Other Parts Discussed in Thread: CC3120MOD
Hi TI experts,
My customer is developing with CC3120MOD.
I received an inquiry from them about the suspension of mDNS, therefor could you please confirm it?
Calling sl_NetAppStop (SL_NETAPP_MDNS_ID) while mDNS is stopped will result in an incorrect return value (positive value, 6023).
Positive values are not defined in error.h.
The Host Driver API documentation also defines the return value as zero or negative.
They are using the SimpleLink SDK WiFi Plugin v2.40.00.22.
Does this issue occur with this version?
Is there a workaround in this version?
Does the latest version fix this issue?
Thank you.
Yojiro
