Tool/software: Linux
Hello Team,
Using android_M6.0.1_2.1.0 Wilink-8 Porting Guide as reference for integrating wifi modules on Android
My TI module is WL18xx.
On Linux kernel (3.18)Wifi is working fine without any issues,
but, on android-6 Marshmallow wifi is not working, (Linux3.18)
Including the logs for reference:
01-01 00:00:50.794 501 542 E WifiMonitor: killSupplicant p2pfalse init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-01 00:00:50.813 135 144 V vold : Waiting for FUSE to spin up...
01-01 00:00:50.817 501 501 I ActivityManager: Start proc 577:com.android.systemui/u0a3 for service com.android.systemui/.SystemUIService
01-01 00:00:50.820 501 501 D NetworkManagement: enabling bandwidth control
01-01 00:00:50.832 501 542 D wifi : Can not initialize the vendor function pointer table
01-01 00:00:50.832 501 542 E WifiNative-HAL: Could not start hal
01-01 00:00:50.832 501 542 E WifiStateMachine: Failed to start HAL
01-01 00:00:50.895 572 572 V WebViewFactory: RelroFileCreator (64bit = false), 32-bit lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so, 64-bit lib:
01-01 00:00:50.900 570 570 E sdcard : missing packages.list; retrying
01-01 00:00:50.903 501 536 D VoldConnector: RCV <- {651 emulated 2}
01-01 00:00:50.905 501 536 D VoldConnector: RCV <- {200 5 Command succeeded}
01-01 00:00:50.976 501 542 D WifiMonitor: startMonitoring(wlan0) with mConnected = false
01-01 00:00:51.280 577 577 W System : ClassLoader referenced unknown path: /system/priv-app/SystemUI/lib/arm
01-01 00:00:51.472 561 561 I dhcpcd : eth0: rebinding lease of 172.16.150.196
01-01 00:00:51.506 591 591 D wpa_supplicant: wpa_supplicant v2.5-devel-6.0
01-01 00:00:51.533 591 591 D wpa_supplicant: random: Trying to read entropy from /dev/random
01-01 00:00:51.565 591 591 I wpa_supplicant: Successfully initialized wpa_supplicant
01-01 00:00:51.565 591 591 D wpa_supplicant: Initializing interface 'wlan0' conf '/data/misc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
01-01 00:00:51.565 591 591 D wpa_supplicant: Configuration file '/data/misc/wifi/wpa_supplicant.conf' -> '/data/misc/wifi/wpa_supplicant.conf'
01-01 00:00:51.565 591 591 D wpa_supplicant: Reading configuration file '/data/misc/wifi/wpa_supplicant.conf'
01-01 00:00:51.571 561 561 E dhcpcd : eth0: invalid UDP packet from 172.16.150.22
01-01 00:00:51.577 561 561 I dhcpcd : eth0: acknowledged 172.16.150.196 from 172.16.150.1
01-01 00:00:51.604 591 591 D wpa_supplicant: update_config=1
01-01 00:00:51.604 591 591 D wpa_supplicant: ctrl_interface='/data/misc/wifi/sockets'
01-01 00:00:51.604 591 591 D wpa_supplicant: ap_scan=1
01-01 00:00:51.604 591 591 D wpa_supplicant: fast_reauth=1
01-01 00:00:51.604 591 591 D wpa_supplicant: persistent_reconnect=1
01-01 00:00:51.604 591 591 D wpa_supplicant: disassoc_low_ack=1
01-01 00:00:51.604 591 591 E wpa_supplicant: Line 8: unknown global field 'concurrent_sched_scan=1'.
01-01 00:00:51.604 591 591 E wpa_supplicant: Line 8: Invalid configuration line 'concurrent_sched_scan=1'.
01-01 00:00:51.618 501 516 W WindowManager: Keyguard drawn timeout. Setting mKeyguardDrawComplete
01-01 00:00:51.634 591 591 I wpa_supplicant: rfkill: Cannot open RFKILL control device
01-01 00:00:51.634 591 591 D wpa_supplicant: nl80211: RFKILL status not available
01-01 00:00:51.635 591 591 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:1
01-01 00:00:51.635 591 591 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:5
01-01 00:00:51.636 591 591 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:2
01-01 00:00:51.636 591 591 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:4
01-01 00:00:51.636 591 591 D wpa_supplicant: nl80211: Supported cipher 00-14-72:1
01-01 00:00:51.636 591 591 D wpa_supplicant: nl80211: Supports Probe Response offload in AP mode
01-01 00:00:51.636 591 591 D wpa_supplicant: nl80211: Using driver-based off-channel TX
01-01 00:00:51.636 591 591 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=0
01-01 00:00:51.636 591 591 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=1
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=2
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Supported vendor event: vendor_id=0x80028 subcmd=0
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Supported vendor event: vendor_id=0x80028 subcmd=1
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Use separate P2P group interface (driver advertised support)
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Enable multi-channel concurrent (driver advertised support)
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: use P2P_DEVICE support
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: interface wlan0 in phy phy0
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Set mode ifindex 4 iftype 2 (STATION)
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Subscribe to mgmt frames with non-AP handle 0xb6a0b0c0
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=0104
01-01 00:00:51.637 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=040a
01-01 00:00:51.638 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=040b
01-01 00:00:51.638 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=040c
01-01 00:00:51.638 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=040d
01-01 00:00:51.638 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=090a
01-01 00:00:51.638 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=090b
01-01 00:00:51.638 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=090c
01-01 00:00:51.638 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=090d
01-01 00:00:51.638 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=0409506f9a09
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=7f506f9a09
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=0801
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=06
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=0a07
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=0a11
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=0a1a
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=1101
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=1102
01-01 00:00:51.639 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0c0 match=0505
01-01 00:00:51.640 561 561 I dhcpcd : eth0: leased 172.16.150.196 for 86400 seconds
01-01 00:00:51.690 577 577 V SystemUIService: Starting SystemUI services.
