4
    TIWLAN: 2.037641: ***scanSRVSM_SMEvent(): currentState 0x4, nextState 0x0
    TIWLAN: 2.042464: set OID_802_11_SSID |TTMACT|
    TIWLAN: 2.042464: ***conn_infraSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 2.042477: ***conn_infraSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 2.042560: ***conn_infraSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 2.042572: ***mlme_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 2.042585: ***auth_osSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 2.042622: ***auth_osSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 2.042630: ***mlme_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 2.042644: ***assoc_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 2.042671: ***assoc_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 2.042679: ***mlme_smEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 2.042693: ***conn_infraSMEvent(): currentState 0x3, nextState 0x4
    TIWLAN: 2.042715: ***mainKeys_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 2.042729: ***unicastKey802_1x_event(): currentState 0x0, nextState 0x1
    TIWLAN: 2.042743: ***broadcastKey802_1x_event(): currentState 0x0, nextState 0x1
    WZC: configured
    TIWLAN: 2.042851: ***unicastKey802_1x_event(): currentState 0x1, nextState 0x2
    TIWLAN: 2.042860: ***mainKeys_smEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 2.042876: ***broadcastKey802_1x_event(): currentState 0x1, nextState 0x2
    TIWLAN: 2.042889: ***mainKeys_smEvent(): currentState 0x2, nextState 0x4
    TIWLAN: 2.042911: ***conn_infraSMEvent(): currentState 0x4, nextState 0x5
    TIWLAN: 2.042925: ***switchChannel_smEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 2.042939: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 2.042963: ***conn_infraSMEvent(): currentState 0x5, nextState 0x6
    TIWLAN: 2.042972: ************ NEW CONNECTION ************
    TIWLAN: 2.042977: -- SSID = TTMACT
    TIWLAN: 2.042980: -- BSSID = 0-1a-1e-aa-ad-a2
    TIWLAN: 2.042985: ****************************************
    TIWLAN: 2.042990: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x1
    TIWLAN: 2.043004: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
    TIWLAN: 2.043018: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x2
    TIWLAN: 2.046713: ***powerSrvSmSMEvent(): currentState 0x2, nextState 0x3
    TIWLAN: 2.046729: ***powerSrvSmSMEvent(): currentState 0x3, nextState 0x0
    TIWLAN: 2.046817: ***powerSrvSmSMEvent(): currentState 0x0, nextState 0x1
    TIWLAN: 2.046839: ***powerSrvSmSMEvent(): currentState 0x1, nextState 0x2
  • Hello Sinoj,
    Have you got a chance to look into the power saving problem I posted yet?
    My device is battery operated and have to have this feature working.
    TL
  • TL,
    Are you seeing differences when the WL1271 is working in different power saving modes, short doze and long doze? Please refer to
    http://processors.wiki.ti.com/index.php/OMAP35x_Wireless_Connectivity_ini_File_Description_and_Parameters_User%27s_Guide
    http://processors.wiki.ti.com/index.php/ARM_Processor_Wireless_Connectivity_FAQ#What_are_the_different_power_modes_.3F
    Sinoj
  • Hi, Sinoj,
    Yes, I have read the user's guide and FAQ. I also experimented using different power saving modes. It doesn't make much difference unless I completely disable the power save feature. The problem could be in the firmware I guess. Please help as this is a very critical issue to our product.
    Another issue I have seen is the quering the site manager configuration parameters SITE_MGR_CONFIGURATION_PARAM through IOCTLs. The function doesn't give the current information, It always gives channel 11 and beacon period of 200. The problem is not critical for me at this time though.
    The function in the driver is
    TI_STATUS siteMgr_getParam (TI_HANDLE hSiteMgr, paramInfo_t *pParam)
    case SITE_MGR_CONFIGURATION_PARAM:
    pParam->content.pSiteMgrConfiguration->Length = sizeof(OS_802_11_CONFIGURATION);
    pParam->content.pSiteMgrConfiguration->ATIMWindow = pSiteMgr->pDesiredParams->siteMgrDesiredAtimWindow;
    pParam->content.pSiteMgrConfiguration->BeaconPeriod = pSiteMgr->pDesiredParams->siteMgrDesiredBeaconInterval;
    pParam->content.pSiteMgrConfiguration->Union.channel =
    Chan2Freq(pSiteMgr->pDesiredParams->siteMgrDesiredChannel);
    /*pSiteMgr->pDesiredParams->siteMgrFreq2ChannelTable[pSiteMgr->pDesiredParams->siteMgrDesiredChannel];*/
    //The parameters does not get updated and I always get the following regardless the current configuration,
    //pParam->content.pSiteMgrConfiguration->Length = 32
    //pParam->content.pSiteMgrConfiguration->BeaconPeriod = 200
    //pSiteMgr->pDesiredParams->siteMgrDesiredChannel = 11
    //pParam->content.pSiteMgrConfiguration->Union.channel = 2462000
    Thanks for help,
    TL
  • Hi TL,
    Can you please try the latest release and let us know the results (OMAP3530 GA release)?
    Sinoj
  • Hi Sinoj,
    Thank you and I will try this new release.
    TL
  • Hello Sinoj,
    I tried the new release and I still have disconnect issues. It seems working a little better than beta2. I got 6 connection drops during a 12 hour overnight testing. The AP and the network has only one user and I was doing a continuous ping to the station.
    Do you have any suggestions?
    TL
  • Hello Sinoj,
    We've tried the new release from TI and we still see the power saving issue here. Could you let me know if this is still a known issue or it we are doing something wrong here? We need to have this resolved asap. Thank you.
    TL
  • TL,
    Since the driver was ported to WinCE we have requested TI to confirm whether there is a problem as regards the power saving mode. We don't have "Aruba Networks Mobility Controller" AP with us. Is there any other AP (Model) like Aruba with which we can reproduce (please provide steps to reproduce) the issue on the OMAP3 EVM+Linux?
