Hi I am trying to do JSON construct by taking the JSON app in SDK as reference and getting error codes Please find below calling and attached source
* Copyright (c) 2015-2017, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== httpget.c ========
* HTTP Client GET example application
/* BSD support */
#include "string.h"
#include <ti/display/Display.h>
#include <ti/net/http/httpclient.h>
#include "semaphore.h"
#define HOSTNAME "http://www.example.com"
#define REQUEST_URI "/"
#define USER_AGENT "HTTPClient (ARM; TI-RTOS)"
#define HTTP_MIN_RECV (256)
extern Display_Handle display;
extern sem_t ipEventSyncObj;
extern void printError(char *errString,
int code);
* ======== httpTask ========
* Makes a HTTP GET request
void* httpTask(void* pvParameters)
bool moreDataFlag = false;
char data[HTTP_MIN_RECV];
int16_t ret = 0;
int16_t len = 0;
Display_printf(display, 0, 0, "Sending a HTTP GET request to '%s'\n",
HOSTNAME);
HTTPClient_Handle httpClientHandle;
int16_t statusCode;
httpClientHandle = HTTPClient_create(&statusCode,0);
if(statusCode < 0)
printError("httpTask: creation of http client handle failed",
statusCode);
ret =
HTTPClient_setHeader(httpClientHandle,
HTTPClient_HFIELD_REQ_USER_AGENT,
USER_AGENT,strlen(USER_AGENT),
HTTPClient_HFIELD_PERSISTENT);
if(ret < 0)
printError("httpTask: setting request header failed", ret);
ret = HTTPClient_connect(httpClientHandle,HOSTNAME,0,0);
if(ret < 0)
printError("httpTask: connect failed", ret);
ret =
HTTPClient_sendRequest(httpClientHandle,HTTP_METHOD_GET,REQUEST_URI,
NULL,0,
0);
if(ret < 0)
printError("httpTask: send failed", ret);
if(ret != HTTP_SC_OK)
printError("httpTask: cannot get status", ret);
Display_printf(display, 0, 0, "HTTP Response Status Code: %d\n", ret);
len = 0;
do
ret = HTTPClient_readResponseBody(httpClientHandle, data, sizeof(data),
&moreDataFlag);
if(ret < 0)
printError("httpTask: response body processing failed", ret);
Display_printf(display, 0, 0, "%.*s \r\n",ret,data);
len += ret;
while(moreDataFlag);
Display_printf(display, 0, 0, "Received %d bytes of payload\n", len);
ret = HTTPClient_disconnect(httpClientHandle);
if(ret < 0)
printError("httpTask: disconnect failed", ret);
HTTPClient_destroy(httpClientHandle);
return(0);
Display_printf(display, 0, 0, "JSON Start \n");
createTemplate();
createObject();
setValue();
build();
Display_printf(display, 0, 0, "JSON End \n");
Results:
JSON Start
Json_createTemplate = -102
Json_createObject = -301
Json_setValue = -302
Json_build = -302
JSON End
For the same if any other way is also good.
Thank you