01-01 00:00:52.122 572 572 I art : System.exit called, status: 0
01-01 00:00:52.122 572 572 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
01-01 00:00:52.350 577 629 E WVMExtractor: Failed to open libwvm.so: dlopen failed: library "libwvm.so" not found
01-01 00:00:52.453 170 170 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:52.563 591 591 D wpa_supplicant: netlink: Operstate: ifindex=4 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
01-01 00:00:52.566 591 591 D wpa_supplicant: nl80211: driver param='(null)'
01-01 00:00:52.567 591 591 D wpa_supplicant: Add interface wlan0 to a new radio phy0
01-01 00:00:52.571 591 591 D wpa_supplicant: nl80211: Regulatory information - country=00
01-01 00:00:52.571 591 591 D wpa_supplicant: nl80211: 2402-2472 @ 40 MHz 20 mBm
01-01 00:00:52.571 591 591 D wpa_supplicant: nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
01-01 00:00:52.571 591 591 D wpa_supplicant: nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
01-01 00:00:52.571 591 591 D wpa_supplicant: nl80211: 5170-5250 @ 40 MHz 20 mBm (no IR)
01-01 00:00:52.571 591 591 D wpa_supplicant: nl80211: 5735-5835 @ 40 MHz 20 mBm (no IR)
01-01 00:00:52.571 591 591 D wpa_supplicant: nl80211: Added 802.11b mode based on 802.11g information
01-01 00:00:52.610 591 591 D wpa_supplicant: wlan0: Own MAC address: de:ad:be:ef:00:00
01-01 00:00:52.610 591 591 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
01-01 00:00:52.611 591 591 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
01-01 00:00:52.611 591 591 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
01-01 00:00:52.611 591 591 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
01-01 00:00:52.611 591 591 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=0x0 key_idx=4 set_tx=0 seq_len=0 key_len=0
01-01 00:00:52.612 591 591 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=0x0 key_idx=5 set_tx=0 seq_len=0 key_len=0
01-01 00:00:52.612 591 591 D wpa_supplicant: wlan0: RSN: flushing PMKID list in the driver
01-01 00:00:52.612 591 591 D wpa_supplicant: nl80211: Flush PMKIDs
01-01 00:00:52.612 591 591 D wpa_supplicant: wlan0: State: DISCONNECTED -> INACTIVE
01-01 00:00:52.691 591 591 D wpa_supplicant: TDLS: TDLS operation not supported by driver
01-01 00:00:52.691 591 591 D wpa_supplicant: TDLS: Driver uses internal link setup
01-01 00:00:52.691 591 591 D wpa_supplicant: TDLS: Driver does not support TDLS channel switching
01-01 00:00:52.692 591 591 D wpa_supplicant: wlan0: WPS: UUID based on MAC address: eb6c866b-8824-5ee2-9602-d9bf673bd55c
01-01 00:00:52.699 591 591 D wpa_supplicant: EAPOL: SUPP_PAE entering state DISCONNECTED
01-01 00:00:52.699 591 591 D wpa_supplicant: EAPOL: Supplicant port status: Unauthorized
01-01 00:00:52.699 591 591 D wpa_supplicant: nl80211: Skip set_supp_port(unauthorized) while not associated
01-01 00:00:52.699 591 591 D wpa_supplicant: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
01-01 00:00:52.699 591 591 D wpa_supplicant: EAPOL: SUPP_BE entering state INITIALIZE
01-01 00:00:52.699 591 591 D wpa_supplicant: EAP: EAP entering state DISABLED
01-01 00:00:52.707 591 591 D wpa_supplicant: Using existing control interface directory.
01-01 00:00:52.707 591 591 E wpa_supplicant: CTRL: Could not chmod directory: Operation not permitted
01-01 00:00:52.731 591 591 D wpa_supplicant: wlan0: Added interface wlan0
01-01 00:00:52.731 591 591 D wpa_supplicant: wlan0: State: INACTIVE -> DISCONNECTED
01-01 00:00:52.731 591 591 D wpa_supplicant: nl80211: Set wlan0 operstate 0->0 (DORMANT)
01-01 00:00:52.731 591 591 D wpa_supplicant: netlink: Operstate: ifindex=4 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
01-01 00:00:52.732 591 591 D wpa_supplicant: nl80211: Create interface iftype 10 (P2P_DEVICE)
01-01 00:00:52.732 591 591 D wpa_supplicant: nl80211: New P2P Device interface p2p-dev-wlan0 (0x2) created
01-01 00:00:52.732 591 591 D wpa_supplicant: Initializing interface 'p2p-dev-wlan0' conf '/data/misc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface '/data/misc/wifi/sockets' bridge 'N/A'
01-01 00:00:52.732 591 591 D wpa_supplicant: Configuration file '/data/misc/wifi/wpa_supplicant.conf' -> '/data/misc/wifi/wpa_supplicant.conf'
01-01 00:00:52.732 591 591 D wpa_supplicant: Reading configuration file '/data/misc/wifi/wpa_supplicant.conf'
01-01 00:00:52.734 591 591 D wpa_supplicant: update_config=1
01-01 00:00:52.734 591 591 D wpa_supplicant: ctrl_interface='/data/misc/wifi/sockets'
01-01 00:00:52.734 591 591 D wpa_supplicant: ap_scan=1
01-01 00:00:52.734 591 591 D wpa_supplicant: fast_reauth=1
01-01 00:00:52.734 591 591 D wpa_supplicant: persistent_reconnect=1
01-01 00:00:52.734 591 591 D wpa_supplicant: disassoc_low_ack=1
01-01 00:00:52.734 591 591 E wpa_supplicant: Line 8: unknown global field 'concurrent_sched_scan=1'.