    Thanks and Regards,
    Sinoj
  • Dear all,
    I'm launching a new project using AM/DM37 processor with WL1271 wifi module under WIN CE6.
    Can you please provide me link were i can get WL1271 WIN CE6 driver ? even Beta version ?
    Walid
  • Sinoj,
    I've tested it using a Netgear MBR624GU in g-mode only. The problem is reproduced fiarly easily.
    One way to see it happen is to ping the station continuously and watch the connection status on the device. You will see it happen after a wile.
    Another way to reproduce is to do a Chariot test on the RX. It only lasts from 40 minutes to 3.5 hours before the connection drops.
    Also, if you leave the station alone (idle) for some time, it will happen.
    In all those cases, you will see that wifi stays in PS state and fails to wake up. There are times when the firmware does recover from a long sleep (5-7 seconds). This leads to poor performance.
    I am wondering if there is a way to wake the chipset up from the host side, say read/write to somewhere to force it to wakeup?
    Thanks for help.
    TL
  • Hi TL,
    As per you request, we have carried out the ping tests on two EVMs (Mistral's OMAP35x+WL1271 DC) with the omap35x Linux GA drivers (http://processors.wiki.ti.com/index.php/ARM_Processor_Wireless_Connectivity_Downloads). Both tests have been conducted independently. Following are the test setup and results;
    Ping Test1:
    Station1: (OMAP35xEVM+WL1271) setup1 +  Linux Driver:6.1.0.1.149 with default configuration (Auto)
    AP1 : Cisco AIR-AP1252AG + Mixed mode (supports 802.11n) + WMM enabled + AES Encryption + Rssi-49 + Channel11
    Procedure: Connected the station1 to the AP1 and did ping from the PC connected to the AP1 to the Station 1 for more than 16hours
    Ping Results:
    60105 packets transmitted, 60097 received, 0% packet loss, time 60180272ms
    rrt min/avg/max/mdev = 1.414/63.744/917.042/37.941 ms
    Comments: On the EVM, no connection drop out;
    Ping Test2:
    Station2: (OMAP35xEVM+WL1271) setup 2 +  Linux Driver:6.1.0.1.149 with default configuration (Auto)
    AP2 : Netgear WNR1000 + Mode (Upto 150Mbps) + WMM enabled + WPA2-PSK -AES Encryption + Rssi-49 + Channel11 +
    Procedure: Connected the station2 to the AP2 and did ping from the PC connected to the AP2 to the Station 2 for more than 16hours
    Ping Results:
    --- 192.168.1.4 ping statistics ---
    59773 packets transmitted, 59348 received, 0% packet loss, time 59813690ms
    rtt min/avg/max/mdev = 1.286/79.095/1986.362/55.647 ms, pipe 2
    Commets:
    After doing the ping test the EVM was kept idle for another 8 hrs. Could not see any connection drop out on the EVM so far. This message "WPA: Group rekeying completed with 00:22:3f:a7:04:3f [GTK=CCMP]" only is being printed periodically on the console.
    Sinoj
  • Hi TL,
    We continued the ping test with another access point for 12 hrs and did not find any disconnection from the AP.
    Station: (OMAP35xEVM+WL1271)  +  Linux Driver:6.1.0.1.149 with default configuration (Auto)
    AP : Linksys WAP54G + Mode (802.11g only) + WPA2-PSK -AES Encryption + Rssi-45 + Channel11
    Sinoj
  • Hello Sinoj,
    Thank you for helping me out.
    I am going to do more testing this weekend. I will collect some logs and captures for you to analyze.
    TL
  • Hello Sinoj,
    I've done more testing on the power saving. The problem still exists.
    The tests were done using a Netgear MBR624GU in g-only mode on channel 6. RSSI is about -45. We used Chariot for testing RX. I've also added some debug messages in the driver to report the power save state changes.
    It happens quite often that the wifi stops receiving and the driver reports that the firmware is in SLEEP state. That resulted in the Chriot to time out. After the test stops, we tried to ping the station from a laptop and the station doesn't wake up. Sometimes it takes more than 10 pings to wake it up, other times it just wonlt wakeup at all. But if the ping is originated from the host side (the station), it wakes up immediately. During the long time sleeping, somehow the network connection is kept, i.e., no disconnect reported to the OS.
    I also checked the SDIO interrupt, command, and data lines using a scope. I was suspecting that the driver may missed interrupts. But that is not the case. After the firmware stopped receiving, there was no pending interrupt and the last interrupt received was processed correctly. There is no new interrupt coming from firmware when we ping to the station.
    Just for your info, the driver works very stable when power save is disabled.
    The following is the log from the driver. I added some comments near the end of the log. Thanks for help.
    //WL1271 Power Saving Test Log
    //Main issue is that the firmware won't wakeup even though there is data to receive.
    //Sometimes it stays in sleep state for 5-10 seconds when it supposed to receiving.
    //When we do Chariot test for RX, the test stops due to no response from the wifi.
    //The wifi fails to wake up when we ping it from another device on the network.
    //If we ping from the host side to another device, it usually wakes up immediately.
    //The following Log is printed using WLAN_OS_REPORT() from the following the source files.
