LAUNCHCC3220MODASF: sl_Select() function timeout issue
Part Number: LAUNCHCC3220MODASF
Other Parts Discussed in Thread: CC3220MOD
Regarding CC3220MOD driver, We found sl_Select() timeout function does not work correctly.
C:\ti\simplelink_sdk_wifi_plugin_2_40_00_22\source\ti\drivers\net\wifi
sl_socket.c
static _i8 _i16 sl_Select(void)
_i16 sl_Select(_i16 nfds,
SlFdSet_t *readsds,
SlFdSet_t *writesds,
SlFdSet_t *exceptsds,
struct SlTimeval_t *timeout) {
(ellipsis)
/* this divides by 1024 to fit the result in a int16_t.
* Upon receiving, the NWP multiply this value by 1024. */
timeout->tv_usec = (timeout->tv_usec >> 10); <------ (A)
if(0xffff <= timeout->tv_usec)
Msg.Cmd.tv_usec = 0xffff;
else
Msg.Cmd.tv_usec = (_u16)timeout->tv_usec;
(ellipsis)
ret = _SlDrvRegisterForSelectAsync(&SelectParams, &Msg, timeout,
SelectInProgress);
(ellipsis)
At the <-----(A) point, 10bit right shift is executed for "timeout" itself.
This will affect to the following <------(B) point in _SlDrvRegisterForSelectAsync()  functioon,
static _i16 _SlDrvRegisterForSelectAsync(_SlSelectEntry_t* pEntry,
_SlSelectMsg_u* pMsg,
struct SlTimeval_t *timeout,
_u8 SelectInProgress) {
(ellipsis)
if((pMsg->Cmd.tv_sec != 0xFFFF) && (timeout != NULL))
pEntry->TimeStamp = to_mSec(timeout); <------(B)
else
pEntry->TimeStamp = SELECT_NO_TIMEOUT;
(ellipsis)
static __INLINE _u32 to_mSec(struct SlTimeval_t* timeout) {
return (((slcb_GetTimestamp() /
SL_TIMESTAMP_TICKS_IN_10_MILLISECONDS) *
10) + (timeout->tv_sec * 1000) + (timeout->tv_usec / 1000)); <------(B) }
Because timeout -> tv_usec was 10 bit shifted already, TOT will be set as almost 0msec if TOT is less than 1sec.
If we did not modify "timeout" itself at  <------(A) , but change like as sg.Cmd.tv_usec = (_u16)(timeout->tv_usec >> 10);
Then it seems the function seems to work well.
Please review these changes.
Regards, A.Fujinaka