01-01 00:00:52.734 591 591 E wpa_supplicant: Line 8: Invalid configuration line 'concurrent_sched_scan=1'.
01-01 00:00:52.735 591 591 I wpa_supplicant: rfkill: Cannot open RFKILL control device
01-01 00:00:52.735 591 591 D wpa_supplicant: nl80211: RFKILL status not available
01-01 00:00:52.751 591 591 E wpa_supplicant: Could not read interface p2p-dev-wlan0 flags: No such device
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:1
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:5
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:2
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:4
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Supported cipher 00-14-72:1
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Supports Probe Response offload in AP mode
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Using driver-based off-channel TX
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=0
01-01 00:00:52.758 591 591 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=1
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=2
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Supported vendor event: vendor_id=0x80028 subcmd=0
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Supported vendor event: vendor_id=0x80028 subcmd=1
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Use separate P2P group interface (driver advertised support)
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Enable multi-channel concurrent (driver advertised support)
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: use P2P_DEVICE support
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: interface p2p-dev-wlan0 in phy phy0
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Set mode ifindex 0 iftype 10 (P2P_DEVICE)
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Failed to set interface 0 to mode 10: -22 (Invalid argument)
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Subscribe to mgmt frames with non-AP handle 0xb6a0b0f0
01-01 00:00:52.759 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=0104
01-01 00:00:52.760 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=040a
01-01 00:00:52.760 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=040b
01-01 00:00:52.760 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=040c
01-01 00:00:52.760 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=040d
01-01 00:00:52.760 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=090a
01-01 00:00:52.760 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=090b
01-01 00:00:52.761 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=090c
01-01 00:00:52.761 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=090d
01-01 00:00:52.761 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=0409506f9a09
01-01 00:00:52.761 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=7f506f9a09
01-01 00:00:52.761 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=0801
01-01 00:00:52.761 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=06
01-01 00:00:52.762 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=0a07
01-01 00:00:52.762 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=0a11
01-01 00:00:52.762 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=0a1a
01-01 00:00:52.762 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=1101
01-01 00:00:52.762 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=1102
01-01 00:00:52.762 591 591 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a0b0f0 match=0505
01-01 00:00:52.779 591 591 D wpa_supplicant: nl80211: Start P2P Device p2p-dev-wlan0 (0x2): Success
01-01 00:00:52.782 591 591 D wpa_supplicant: nl80211: driver param='(null)'
01-01 00:00:52.782 591 591 D wpa_supplicant: Add interface p2p-dev-wlan0 to existing radio phy0
01-01 00:00:52.783 591 591 D wpa_supplicant: nl80211: Regulatory information - country=00
01-01 00:00:52.783 591 591 D wpa_supplicant: nl80211: 2402-2472 @ 40 MHz 20 mBm
01-01 00:00:52.783 591 591 D wpa_supplicant: nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
01-01 00:00:52.784 591 591 D wpa_supplicant: nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
01-01 00:00:52.784 591 591 D wpa_supplicant: nl80211: 5170-5250 @ 40 MHz 20 mBm (no IR)
01-01 00:00:52.784 591 591 D wpa_supplicant: nl80211: 5735-5835 @ 40 MHz 20 mBm (no IR)
01-01 00:00:52.784 591 591 D wpa_supplicant: nl80211: Added 802.11b mode based on 802.11g information
01-01 00:00:52.784 591 591 D wpa_supplicant: p2p-dev-wlan0: Own MAC address: de:ad:be:ef:00:01
01-01 00:00:52.784 591 591 D wpa_supplicant: p2p-dev-wlan0: RSN: flushing PMKID list in the driver
01-01 00:00:52.784 591 591 D wpa_supplicant: nl80211: Flush PMKIDs
01-01 00:00:52.784 591 591 D wpa_supplicant: p2p-dev-wlan0: State: DISCONNECTED -> INACTIVE
01-01 00:00:52.784 591 591 D wpa_supplicant: p2p-dev-wlan0: WPS: UUID from the first interface: eb6c866b-8824-5ee2-9602-d9bf673bd55c
01-01 00:00:52.785 591 591 D wpa_supplicant: EAPOL: SUPP_PAE entering state DISCONNECTED
01-01 00:00:52.785 591 591 D wpa_supplicant: EAPOL: Supplicant port status: Unauthorized
01-01 00:00:52.785 591 591 D wpa_supplicant: nl80211: Skip set_supp_port(unauthorized) while not associated
01-01 00:00:52.785 591 591 D wpa_supplicant: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
01-01 00:00:52.785 591 591 D wpa_supplicant: EAPOL: SUPP_BE entering state INITIALIZE
01-01 00:00:52.785 591 591 D wpa_supplicant: EAP: EAP entering state DISABLED
01-01 00:00:52.790 591 591 D wpa_supplicant: Using existing control interface directory.