    // DRIVERS\WILINK\TWD\MacServices\PowerSrvSM.c
    // DRIVERS\WILINK\TWD\MacServices\PowerSrv.c
    //In the log, the Event numbers are as defined in PowerSrvSMEvents_e
    // the States are defined as in PowerSrvSMStates_e
    static TI_STATUS powerSrvSmSMEvent(TI_UINT8* pCurrentState,
    TI_UINT8 event,
    TI_HANDLE hPowerSrvSM)
    PowerSrvSM_t *pPowerSrvSM = (PowerSrvSM_t*)hPowerSrvSM;
    TI_STATUS status = TI_OK;
    TI_UINT8 nextState;
    status = fsm_GetNextState((fsm_stateMachine_t*)pPowerSrvSM->hFSM,
    (TI_UINT8)pPowerSrvSM->currentState,
    event,
    &nextState);
    if ( status != TI_OK )
    TRACE0(pPowerSrvSM->hReport, REPORT_SEVERITY_SM, "PowerSrvSM - State machine error, failed getting next state\n");
    return(status);
    WLAN_OS_REPORT(("***powerSrvSmSMEvent(): Event=%d, State %d -> %d\r\n", event, pPowerSrvSM->currentState, nextState));
    TRACE3( pPowerSrvSM->hReport, REPORT_SEVERITY_INFORMATION, "powerSrvSmSMEvent: <currentState = %d, event = %d> --> nextState = %d\n", *pCurrentState, event, nextState);
    status = fsm_Event(pPowerSrvSM->hFSM,
    pCurrentState,
    event,
    (void*)pPowerSrvSM);
    return status;
    static void powerSrv802_11PsReport(TI_HANDLE hPowerSrv, char* str , TI_UINT32 strLen)
    powerSrv_t * pPowerSrv = (powerSrv_t*)hPowerSrv;
    TI_UINT8 PowerSaveStatus;
    E80211PsMode currentPsMode;
    /*copy the event*/
    os_memoryCopy(pPowerSrv->hOS, (void *)&PowerSaveStatus, (void *)str, strLen);
    TRACE1( pPowerSrv->hReport, REPORT_SEVERITY_INFORMATION, "PS callback with status: %d\n", PowerSaveStatus);
    /* Handling the event*/
    switch ( (EventsPowerSave_e)PowerSaveStatus )
    case ENTER_POWER_SAVE_FAIL:
    case EXIT_POWER_SAVE_FAIL:
    TRACE0( pPowerSrv->hReport, REPORT_SEVERITY_WARNING, "Power save enter or exit failed!\n");
    WLAN_OS_REPORT(("***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=%d\r\n", PowerSaveStatus));
    powerSrvSM_SMApi(pPowerSrv->hPowerSrvSM,POWER_SRV_EVENT_FAIL);
    break;
    case ENTER_POWER_SAVE_SUCCESS:
    case EXIT_POWER_SAVE_SUCCESS:
    //Remaining code omitted....
    //In the log, the Event is PowerSrvSMEvents_e and the State is
    //PowerSrvSMStates_e as defined below
    typedef enum
    POWER_SRV_EVENT_REQUEST_ACTIVE = 0,
    POWER_SRV_EVENT_REQUEST_PS = 1,
    POWER_SRV_EVENT_SUCCESS = 2,
    POWER_SRV_EVENT_FAIL = 3,
    POWER_SRV_SM_EVENT_NUM = 4
    }PowerSrvSMEvents_e;
    typedef enum
    POWER_SRV_STATE_ACTIVE = 0,
    POWER_SRV_STATE_PEND_PS = 1,
    POWER_SRV_STATE_PS = 2,
    POWER_SRV_STATE_PEND_ACTIVE = 3,
    POWER_SRV_STATE_ERROR_ACTIVE= 4,
    POWER_SRV_SM_STATE_NUM = 5
    }PowerSrvSMStates_e;
    typedef enum
    ENTER_POWER_SAVE_FAIL = 0,
    ENTER_POWER_SAVE_SUCCESS = 1,
    EXIT_POWER_SAVE_FAIL = 2,
    EXIT_POWER_SAVE_SUCCESS = 3,
    POWER_SAVE_STATUS_NUMBER
    } EventsPowerSave_enum;
    1. Chariot Test Log - RX, script is filesndl.scr
    TIWLAN: 12374.116: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12374.144: ***powerSrvSmSMEvent(): Event=1, State 1 -> 1 ??
    TIWLAN: 12374.149: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12374.151: ***powerSrvSmSMEvent(): Event=1, State 2 -> 2
    TIWLAN: 12381.991: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12381.993: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12382.079: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12382.083: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 12382.088: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 12382.105: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12382.128: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12382.400: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    ////////// DELETED SOME LOG HERE //////////////
    TIWLAN: 12398.794: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12399.091: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12399.093: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12399.323: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12399.324: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12399.353: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12399.353: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12399.363: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 12399.368: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 12399.385: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 12399.387: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12399.565: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12399.589: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12460.526: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12460.528: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12460.802: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12460.807: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 12460.811: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 12460.817: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 12460.866: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12460.890: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12461.246: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12461.247: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12491.093: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12491.115: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12491.245: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12491.248: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12493.405: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12493.406: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1 ??
    TIWLAN: 12493.435: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12493.435: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12493.443: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12493.469: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12493.472: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1 ??
    TIWLAN: 12493.492: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12493.492: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12493.500: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12493.575: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12493.597: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12493.911: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12493.914: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12497.465: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12497.466: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1 ??
