Other Parts Discussed in Thread: CC3100
My customer is getting an error -100 when trying to connect in secure more. Socket.h does not have that error code - could you please describe it and tell me when it should be expected?
Thank you!
Thank you!
Hi Ben,
here is the code snippet along with the comment on where the error is returned - thank you!
if (status == 0)
status = connect(tmpSkt, (struct sockaddr *)&address, sizeof(address)); <<< -100 is returned by connect() API
if (status < 0)
returnStatus = WIFI_PLATFORM_STATUS_SOCKET_CONNECT_FAILURE;
if (tmpSkt >= 0)
if(status == SL_ESEC_ASN_SIG_CONFIRM_E)
returnStatus = WIFI_PLATFORM_STATUS_SOCKET_CERTVALIDATION_FAILURE;
close(tmpSkt);
else
*skt = tmpSkt;
Hi Lenio,
The use case looks ok from what I can see. This makes me think that the CC3100 and the host are just getting out of sync, which could be caused by a problem with the host interface itself.
Does this happen every time the code is run?
What type of interface is being used?
Ben