01-01 00:00:52.793 591 591 E wpa_supplicant: CTRL: Could not chmod directory: Operation not permitted
01-01 00:00:52.806 591 591 D wpa_supplicant: P2P: Add operating class 81
01-01 00:00:52.806 591 591 D wpa_supplicant: P2P: Channels - hexdump(len=11): 01 02 03 04 05 06 07 08 09 0a 0b
01-01 00:00:52.808 591 591 D wpa_supplicant: P2P: Own listen channel: 81:11
01-01 00:00:52.810 591 591 D wpa_supplicant: P2P: Random operating channel: 81:11
01-01 00:00:52.812 591 591 D wpa_supplicant: P2P: initialized
01-01 00:00:52.813 591 591 D wpa_supplicant: P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11
01-01 00:00:52.813 591 591 D wpa_supplicant: P2P: cli_channels:
01-01 00:00:52.813 591 591 D wpa_supplicant: p2p-dev-wlan0: Added interface p2p-dev-wlan0
01-01 00:00:52.813 591 591 D wpa_supplicant: p2p-dev-wlan0: State: INACTIVE -> DISCONNECTED
01-01 00:00:52.813 591 591 D wpa_supplicant: nl80211: Set p2p-dev-wlan0 operstate 0->0 (DORMANT)
01-01 00:00:52.813 591 591 D wpa_supplicant: netlink: Operstate: ifindex=0 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
01-01 00:00:52.813 591 591 D wpa_supplicant: random: Got 20/20 bytes from /dev/random
01-01 00:00:52.814 591 591 D wpa_supplicant: RTM_NEWLINK: ifi_index=4 ifname=wlan0 operstate=0 linkmode=0 ifi_family=0 ifi_flags=0x1043 ([UP][RUNNING])
01-01 00:00:52.814 591 591 D wpa_supplicant: RTM_NEWLINK: ifi_index=4 ifname=wlan0 operstate=2 linkmode=0 ifi_family=0 ifi_flags=0x1003 ([UP])
01-01 00:00:52.814 591 591 D wpa_supplicant: RTM_NEWLINK: ifi_index=4 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1003 ([UP])
01-01 00:00:52.957 170 170 W MVE_OMX_IF: Get parameter returned error status. error=0x8000101a, handle=0xb60970e0, index=0x600000f. (mve_omx_common_component.c:549)
01-01 00:00:52.957 170 170 E OMXNodeInstance: getParameter(6:ARM.v5xx.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:00:53.173 501 560 D ConnectivityService: registerNetworkAgent NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: a0:8c:fd:1b:f0:4a, roaming: false, failover: false, isAvailable: true]} network{100} lp{{InterfaceName: eth0 LinkAddresses: [172.16.150.196/24,] Routes: [172.16.150.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.150.1 eth0,] DnsAddresses: [] Domains: MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}} nc{[ Transports: ETHERNET Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]} Score{30} everValidated{false} lastValidated{false} created{false} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} }
01-01 00:00:53.174 501 544 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] EVENT_NETWORK_INFO_CHANGED, going from null to CONNECTED
01-01 00:00:53.239 501 501 E NetdConnector: NDC Command {12 bandwidth enable} took too long (2418ms)
01-01 00:00:53.241 501 544 D ConnectivityService: Adding iface eth0 to network 100
01-01 00:00:53.272 170 170 W OMXNodeInstance: [f:google.mpeg4.decoder] component does not support metadata mode; using fallback
01-01 00:00:53.282 170 170 W OMXNodeInstance: [10:google.h263.decoder] component does not support metadata mode; using fallback
01-01 00:00:53.293 577 577 I vol.Events: writeEvent collection_started
01-01 00:00:53.328 170 170 D SoftAVCDec: Number of CPU cores: 4
01-01 00:00:53.370 170 170 W OMXNodeInstance: [11:google.h264.decoder] component does not support metadata mode; using fallback
01-01 00:00:53.373 170 170 D SoftAVCDec: Number of CPU cores: 4
01-01 00:00:53.427 170 170 W OMXNodeInstance: [12:google.vp8.decoder] component does not support metadata mode; using fallback
01-01 00:00:53.443 170 170 W OMXNodeInstance: [13:google.vp9.decoder] component does not support metadata mode; using fallback
01-01 00:00:53.554 501 544 E ConnectivityService: Unexpected mtu value: 0, eth0
01-01 00:00:53.554 501 544 D ConnectivityService: Adding Route [172.16.150.0/24 -> 0.0.0.0 eth0] to network 100
01-01 00:00:53.701 591 591 D wpa_supplicant: EAPOL: disable timer tick
01-01 00:00:53.786 591 591 D wpa_supplicant: EAPOL: disable timer tick
01-01 00:00:53.789 170 170 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
01-01 00:00:53.790 170 170 W ACodec : do not know color format 0x7f000789 = 2130708361
01-01 00:00:53.813 577 712 I vol.Events: writeEvent level_changed STREAM_ALARM 6
01-01 00:00:53.819 577 712 I vol.Events: writeEvent level_changed STREAM_BLUETOOTH_SCO 7
01-01 00:00:53.824 577 712 I vol.Events: writeEvent level_changed STREAM_MUSIC 11
01-01 00:00:53.834 577 712 I vol.Events: writeEvent level_changed STREAM_RING 5
01-01 00:00:53.836 577 712 I vol.Events: writeEvent level_changed STREAM_SYSTEM 5
01-01 00:00:53.842 170 170 W ACodec : do not know color format 0x7f000789 = 2130708361
01-01 00:00:53.852 167 499 I iptables: iptables: No chain/target/match by that name.
01-01 00:00:53.853 170 170 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
01-01 00:00:53.854 167 499 I iptables: iptables terminated by exit(1)
01-01 00:00:53.854 170 170 W ACodec : do not know color format 0x7f000789 = 2130708361
01-01 00:00:53.854 167 499 E Netd : exec() res=0, status=256 for /system/bin/iptables -w -F st_penalty_log
01-01 00:00:53.862 577 712 I vol.Events: writeEvent level_changed STREAM_VOICE_CALL 4
01-01 00:00:53.872 577 712 I vol.Events: writeEvent external_ringer_mode_changed normal
01-01 00:00:53.884 577 577 D StorageNotification: Notifying about private volume: VolumeInfo{private}:
01-01 00:00:53.884 577 577 D StorageNotification: type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
01-01 00:00:53.884 577 577 D StorageNotification: state=MOUNTED
01-01 00:00:53.884 577 577 D StorageNotification: fsType=null fsUuid=null fsLabel=null
01-01 00:00:53.884 577 577 D StorageNotification: path=/data internalPath=null
01-01 00:00:53.902 570 570 E sdcard : missing packages.list; retrying
01-01 00:00:53.931 167 499 I ip6tables: ip6tables: No chain/target/match by that name.