    TIWLAN: 12497.495: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12497.496: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12497.502: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12670.241: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12673.309: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12673.330: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12673.335: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12673.336: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12673.355: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12673.373: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12673.411: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12673.926: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12673.927: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12673.975: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12673.998: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12674.125: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12674.130: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12675.012: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12675.029: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 12675.032: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 12675.038: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 12675.081: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12675.112: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12675.252: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12675.262: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12675.293: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12675.317: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12675.877: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12675.881: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12675.926: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12675.951: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12676.071: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12676.073: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12676.114: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12676.137: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12676.302: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12676.316: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12676.345: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12676.371: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12676.686: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12676.692: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 12676.695: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 12676.712: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 12676.720: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12676.729: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12676.764: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12686.108: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12691.657: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12691.657: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12691.685: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12691.685: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12691.696: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12693.770: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12693.772: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12693.800: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12693.800: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12693.811: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 12693.815: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 12693.831: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 12693.834: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12693.970: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12693.976: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12693.996: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12693.996: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12719.658: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12719.795: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12719.797: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12721.992: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12722.015: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12722.355: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12722.360: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 12722.364: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 12722.381: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 12722.384: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12722.413: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12782.564: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12782.566: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12788.060: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12788.061: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12788.092: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12788.092: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12788.101: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12788.104: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12788.133: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12788.298: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12788.318: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 12788.321: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 12788.338: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 12788.344: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12794.732: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12794.734: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12794.754: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12794.754: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12794.761: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12840.596: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12840.725: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12840.727: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12843.056: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12843.090: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12843.387: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12843.403: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 12843.406: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 12843.423: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 12843.429: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12843.435: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12843.468: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12844.209: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12844.210: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12858.487: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12858.489: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12858.509: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12858.509: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12858.530: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 12858.544: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 12858.547: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 12858.553: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 12858.560: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12858.581: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12858.581: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12858.590: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12858.602: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12858.636: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12858.952: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12858.953: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12859.002: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12859.024: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12859.164: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12859.175: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12859.213: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12859.240: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12859.363: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12859.365: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12860.679: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12860.703: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12860.795: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12860.797: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12860.848: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12860.882: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12861.005: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12861.006: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12861.059: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12861.081: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12861.204: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12861.207: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12862.441: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12862.442: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12862.451: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 12862.456: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 12862.462: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 12864.353: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12864.357: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12864.375: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12864.375: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12864.387: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12864.417: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12864.449: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12864.997: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12864.998: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12865.911: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12865.927: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 12865.930: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 12865.947: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12865.972: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12866.635: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12866.636: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12866.693: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12932.817: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12933.398: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12933.399: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12933.447: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12933.469: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12933.599: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12933.600: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12935.543: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12935.544: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12935.553: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 12935.558: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 12935.563: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 12956.790: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12956.792: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12956.814: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12956.814: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12956.824: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 12956.828: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 12956.835: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 12956.840: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 12956.869: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12956.869: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12956.881: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12956.883: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12956.910: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12957.461: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12957.462: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12957.519: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12957.545: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12957.662: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12957.666: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12958.768: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12958.781: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 12958.784: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 12958.801: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 12958.828: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 12958.851: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 12958.862: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 12958.896: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13151.712: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13151.754: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13151.779: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13151.909: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13151.910: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13151.965: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13151.971: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13151.974: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13151.985: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13154.796: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13154.820: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13154.980: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13154.986: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13155.028: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13155.051: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13155.597: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13155.599: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13256.340: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13256.456: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13256.464: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13256.550: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13256.575: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13256.660: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13256.664: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13256.669: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13256.686: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13256.689: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13269.983: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13270.008: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13270.177: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13270.179: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13348.002: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13348.003: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13348.061: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13348.083: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13348.203: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13348.207: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13352.179: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13352.185: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13352.188: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13352.205: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13352.231: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13352.297: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13352.298: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13352.348: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13366.941: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13366.965: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13367.561: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13367.565: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13368.279: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13368.285: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13368.288: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13368.294: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13368.447: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13368.447: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13368.475: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13377.221: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13377.244: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13377.806: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13377.809: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13377.856: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13377.863: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13377.866: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13377.883: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13377.907: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13378.000: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13378.002: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13378.112: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13378.130: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13378.138: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13378.138: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13378.145: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13378.176: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13378.198: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13378.308: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13378.310: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13378.366: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13378.366: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13378.388: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13378.388: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13378.396: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13378.409: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13378.433: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13378.824: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13378.826: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13380.249: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13380.275: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13380.278: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13380.295: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13380.306: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13380.309: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13380.317: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13380.358: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13380.362: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13380.382: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13382.204: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13382.297: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13382.298: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13382.354: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13382.376: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13382.717: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13382.720: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13382.775: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13382.798: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13382.915: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13382.916: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13383.536: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13383.537: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13383.542: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13383.551: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13383.557: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13383.585: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13383.607: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13383.611: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13383.613: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13383.621: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13429.201: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13429.202: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13429.253: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13429.276: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13429.403: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13429.406: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13430.354: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13430.359: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13430.363: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13430.371: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13430.461: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13430.462: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