Other Parts Discussed in Thread: CC3220SF
Using: simplelink_cc32xx_sdk_1_50_00_06
After using i2C for temperature mesurement, I want to use ports GPIOCC32XX_GPIO_10 ("LED1") and GPIOCC32XX_GPIO_11 ("LED2") again as GPIO output ports.
(LEDs are enabled in GPIO_PinConfig gpioPinConfigs[] in CC3220SF_LAUNCHXL.c and CC3220SF_LAUNCHXL.h)
Functional sequence::
1. GPIO_init()
Some code using all 3 Board LED's: works OK
2. I2C_init()
Some code accessing temerature sensor: works OK
3. I2C_close()
Ports GPIO10 and GPIO11 remain high and can not be set again by GPIO_init() and GPIO_write()
How can I release multiplexer setting from I2C_SCL and I2C_SDA to GPIO function again? (I would prefer using driver functions instead of directly manipulating registers)
Thanks for any proposal!
Klaus
After adapting GPIO_PinConfig gpioPinConfigs[] in CC3220SF_LAUNCHXL.c and CC3220SF_LAUNCHXL.h