01-01 00:00:53.933 167 499 I ip6tables: ip6tables terminated by exit(1)
01-01 00:00:53.933 167 499 E Netd : exec() res=0, status=256 for /system/bin/ip6tables -w -F st_penalty_log
01-01 00:00:53.948 170 170 W ACodec : do not know color format 0x7f000789 = 2130708361
01-01 00:00:53.955 170 170 W MediaCodecList: unable to open media codecs configuration xml file: /etc/media_codecs_performance.xml
01-01 00:00:53.959 170 170 W MediaCodecList: unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
01-01 00:00:53.967 577 635 I OMXClient: Using client-side OMX mux.
01-01 00:00:53.982 167 499 I iptables: iptables: No chain/target/match by that name.
01-01 00:00:53.984 167 499 I iptables: iptables terminated by exit(1)
01-01 00:00:53.984 167 499 E Netd : exec() res=0, status=256 for /system/bin/iptables -w -F st_penalty_reject
01-01 00:00:54.005 577 635 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:54.029 167 499 I ip6tables: ip6tables: No chain/target/match by that name.
01-01 00:00:54.030 167 499 I ip6tables: ip6tables terminated by exit(1)
01-01 00:00:54.031 167 499 E Netd : exec() res=0, status=256 for /system/bin/ip6tables -w -F st_penalty_reject
01-01 00:00:54.076 167 499 I iptables: iptables: No chain/target/match by that name.
01-01 00:00:54.078 167 499 I iptables: iptables terminated by exit(1)
01-01 00:00:54.078 167 499 E Netd : exec() res=0, status=256 for /system/bin/iptables -w -F st_clear_caught
01-01 00:00:54.147 167 499 I ip6tables: ip6tables: No chain/target/match by that name.
01-01 00:00:54.149 167 499 I ip6tables: ip6tables terminated by exit(1)
01-01 00:00:54.149 167 499 E Netd : exec() res=0, status=256 for /system/bin/ip6tables -w -F st_clear_caught
01-01 00:00:54.190 167 499 I iptables: iptables: No chain/target/match by that name.
01-01 00:00:54.192 167 499 I iptables: iptables terminated by exit(1)
01-01 00:00:54.192 167 499 E Netd : exec() res=0, status=256 for /system/bin/iptables -w -F st_clear_detect
01-01 00:00:54.206 501 512 I StatusBarManagerService: registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@8e9dbcb
01-01 00:00:54.216 577 760 I OMXClient: Using client-side OMX mux.
01-01 00:00:54.231 577 760 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:54.235 167 499 I ip6tables: ip6tables: No chain/target/match by that name.
01-01 00:00:54.252 167 499 I ip6tables: ip6tables terminated by exit(1)
01-01 00:00:54.252 167 499 E Netd : exec() res=0, status=256 for /system/bin/ip6tables -w -F st_clear_detect
01-01 00:00:54.262 501 515 W DropBoxManagerService: Unrecognized file: /data/system/dropbox/.nfs00000000003b094500000004
01-01 00:00:54.316 167 499 I iptables: iptables: No chain/target/match by that name.
01-01 00:00:54.331 167 499 I iptables: iptables terminated by exit(1)
01-01 00:00:54.332 167 499 E Netd : exec() res=0, status=256 for /system/bin/iptables -w -X st_penalty_log
01-01 00:00:54.343 577 765 I OMXClient: Using client-side OMX mux.
01-01 00:00:54.357 577 765 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:54.376 167 499 I ip6tables: ip6tables: No chain/target/match by that name.
01-01 00:00:54.378 167 499 I ip6tables: ip6tables terminated by exit(1)
01-01 00:00:54.378 167 499 E Netd : exec() res=0, status=256 for /system/bin/ip6tables -w -X st_penalty_log
01-01 00:00:54.421 167 499 I iptables: iptables: No chain/target/match by that name.
01-01 00:00:54.422 167 499 I iptables: iptables terminated by exit(1)
01-01 00:00:54.423 167 499 E Netd : exec() res=0, status=256 for /system/bin/iptables -w -X st_penalty_reject
01-01 00:00:54.473 167 499 I ip6tables: ip6tables: No chain/target/match by that name.
01-01 00:00:54.474 167 499 I ip6tables: ip6tables terminated by exit(1)
01-01 00:00:54.475 167 499 E Netd : exec() res=0, status=256 for /system/bin/ip6tables -w -X st_penalty_reject
01-01 00:00:54.531 167 499 I iptables: iptables: No chain/target/match by that name.
01-01 00:00:54.533 167 499 I iptables: iptables terminated by exit(1)
01-01 00:00:54.534 167 499 E Netd : exec() res=0, status=256 for /system/bin/iptables -w -X st_clear_caught
01-01 00:00:54.581 167 499 I ip6tables: ip6tables: No chain/target/match by that name.
01-01 00:00:54.583 167 499 I ip6tables: ip6tables terminated by exit(1)
01-01 00:00:54.583 167 499 E Netd : exec() res=0, status=256 for /system/bin/ip6tables -w -X st_clear_caught
01-01 00:00:54.622 167 499 I iptables: iptables: No chain/target/match by that name.
01-01 00:00:54.632 167 499 I iptables: iptables terminated by exit(1)
01-01 00:00:54.632 167 499 E Netd : exec() res=0, status=256 for /system/bin/iptables -w -X st_clear_detect
01-01 00:00:54.685 167 499 I ip6tables: ip6tables: No chain/target/match by that name.