13430.483: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13469.334: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13476.182: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13476.203: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13476.207: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13476.209: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13476.215: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13476.245: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13476.246: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13476.255: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13476.260: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13476.266: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13476.315: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13476.341: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13476.715: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13476.716: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13494.394: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13495.068: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13495.069: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13495.099: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13495.099: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13495.106: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13502.759: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13502.759: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13502.780: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13502.783: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13502.789: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13503.601: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13503.630: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13503.633: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13503.636: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13503.659: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13503.662: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13503.679: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13503.686: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13503.689: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13503.704: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13503.723: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13503.723: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13503.741: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13503.756: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13503.772: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13503.775: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13503.792: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13503.819: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13504.364: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13504.368: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13504.421: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13504.443: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13504.563: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13504.565: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13551.520: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13551.542: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13551.665: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13551.667: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13551.967: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13551.968: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13551.977: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13551.982: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13551.988: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13552.036: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13552.070: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13552.384: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13552.387: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13552.606: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13552.629: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13553.204: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13583.187: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13583.205: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13583.205: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13583.211: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13583.308: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13583.308: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13583.320: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13583.323: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13583.329: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13583.357: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13583.381: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13583.924: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13583.925: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13583.967: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13583.990: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13584.125: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13584.126: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13584.705: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13584.710: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13584.730: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13584.730: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13584.741: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13584.769: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13584.791: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13585.357: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13585.360: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13585.865: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13585.866: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13585.894: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13585.894: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13585.906: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13585.909: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13585.926: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13585.930: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13585.935: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13585.942: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 13585.948: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13585.979: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13585.979: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13585.988: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13602.354: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13602.367: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13602.390: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13604.197: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13604.199: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13605.679: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13605.689: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13605.690: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13605.698: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13605.704: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13605.732: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13605.755: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13606.552: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13692.768: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13692.779: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13692.822: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13692.844: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13693.590: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13693.592: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13693.634: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13693.649: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13693.652: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13693.669: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13693.699: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13693.792: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13693.798: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13693.919: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13693.920: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13693.947: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13693.947: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13693.955: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13693.962: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13693.990: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13694.101: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13694.102: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13694.154: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13694.182: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13694.320: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13694.324: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13694.786: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13694.819: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13694.914: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13694.921: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13694.924: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13694.941: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13694.944: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13694.955: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13694.957: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13694.977: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13694.977: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13694.985: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13694.998: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13695.001: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13695.021: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13695.021: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13695.029: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13695.062: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13695.087: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13695.436: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13695.438: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13695.632: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13695.668: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13695.745: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13695.748: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13695.801: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13695.807: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13695.810: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13695.818: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13695.971: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13695.996: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13696.357: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13696.386: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13696.413: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13696.435: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13696.556: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13696.558: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13696.647: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13696.670: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13696.761: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13696.772: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13696.815: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13696.845: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13696.848: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13696.851: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13696.859: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13696.922: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13696.958: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13697.692: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13697.693: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13697.746: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13697.780: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13697.887: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13697.901: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13697.979: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13698.006: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13698.297: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13698.298: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13698.358: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13698.382: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13698.389: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13698.389: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13698.409: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13698.412: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13698.429: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13698.434: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13698.443: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13698.472: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13698.617: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13698.619: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13698.675: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13698.700: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13698.809: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13698.811: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13698.908: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13698.931: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13699.219: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13699.221: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13699.331: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13699.354: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13699.943: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13699.945: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13700.004: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13700.037: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13700.140: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13700.142: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13700.320: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13700.347: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13700.652: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13700.654: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13700.701: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13700.729: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13700.867: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13700.869: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13700.958: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13700.982: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13702.102: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13702.104: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13702.145: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13702.169: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13702.287: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13702.289: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13702.330: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13702.331: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13702.359: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13702.359: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13702.367: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13702.379: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13702.401: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13702.406: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13702.408: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13702.506: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13702.537: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13703.112: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13703.115: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13703.162: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13703.184: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13703.315: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13703.317: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13703.609: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13703.636: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13705.779: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13705.780: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13705.822: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13705.844: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13705.977: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13705.979: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13706.105: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13706.107: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13706.128: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13706.128: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13706.136: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13706.148: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13706.149: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13706.170: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13706.170: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13706.178: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13706.191: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13706.210: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13706.216: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13706.216: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13706.238: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13706.255: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13706.258: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13706.277: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13706.277: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13706.284: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13706.510: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13706.510: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13706.538: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13706.538: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13706.546: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13706.552: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13706.556: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13706.584: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13706.584: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13706.594: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13706.619: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13706.646: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13706.817: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13706.822: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13707.672: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13707.705: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13709.872: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13709.874: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13709.916: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13709.938: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13710.073: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13710.077: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13710.452: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13710.470: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13710.473: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13710.490: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13710.525: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13710.529: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13712.892: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13713.042: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13713.044: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13713.719: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13713.747: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13714.686: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13714.690: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13714.730: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13714.752: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13714.885: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13714.886: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13714.970: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13715.011: