CC3220S-LAUNCHXL: Correct Reset Pin Configuration/Layout
Part Number: CC3220S-LAUNCHXL
Hi There,
Just wanted to verify I am laying the CC3220MODAS module out correctly. I previously had a switch wired up to a reset button but I no longer need that. Per the datasheet, I am leaving RESET floating and connecting VBAT_RESET to VCC_BRD.
Is this correct? Picture attached. Note, I am also connecting the reset pin to a JTAG connector for debugging. It's just not tied to a signal when the debugger isn't connected.
Also note: the schematic says it's a MODASF, but it will be a MODAS -- my understanding is they are pin for pin compatible.
Thanks!