01-01 00:00:54.687 167 499 I ip6tables: ip6tables terminated by exit(1)
01-01 00:00:54.687 167 499 E Netd : exec() res=0, status=256 for /system/bin/ip6tables -w -X st_clear_detect
01-01 00:00:55.011 501 543 D WifiService: New client listening to asynchronous messages
01-01 00:00:55.295 501 515 W DropBoxManagerService: Dropping: system_server_wtf (1415 > 0 bytes)
01-01 00:00:55.679 577 577 E BluetoothAdapter: Bluetooth binder is null
01-01 00:00:55.691 501 512 D ConnectivityService: listenForNetwork for Listen from uid/pid:10003/577 for NetworkRequest [ id=3, legacyType=-1, [] ]
01-01 00:00:55.724 577 577 I CameraManagerGlobal: Connecting to camera service
01-01 00:00:55.733 170 741 E CameraService: getCameraVendorTagDescriptor: camera hardware module doesn't exist
01-01 00:00:55.733 577 577 E CameraMetadata-JNI: CameraMetadata_setupGlobalVendorTagDescriptor: Failed to setup vendor tag descriptors, received error No such device (-19)
01-01 00:00:55.734 577 577 W CameraManagerGlobal: Failed to set up vendor tags: The camera device is removable and has been disconnected from the Android device, or the camera service has shut down the connection due to a higher-priority access request for the camera device.
01-01 00:00:56.065 501 607 I ActivityManager: Start proc 810:android.process.acore/u0a0 for content provider com.android.providers.contacts/.ContactsProvider2
01-01 00:00:56.233 501 511 I art : Background sticky concurrent mark sweep GC freed 48770(3MB) AllocSpace objects, 10(228KB) LOS objects, 27% free, 11MB/15MB, paused 4.015ms total 161.976ms
01-01 00:00:56.294 501 501 E NetdConnector: NDC Command {15 strict enable} took too long (3051ms)
01-01 00:00:56.298 501 544 E NetdConnector: NDC Command {16 network route add 100 eth0 172.16.150.0/24} took too long (2741ms)
01-01 00:00:56.299 501 544 D ConnectivityService: Adding Route [0.0.0.0/0 -> 172.16.150.1 eth0] to network 100
01-01 00:00:56.304 501 544 D ConnectivityService: Setting Dns servers for network 100 to []
01-01 00:00:56.326 501 544 D ConnectivityService: notifyType IP_CHANGED for NetworkAgentInfo [Ethernet () - 100]
01-01 00:00:56.336 501 544 D ConnectivityService: scheduleUnvalidatedPrompt 100
01-01 00:00:56.341 501 544 D ConnectivityService: rematching NetworkAgentInfo [Ethernet () - 100]
01-01 00:00:56.341 501 544 D ConnectivityService: accepting network in place of null
01-01 00:00:56.343 501 544 D ConnectivityService: Switching to new default network: NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: a0:8c:fd:1b:f0:4a, roaming: false, failover: false, isAvailable: true]} network{100} lp{{InterfaceName: eth0 LinkAddresses: [172.16.150.196/24,] Routes: [172.16.150.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.150.1 eth0,] DnsAddresses: [] Domains: MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}} nc{[ Transports: ETHERNET Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]} Score{30} everValidated{false} lastValidated{false} created{true} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} }
01-01 00:00:56.347 501 544 D ConnectivityService: Setting tx/rx TCP buffers to 524288,1048576,3145728,524288,1048576,2097152
01-01 00:00:56.352 501 697 D NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]: Probably not a portal: exception java.net.UnknownHostException: Unable to resolve host "connectivitycheck.gstatic.com": No address associated with hostname
01-01 00:00:56.355 501 544 D CSLegacyTypeTracker: Sending CONNECTED broadcast for type 9 NetworkAgentInfo [Ethernet () - 100] isDefaultNetwork=true
01-01 00:00:56.357 501 544 D ConnectivityService: sendStickyBroadcast: action=android.net.conn.CONNECTIVITY_CHANGE
01-01 00:00:56.359 501 544 D ConnectivityService: notifyType PRECHECK for NetworkAgentInfo [Ethernet () - 100]
01-01 00:00:56.360 501 544 D ConnectivityService: rematching NetworkAgentInfo [Ethernet () - 100]
01-01 00:00:56.364 501 544 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] validation failed
01-01 00:00:56.421 810 810 W System : ClassLoader referenced unknown path: /system/priv-app/ContactsProvider/lib/arm
01-01 00:00:56.448 577 798 D ConnectivityManager.CallbackHandler: CM callback handler got msg 524290
01-01 00:00:56.479 577 829 D OpenGLRenderer: Use EGL_SWAP_BEHAVIOR_PRESERVED: true
01-01 00:00:56.479 577 829 D OpenGLRenderer: profile bars disabled
01-01 00:00:56.480 577 829 D OpenGLRenderer: ambientRatio = 1.50
01-01 00:00:56.504 577 577 D PhoneStatusBar: disable: < expand icons alerts system_info back home recent clock search quick_settings >
01-01 00:00:56.632 577 577 D PhoneStatusBar: heads up is enabled
01-01 00:00:56.695 577 577 I Choreographer: Skipped 140 frames! The application may be doing too much work on its main thread.