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13715.109: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13715.111: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13715.160: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13715.160: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13715.169: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13715.175: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13715.180: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13715.208: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13715.231: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13715.397: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13715.398: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13715.440: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13715.563: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13715.566: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13715.583: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13715.620: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13716.051: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13716.052: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13746.629: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13746.677: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13746.703: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13747.470: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13747.480: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13747.513: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13747.529: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13747.532: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13747.549: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13747.585: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13747.651: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13747.657: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13756.924: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13756.948: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13757.072: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13757.081: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13757.114: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13757.130: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13757.133: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13757.139: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13757.188: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13757.200: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13757.217: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13757.217: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13757.225: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13757.252: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13757.274: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13757.388: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13757.389: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13757.442: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13757.467: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13757.584: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13757.588: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13757.633: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13757.637: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13757.657: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13757.657: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13757.665: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13757.697: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13757.704: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13757.707: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13757.724: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13757.749: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13757.891: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13757.894: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13758.016: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13758.038: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13784.267: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13784.290: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13784.414: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13784.418: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13784.499: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13784.509: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13784.528: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13784.528: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13784.557: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13784.560: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13784.566: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 13784.572: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13784.601: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13784.601: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13784.613: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13784.614: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13785.010: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13785.010: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13785.021: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13785.044: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13785.069: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13785.072: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13785.085: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13785.129: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13785.130: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13785.158: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13785.158: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13785.166: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13805.917: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13805.930: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13805.960: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13805.964: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13805.984: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13805.984: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13806.004: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13806.007: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13806.013: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 13806.029: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13806.032: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13806.039: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13806.151: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13806.176: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13806.324: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13806.326: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13806.415: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13806.416: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13806.455: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13806.455: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13806.461: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 13806.484: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13817.631: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13817.654: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13831.936: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13831.938: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13831.979: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13832.004: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13832.128: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13832.138: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13832.141: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13832.158: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13832.169: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13832.170: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13832.175: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13832.224: ***powerSrvSmSMEvent(): Event=1, State 1 -> 1
    TIWLAN: 13832.224: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13832.230: ***powerSrvSmSMEvent(): Event=1, State 2 -> 2
    TIWLAN: 13832.538: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13832.545: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13832.581: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13832.596: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13832.599: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13832.616: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13832.647: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13832.970: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13832.984: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13833.014: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13833.040: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13833.152: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13833.173: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13833.176: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13833.193: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13833.204: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 13833.206: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13833.213: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13833.219: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 13833.236: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13833.239: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13833.256: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13833.281: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13833.583: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13833.609: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13833.627: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13833.655: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13833.767: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13833.772: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13833.810: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13833.834: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13834.184: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13834.185: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13834.227: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13834.229: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13834.249: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13834.249: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13834.274: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13834.277: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13834.304: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13834.307: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13834.313: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13834.362: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13834.369: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13834.372: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13834.389: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13834.419: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13835.923: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13835.925: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13835.966: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13835.989: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13839.413: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13839.416: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13839.456: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13839.480: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13839.603: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13839.604: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13839.646: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13839.677: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13839.829: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13839.831: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13839.873: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13839.885: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13839.888: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13839.895: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13839.943: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13839.943: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13839.974: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13839.974: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13839.985: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13839.992: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13839.992: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13840.020: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13840.020: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13840.027: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13840.035: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13840.038: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13840.065: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13840.065: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13840.073: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13840.080: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13840.086: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13840.106: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13840.106: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13840.125: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13840.128: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13840.145: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13840.146: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 13840.152: ***powerSrvSmSMEvent(): Event=0, State 3 -> 3
    TIWLAN: 13840.158: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13840.163: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13840.237: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13840.247: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13840.263: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13840.263: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13840.273: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    ////////// DELETED SOME LOG HERE //////////////
    TIWLAN: 13848.581: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13848.592: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13848.614: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13848.614: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13848.633: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13848.635: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13848.668: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13848.845: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13848.853: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13848.856: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13848.873: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13848.879: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13848.889: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13848.921: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13849.042: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13849.044: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13849.085: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13849.108: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13849.234: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13849.265: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13849.268: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13849.277: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 13849.315: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13849.318: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13849.331: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13849.374: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13849.374: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13867.427: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13867.427: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13867.445: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 13867.457: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13867.457: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13867.482: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13867.485: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13867.502: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13867.530: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13867.566: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13867.569: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13867.693: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13867.716: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13867.865: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13867.868: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13867.906: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13867.908: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13867.928: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13867.928: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13867.942: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13867.949: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13867.975: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13867.978: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13867.993: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 13868.034: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13868.034: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13868.077: ***powerSrvSmSMEvent(): Event=1, State 1 -> 1
    TIWLAN: 13868.090: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13868.090: ***powerSrvSmSMEvent(): Event=1, State 2 -> 2
