CC3200STK-WIFIMK: Not able to get data form sensor tag
Part Number: CC3200STK-WIFIMK
Sensor tag is not giving data after connection. it connects to and starts provisioning for long time without any further response what i do.
  • Hi Dheeraj,
    If you run the demo in AP mode instead of trying to connect it to an AP as a station, do you get data?
    What is your goal with the Sensor Tag? It is only intended to be used as a demo and is not a development platform. It can't be reprogrammed and source code is not available.
    If you intend to do development, I recommend you move to the CC3220 or CC3235 LaunchPad. We have a software example application that is designed to be similar in function to the sensortag in the Sensor and Actuator Plug-in here and it can be used for development (go to Examples\Development Tools\CC3220x LaunchPad\SAIL\mqtt_sensor):
    http://dev.ti.com/tirex/explore/node?node=AFSrQICgvevFxy6Dv4Qy-Q__swcUKHN__LATEST
    Ben M