01-01 00:00:56.707 577 577 D ViewRootImpl: changeCanvasOpacity: opaque=true
01-01 00:00:56.905 570 570 E sdcard : missing packages.list; retrying
01-01 00:00:56.998 501 501 D PermissionMonitor: Monitoring
01-01 00:00:57.050 501 501 D PermissionMonitor: Users: 1, Apps: 55
01-01 00:00:57.058 501 543 D WifiService: New client listening to asynchronous messages
01-01 00:00:57.069 501 501 I SystemServiceManager: Starting phase 600
01-01 00:00:57.069 501 549 E BluetoothAdapter: Bluetooth binder is null
01-01 00:00:57.074 501 549 E BluetoothAdapter: Bluetooth binder is null
01-01 00:00:57.080 170 741 I AudioFlinger: systemReady
01-01 00:00:57.111 810 810 W System : ClassLoader referenced unknown path: /system/app/UserDictionaryProvider/lib/arm
01-01 00:00:57.122 501 501 E InputMethodManagerService: Ignoring updateSystemUiLocked due to an invalid token. uid:1000 token:null
01-01 00:00:57.166 501 843 E WVMExtractor: Failed to open libwvm.so: dlopen failed: library "libwvm.so" not found
01-01 00:00:57.197 501 501 I ActivityManager: Start proc 845:com.android.inputmethod.latin/u0a25 for service com.android.inputmethod.latin/.LatinIME
01-01 00:00:57.197 501 501 V InputMethodManagerService: Adding window token: android.os.Binder@b26773d
01-01 00:00:57.222 501 501 W LocationManagerService: no network location provider found
01-01 00:00:57.231 501 501 E LocationManagerService: no geocoder provider found
01-01 00:00:57.234 501 501 E FlpHardwareProvider: Error hw_get_module 'flp': -2
01-01 00:00:57.234 501 501 E LocationManagerService: FLP HAL not supported
01-01 00:00:57.242 501 850 I OMXClient: Using client-side OMX mux.
01-01 00:00:57.245 501 501 E LocationManagerService: Unable to bind FLP Geofence proxy.
01-01 00:00:57.248 501 501 E ActivityRecognitionHardware: Error hw_get_module: -2
01-01 00:00:57.249 501 501 E LocationManagerService: Hardware Activity-Recognition not supported.
01-01 00:00:57.253 501 850 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:57.272 501 501 I CommonTimeManagementService: No common time service detected on this platform. Common time services will be unavailable.
01-01 00:00:57.284 501 534 I InputReader: Reconfiguring input devices. changes=0x00000020
01-01 00:00:57.286 501 501 I MmsServiceBroker: Delay connecting to MmsService until an API is called
01-01 00:00:57.296 501 501 D MountService: onStartUser 0
01-01 00:00:57.300 501 501 D VoldConnector: SND -> {6 volume user_started 0}
01-01 00:00:57.311 135 144 D vold : Linking /storage/emulated/0 to /mnt/user/0/primary
01-01 00:00:57.311 501 536 D VoldConnector: RCV <- {200 6 Command succeeded}
01-01 00:00:57.316 501 534 I InputReader: Reconfiguring input devices. changes=0x00000010
01-01 00:00:57.317 501 535 D MountService: Volume emulated broadcasting mounted to UserHandle{0}
01-01 00:00:57.355 501 697 D NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]: Probably not a portal: exception java.net.UnknownHostException: Unable to resolve host "connectivitycheck.gstatic.com": No address associated with hostname
01-01 00:00:57.357 501 544 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] validation failed
01-01 00:00:57.403 501 501 I ActivityManager: Start proc 860:com.android.phone/1001 for added application com.android.phone
01-01 00:00:57.408 501 501 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher} from uid 0 on display 0
01-01 00:00:57.408 501 864 I OMXClient: Using client-side OMX mux.
01-01 00:00:57.426 501 864 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:57.531 501 501 I ActivityManager: Start proc 870:com.android.launcher/u0a2 for activity com.android.launcher/com.android.launcher2.Launcher
01-01 00:00:57.562 501 516 W art : Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable) from ActivityManagerService.java:11842 waiters=0 for 240ms
01-01 00:00:57.564 501 501 I SystemServer: Enabled StrictMode for system server main thread.
01-01 00:00:57.584 577 601 I art : Background sticky concurrent mark sweep GC freed 25800(1167KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 2MB/4MB, paused 18.508ms total 168.759ms
01-01 00:00:57.619 501 501 D RttService: SCAN_AVAILABLE : 1
01-01 00:00:57.619 501 501 I Choreographer: Skipped 932 frames! The application may be doing too much work on its main thread.
01-01 00:00:57.620 501 558 D RttService: DefaultState got{ when=-1ms what=160513 target=com.android.internal.util.StateMachine$SmHandler }
01-01 00:00:57.675 501 889 I OMXClient: Using client-side OMX mux.
01-01 00:00:57.703 501 889 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:57.737 501 501 W System : ClassLoader referenced unknown path: /system/priv-app/Telecom/lib/arm
01-01 00:00:57.755 577 577 I Choreographer: Skipped 139 frames! The application may be doing too much work on its main thread.
01-01 00:00:57.942 501 894 I OMXClient: Using client-side OMX mux.
01-01 00:00:57.946 860 860 W System : ClassLoader referenced unknown path: /system/priv-app/TeleService/lib/arm
01-01 00:00:57.964 501 894 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:57.983 870 870 W System : ClassLoader referenced unknown path: /system/priv-app/Launcher2/lib/arm
01-01 00:00:58.052 501 501 E BluetoothAdapter: Bluetooth binder is null
01-01 00:00:58.111 577 577 D PhoneStatusBar: disable: < EXPAND* icons alerts system_info BACK* HOME* RECENT* clock SEARCH* quick_settings >
01-01 00:00:58.128 577 577 I Choreographer: Skipped 48 frames! The application may be doing too much work on its main thread.
01-01 00:00:58.146 501 897 I OMXClient: Using client-side OMX mux.
01-01 00:00:58.159 501 897 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:58.238 501 501 E BluetoothAdapter: Bluetooth binder is null
01-01 00:00:58.246 501 501 I Telecom : Class: TelecomSystem.INSTANCE being set
01-01 00:00:58.246 501 501 E BluetoothAdapter: Bluetooth binder is null
01-01 00:00:58.326 501 906 I OMXClient: Using client-side OMX mux.
01-01 00:00:58.336 501 906 E libstagefrighthw: Creating OMX Plugin
01-01 00:00:58.369 501 501 W System : ClassLoader referenced unknown path: /system/priv-app/FusedLocation/lib/arm
01-01 00:00:58.377 860 860 W System : ClassLoader referenced unknown path: /system/priv-app/TelephonyProvider/lib/arm
01-01 00:00:58.433 501 501 V WiredAccessoryManager: init()
01-01 00:00:58.434 577 577 I Choreographer: Skipped 39 frames! The application may be doing too much work on its main thread.
