Hi, TI.
I would like to use RF transceiver mode in Non OS mode.
Can you provide me a guide for using the radioTool_TxStart()/radioTool_RxStart() function in radio_tool.c in Non OS?
Thank you in advance.
Simon
Hi, TI.
Simon
Hi Simon,
I recommend you use the power_measurement example and copy over the radiotool code that you wish to use.
So, first you'd import the power_measurement nortos example from the SDK, then copy over the radiotool.c/.h files, correct any build errors from missing import paths/ struct defines, and then use the function in one of the power measurement test cases.
You could also try migrating the network_terminal example to nortos using an existing nortos demo as a guide, but it would probably be easier to copy over the functionality you want to use to a networking-enabled nortos example. The power_measurement demo would be easiest to adapt.
Michael