    TIWLAN: 13868.291: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13868.304: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 13868.307: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 13868.324: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 13868.329: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13868.335: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13868.360: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13868.491: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13868.500: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13868.547: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13868.572: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13868.706: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13868.707: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13868.758: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13868.786: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13868.789: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13868.806: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13868.841: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13868.889: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13868.903: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13868.948: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13982.882: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13982.890: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13983.110: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13983.110: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13983.139: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13983.139: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13983.149: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13983.153: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13983.176: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 13983.179: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13983.182: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13983.189: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13983.494: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13983.530: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13983.533: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13983.550: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13983.558: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 13983.561: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 13983.578: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13983.608: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 13983.681: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 13983.682: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 13983.736: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 13983.758: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14054.150: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14054.158: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14054.173: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14054.173: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14054.180: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14054.382: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14054.389: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14054.392: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14054.409: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14054.411: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14054.432: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14054.432: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14054.447: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14054.467: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14054.468: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14054.489: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14054.489: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14054.497: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14054.510: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14054.537: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14054.553: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14054.555: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14054.599: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14054.681: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14054.704: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14054.718: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14054.747: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14054.796: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14054.815: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14054.815: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14054.854: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 14054.862: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14054.862: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14054.923: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14054.999: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14055.022: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14055.045: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14055.076: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14056.279: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14056.280: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14056.322: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14056.344: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14056.480: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14056.481: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14057.642: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14057.661: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14057.664: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14057.675: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 14057.799: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14057.836: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14057.926: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14057.935: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14057.968: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14057.990: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14058.536: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14058.538: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14104.519: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14104.556: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14104.575: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14104.593: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14104.593: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14104.610: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 14104.613: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 14104.621: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 14104.625: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14104.650: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14104.650: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14104.658: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14104.678: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14104.709: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14104.807: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14104.809: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14104.850: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14104.850: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14104.878: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14104.878: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14104.893: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14104.899: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14104.903: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14104.908: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14104.925: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14104.952: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14116.087: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14116.091: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14116.571: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14116.571: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14116.600: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14116.600: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14116.606: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14116.613: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14116.640: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14117.222: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14117.225: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14117.272: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14117.300: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14117.611: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14117.614: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14117.696: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14117.697: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14117.717: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14117.720: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14117.726: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 14117.754: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14117.755: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14117.783: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14117.783: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14117.791: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14117.797: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14117.801: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14117.823: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14117.823: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14117.841: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14117.843: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14117.847: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14117.876: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14117.876: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14117.884: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14117.890: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14117.894: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14117.929: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14117.929: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14117.935: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 14117.941: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14117.946: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14117.976: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14119.164: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14119.172: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 14119.176: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 14119.192: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 14119.207: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 14119.211: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14119.213: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14119.245: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14119.369: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14119.373: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14119.412: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14119.435: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14119.557: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14119.560: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14119.684: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14119.684: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14119.706: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14119.706: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14119.727: ***powerSrvSmSMEvent(): Event=1, State 3 -> 3
    TIWLAN: 14119.728: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 14119.736: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 14119.742: ***powerSrvSmSMEvent(): Event=1, State 4 -> 1
    TIWLAN: 14119.748: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14119.780: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14119.780: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14119.789: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14119.792: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14119.798: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14119.827: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14119.827: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14119.834: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14119.839: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14119.845: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14119.875: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14119.878: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14119.884: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 14119.890: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14119.918: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14217.186: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14217.426: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14217.439: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14217.451: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14217.451: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14217.460: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14217.490: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14217.502: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14217.505: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14217.522: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14217.546: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14217.656: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14217.658: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14217.705: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14217.714: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14217.717: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14217.734: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14217.758: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14218.072: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14218.074: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14218.126: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14218.141: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14218.145: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14218.161: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14218.163: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14218.184: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14218.184: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14218.192: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14218.218: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14231.648: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14231.861: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14231.867: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14231.920: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14231.936: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14231.939: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14231.957: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14231.979: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14233.945: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14233.948: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14233.988: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14234.010: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14234.139: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14234.143: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14234.245: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14234.272: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14235.067: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14235.071: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=2
    TIWLAN: 14235.076: ***powerSrvSmSMEvent(): Event=3, State 3 -> 4
    TIWLAN: 14235.093: ***powerSrvSmSMEvent(): Event=0, State 4 -> 3
    TIWLAN: 14235.096: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14235.108: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14235.130: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14235.241: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14235.244: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14235.378: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14235.393: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14235.396: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14235.413: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14235.436: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14235.572: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14235.577: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14235.613: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14237.614: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14237.641: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14237.665: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14237.825: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14237.826: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14237.916: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14237.940: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14242.141: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14242.147: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14242.628: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14242.637: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14242.640: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14242.657: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14242.691: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14243.569: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14243.571: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14243.681: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14243.694: ***powerSrvSmSMEvent(): Event=0, State 1 -> 1
    TIWLAN: 14243.713: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14243.713: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14243.723: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14243.747: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14243.770: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14243.867: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14243.870: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14243.916: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14243.938: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14245.317: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14245.320: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14245.360: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14245.391: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14245.710: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14245.715: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14245.753: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14245.765: ***powerSrv802_11PsReport(): Power save enter or exit failed! PowerSaveStatus=0
    TIWLAN: 14245.768: ***powerSrvSmSMEvent(): Event=3, State 1 -> 0
    TIWLAN: 14245.780: ***powerSrvSmSMEvent(): Event=0, State 0 -> 0
    TIWLAN: 14245.823: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14245.849: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    # Now the firmware is in sleep atate and won't wake up.
    # Chariot test on RX stopped due to no response from STA.
    # Pinged to the STA from laptop 12 times and all timed out.
    # Pinged from the STA to laptop and succeeded on the first ping
    # This is usually the csae that we can wake the chipset up from the
    # host side, but fails from the remote device on the network.
    TIWLAN: 14681.439: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14681.441: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14681.482: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14681.507: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14682.432: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14682.435: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14682.475: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14682.498: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14683.455: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14683.459: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14683.498: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14683.521: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
    TIWLAN: 14684.480: ***powerSrvSmSMEvent(): Event=0, State 2 -> 3
    TIWLAN: 14684.483: ***powerSrvSmSMEvent(): Event=2, State 3 -> 0
    TIWLAN: 14684.524: ***powerSrvSmSMEvent(): Event=1, State 0 -> 1
    TIWLAN: 14684.548: ***powerSrvSmSMEvent(): Event=2, State 1 -> 2
     ------------------ END -------------------------------------------------------------------------------
  • Hello Sinoj,
    Could you send me the power save related settings you use on your device? I mean the settings from the .ini file. I'd like to see if there are any differences.
    I am using PS Auto mode with ELP.
    Thank you,
    Tiegang
    Attached is the tiwlan.ini file.
    Sinoj
    tiwlan.ini
  • Sinoj,
    Thank you for sending me ther file. I've checked mine against yours. I don't see any problems with the settings for power management.
    TL
  • TL,
    Can you please advise if the various tests mentioned in this thread were run with the Lunux Release from TI or the one ported to WINCE?
    Adnan
  • Adnan,
    The tests were done to the ported WinCE6 driver based on the WL6.1.6.3 release.
    Also, I'd like to know what workaround on the host side I can do to address the following issue as mentioned in your latest release notes,
    Constraints and Limitations
    Hardware Limitations In some cases, the WL127x device may fail to wake up when receiving a host request because of a timing issue in the POR module. The host driver should contain implementation to work around this issue
    Constraints
    This release has the following constraints:
    • Configuration of short/long doze with N*Beacon or N*DTIM may lead to application failure when the sleep time is compared to the application protocol expiration time.
    Thanks for your help.
    Tiegang
    3365.PacketCapture.zip
    Please analyze the attached packet captures.
    *** AP SETUP:
    Netgear MBR624GU, g-mode only, WPA2-PSK/AES, WMM enabled, BeaconPeriod =100. MAC Address: 00:24:B2:09:A0:07
    DHCP enabled. This is the only AP connected to the network.
    *** STA SETUP:
    WinCE6 device, The latest M6 driver, AC powered with no CPU PS. No BT or FM enabled on hardware. WL1271 in power save mode.
    N*BEACON and N*DTIM both set to 1. MAC Address: 00:04:A3:33:99:67
    *** AeroPeek v2.0.2:
    Captured packets from and to both physical addresses. Beacons with TIM information set also captured.
    *** Test Findings:
    Leave the STA in idele for a while. Ping STA continously from laptop. You will see that STA does not respond to the beacons with TIM's Bitmap Offset set. And the first few pings (up to 7 pings)  time out. The STA eventually wakes up. This can be seen from the captured packets attached.
    Please help!
    Tiegang
  • Tiegang,
    We will go through the sniffer logs and get back to you on e2e. Thanks.
    Saurabh
  • Saurabh,
    We have been struggling with this issue for a long time and really need your help to have it resolved asap.
    Thanks for help.
    Tiegang
  • Tiegang,
    Please elaborate the issue and mention the packet numbers on the sniffer trace  - especially the specific beacons and ping frames that are you want to focus on. Do you see the same issue with no security? Thanks
    Saurabh
  • Saurabh,
    Let's pick a smaller file from my log, ttmvrb-ps-ping-beacon-capture-004.apc.
