Hello TI,
There is a possible bug in software. File net\bsd\netinet\in.h:
/* * Copyright (c) 2017-2018, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #ifndef ti_net_bsd_netinet_in__include #define ti_net_bsd_netinet_in__include #include <ti/net/slnetsock.h> #ifdef __cplusplus extern "C" { #endif /* protocols */ #define IPPROTO_IP SLNETSOCK_LVL_IP #define IPPROTO_TCP SLNETSOCK_PROTO_TCP #define IPPROTO_UDP SLNETSOCK_PROTO_UDP #define IPPROTO_RAW SLNETSOCK_PROTO_RAW /* address integers */ #define INADDR_ANY SLNETSOCK_INADDR_ANY #define IN6ADDR_ANY SLNETSOCK_IN6ADDR_ANY #define in_addr SlNetSock_InAddr_t #define sockaddr_in SlNetSock_AddrIn_t #define in6_addr SlNetSock_In6Addr_t #define sockaddr_in6 SlNetSock_AddrIn6_t /* address string lengths */ #define INET_ADDRSTRLEN SLNETSOCK_INET_ADDRSTRLEN #define INET6_ADDRSTRLEN SLNETSOCK_INET6_ADDRSTRLEN /* sock options */ #define IP_ADD_MEMBERSHIP SLNETSOCK_OPIP_ADD_MEMBERSHIP #define IP_DROP_MEMBERSHIP SLNETSOCK_OPIP_DROP_MEMBERSHIP #define IP_MULTICAST_TTL SLNETSOCK_OPIP_DROP_MEMBERSHIP #define IPV6_MULTICAST_HOPS SLNETSOCK_OPIPV6_MULTICAST_HOPS #define IPV6_ADD_MEMBERSHIP SLNETSOCK_OPIPV6_ADD_MEMBERSHIP #define IPV6_DROP_MEMBERSHIP SLNETSOCK_OPIPV6_DROP_MEMBERSHIP #ifdef __cplusplus } #endif #endif /* ti_net_bsd_netinet_in__include */
Should be
/* * Copyright (c) 2017-2018, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #ifndef ti_net_bsd_netinet_in__include #define ti_net_bsd_netinet_in__include #include <ti/net/slnetsock.h> #ifdef __cplusplus extern "C" { #endif /* protocols */ #define IPPROTO_IP SLNETSOCK_LVL_IP #define IPPROTO_TCP SLNETSOCK_PROTO_TCP #define IPPROTO_UDP SLNETSOCK_PROTO_UDP #define IPPROTO_RAW SLNETSOCK_PROTO_RAW /* address integers */ #define INADDR_ANY SLNETSOCK_INADDR_ANY #define IN6ADDR_ANY SLNETSOCK_IN6ADDR_ANY #define in_addr SlNetSock_InAddr_t #define sockaddr_in SlNetSock_AddrIn_t #define in6_addr SlNetSock_In6Addr_t #define sockaddr_in6 SlNetSock_AddrIn6_t /* address string lengths */ #define INET_ADDRSTRLEN SLNETSOCK_INET_ADDRSTRLEN #define INET6_ADDRSTRLEN SLNETSOCK_INET6_ADDRSTRLEN /* sock options */ #define IP_ADD_MEMBERSHIP SLNETSOCK_OPIP_ADD_MEMBERSHIP #define IP_DROP_MEMBERSHIP SLNETSOCK_OPIP_DROP_MEMBERSHIP #define IP_MULTICAST_TTL SLNETSOCK_OPIP_MULTICAST_TTL #define IPV6_MULTICAST_HOPS SLNETSOCK_OPIPV6_MULTICAST_HOPS #define IPV6_ADD_MEMBERSHIP SLNETSOCK_OPIPV6_ADD_MEMBERSHIP #define IPV6_DROP_MEMBERSHIP SLNETSOCK_OPIPV6_DROP_MEMBERSHIP #ifdef __cplusplus } #endif #endif /* ti_net_bsd_netinet_in__include */
Eugene