    The beacon packet #811 is the one I see when I started the ping session. Beacon packets 814, 815, 818, 819 are from additional four pings which all got timed out. So for this ping session, first five pings got all timed out. Those five beacons are corresponding to the five missed pings. Packet 823 is the first successful ping response which is for the sixth ping.
    I remebmber that the same issue was seen when I was testing without security.
    Tiegang
  • Saurabh,
    Just FYI.
    All the captures are from pingning from a laptop to the station. The beacon packets captured are the ones with TIM's Bitmap offset (Bitmap control) or Virtual bitmap bit/bits set. Other beacons have already filtered out. I am not sure why the station doesn't respond to those multicast beacons.
    Tiegang
  • Tiegang
    Station AID is 7 (as per sniffer capture you mentioned).  For beacon packets you stated - 811 814, 815, 818, 819 - None of these indicate traffic for AID 7 i.e. TI station. Ping is a unicast frame. Station will not send PS POLL unless AP has data for it. Beacon 826 indicates data for AID 7 and station does PS handshake in subsequent packets.
    I did notice "more data" bit set in some packets sent from AP to station  ex: 892 indicating AP might be buffering more data - which is ok because station is in PS mode. Capture all beacons and see if station does not respond to the beacons in scenarios where beacon indicates traffic for station. If beacons fail to show traffic for particular AID, then it could be an AP issue.
    Saurabh
  • Saurabh,
    Thanks a lot for looking into the log.
    It seems odd that those 5 beacons were indeed from each ping. They all have the TIM bitmap control bit set but have no virtual bitmap set. Is it the case that WL1271 will treat those as regular beacons? Aren't those beacons tell that there are multicast frames buffered by the AP?
    I will capture more packets with all the beacons so you can help me to investigate why the station always misses the first few pings. By the way, I don't see this problem when power saving feature is disabled.
    Tiegang
  • Tiegang,
    Ping frame is a unicast frame and in case AP has buffered ping frames, TIM in beacons sent by AP should specific unicast traffic for that particular station (AID). It has nothing to do with multicast traffic.Yes, if the least significant bit in Bitmap control is set, it means AP has buffered multicast traffic buffered.
    Saurabh
  • Hi, Saurabh,
    Here are another two captures. Please help to analyze the problem.
    3603.PacketCapture.zip
     Test Setup:
    AP: Netgear MBR624GU, DHCP enabled, NO Security, Channel 6, g-mode only, WMM enabled. MAC 00:24:B2:09:A0:07, IP address 172.95.1.1
    WL1271 power save mode enabled. MAC 00:04:A3:2F:B9:8E, IP address 172.95.1.3.
    Laptop wire-connected to AP, MAC 00:18:8B:AD:30:4C, IP address 172.95.1.2
    I pinged the station from laptop. The packets of 500 (434 + 66) bytes are the ping packets.
    I looked into the capture file ttmvrb-ps-no-sec-ping-beacon-capture-017.apc, and found that following:
    Start ping: ping 172.95.1.3 -t -l 434
    Pkt# 5010: Laptop sent ARP Request (no response from the station.)
    Pkt# 5118: Laptop sent ARP Request (no response from the station.)
    Pkt# 5235: Laptop sent ARP Request (no response from the station.)
    Pkt# 5347: Laptop sent ARP Request  (*** station reply to the ARP request, but this was almost 20 seconds passed)
    After let the station idle for a while, started another ping session.
    Pkt# 19127: Laptop sent ARP Request (no response from the station.)
    Pkt# 19217: Laptop sent ARP Request (no response from the station.)
    Pkt# 19319: Laptop sent ARP Request (Station responded to the ARP request and ping went through.)
    So what is causing the station not to respond to the ARP requests?
    I do have ARP filtering feature disabled (ArpIp_Filter_ena set to 0), and ARP IP address to zeros (ArpIp_Addr set to 00 00 00 00).
    Please Help.
    Tiegang
  • Saurabh,
    Have you got a chance to look into the captured packets yet?
    4571.FullPower_PacketCapture.zip
    I've attached another capture when WL1271 is running in full power mode. You will see that WL1271 sent out ARP response (packet# 132) immediately after the laptop requested for (packet# 131). The ping request (packet# 134) and reply (packet# 136) went through as expected.
    Unless the firmware was purposely configured for not receiving ARP requests under power saving mode, the cause could mostly be that the chipset failed to wakeup for receiving.
     Please help.
    Tiegang
    Has anyone looked into my previous two posts yet?
    Could you please let me know if my problem is caused by incorrect firmware configuration or the power saving mode?
    Thank you,
    Tiegang
  • Hello?
    I've been waiting for two weeks since I last posted my support requests. I really need you guys' help to have this issue resolved ASAP. Our mass production got stopped by this problem and we can't afford waiting any longer like this.
    Please respond and help us out. The information we provided (posted here) on April 27th and 28th may help you to investigate the cause.
    Tiegang
  • Hi  Tiegang,
    I am currently reviewing the thread, and respond in couple of hours after I understand what the issue is
    Eyal
  • Hi Tiegang,
    I can see from the sniffer similar things to your observation, we can see that the beacon before the ARP request frame always is DTIM beacon, that is DTIM count equal 0 and also indicates that group frame is buffered at the AP, and then immediately after (around 110-140uSec) send the ARP request frame, so in that case the Station wakes for that beacon and should stay awake to receive the ARP request frame.
    In addition based on the ini file I see the following:
    RxBroadcastInPs = 1 that is enables receive of broadcast packets in Power-Save mode
    ARP filter is disabled
    The station is waking up every Beacon so that should be the safe way to work to reduce the delay time.
    So based on all the conditions the Station had to wake up and respond to the ARP request and currently I don’t have a good idea what can be the issue.  I will consult some colleague tomorrow morning in order to debug that issue
    Eyal