01-01 00:00:58.442 501 501 I Choreographer: Skipped 102 frames! The application may be doing too much work on its main thread.
01-01 00:00:58.470 810 835 I ContactLocale: AddressBook Labels [en-US]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, , ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
01-01 00:00:58.824 577 601 I art : Background partial concurrent mark sweep GC freed 10660(585KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 8MB/14MB, paused 1.486ms total 132.788ms
01-01 00:00:58.843 501 501 I FusedLocation: engine started (com.android.location.fused)
01-01 00:00:59.097 860 860 D TelephonyProvider: dbh.onOpen: ok, queried table=siminfo
01-01 00:00:59.102 860 860 D TelephonyProvider: dbh.onOpen: ok, queried table=carriers
01-01 00:00:59.160 845 845 I LatinIME: Hardware accelerated drawing: true
01-01 00:00:59.410 501 697 D NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]: Probably not a portal: exception java.net.UnknownHostException: Unable to resolve host "connectivitycheck.gstatic.com": No address associated with hostname
01-01 00:00:59.411 501 544 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] validation failed
01-01 00:00:59.670 577 577 I Choreographer: Skipped 149 frames! The application may be doing too much work on its main thread.
01-01 00:00:59.794 845 845 W InputAttributes: No editor info for this field. Bug?
01-01 00:00:59.912 570 570 E sdcard : missing packages.list; retrying
01-01 00:00:59.934 845 935 I LatinIME:LogUtils: Dictionary info: dictionary = contacts.en_US ; version = 59 ; date = ?
01-01 00:00:59.935 501 749 W art : Long monitor contention event with owner method=java.io.FileDescriptor libcore.io.Posix.open(java.lang.String, int, int) from Posix.java:4294967294 waiters=0 for 989ms
01-01 00:00:59.950 501 515 I ActivityManager: Force stopping com.android.providers.media appid=10007 user=-1: vold reset
01-01 00:00:59.953 501 607 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:00:59.953 501 512 I AccountManagerService: getTypesVisibleToCaller: isPermitted? false
01-01 00:00:59.959 501 515 W BroadcastQueue: Permission Denial: broadcasting Intent { act=android.net.conn.CONNECTIVITY_CHANGE flg=0x4000010 (has extras) } from null (pid=-1, uid=-1) requires android.permission.CONNECTIVITY_INTERNAL due to registered receiver BroadcastFilter{c67d347 u0 ReceiverList{af2e86 501 system/1000/u0 local:4200361}}
01-01 00:00:59.960 501 519 D Tethering: MasterInitialState.processMessage what=3
01-01 00:01:00.012 501 807 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:00.013 501 515 I ActivityManager: Start proc 941:com.android.externalstorage/u0a12 for broadcast com.android.externalstorage/.MountReceiver
01-01 00:01:00.038 577 712 I vol.Events: writeEvent internal_ringer_mode_changed normal
01-01 00:01:00.070 501 749 W DropBoxManagerService: Dropping: system_app_strictmode (10 > 0 bytes)
01-01 00:01:00.099 166 186 D PermissionCache: checking android.permission.HARDWARE_TEST for uid=1000 => granted (3933 us)
01-01 00:01:00.107 501 512 W art : Long monitor contention event with owner method=boolean libcore.io.Posix.access(java.lang.String, int) from Posix.java:4294967294 waiters=0 for 152ms
01-01 00:01:00.277 577 577 V StatusBar: userId 0 is in the house
01-01 00:01:00.277 501 511 I art : Background sticky concurrent mark sweep GC freed 36049(3MB) AllocSpace objects, 8(152KB) LOS objects, 20% free, 12MB/15MB, paused 22.228ms total 321.033ms
01-01 00:01:00.393 501 807 W art : Long monitor contention event with owner method=long android.database.sqlite.SQLiteConnection.nativeOpen(java.lang.String, int, java.lang.String, boolean, boolean) from SQLiteConnection.java:4294967294 waiters=0 for 259ms
01-01 00:01:00.497 941 941 W System : ClassLoader referenced unknown path: /system/priv-app/ExternalStorageProvider/lib/arm
01-01 00:01:00.555 501 940 I ActivityManager: Start proc 960:com.android.smspush/u0a19 for service com.android.smspush/.WapPushManager
01-01 00:01:00.579 941 941 D ExternalStorage: After updating volumes, found 1 active roots
01-01 00:01:00.603 941 941 D ExternalStorage: After updating volumes, found 1 active roots
01-01 00:01:00.619 941 941 D ExternalStorage: After updating volumes, found 1 active roots
01-01 00:01:00.633 845 935 I LatinIME:LogUtils: Dictionary info: dictionary = userunigram.en_US ; version = 60 ; date = ?
01-01 00:01:00.674 501 513 I ActivityManager: Start proc 967:android.process.media/u0a7 for broadcast com.android.providers.downloads/.DownloadReceiver
01-01 00:01:00.799 860 978 E DcSwitchStateMachine-0: DctController is not ready
01-01 00:01:00.811 501 544 E ConnectivityService: Failed to find Messenger in unregisterNetworkFactory
01-01 00:01:00.815 501 544 D ConnectivityService: Got NetworkFactory Messenger for Telephony
01-01 00:01:00.981 845 935 I LatinIME:LogUtils: Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 60 ; date = ?
01-01 00:01:01.030 960 960 W System : ClassLoader referenced unknown path: /system/app/WAPPushManager/lib/arm
01-01 00:01:01.072 967 967 W System : ClassLoader referenced unknown path: /system/priv-app/DownloadProvider/lib/arm
01-01 00:01:01.095 967 967 W System : ClassLoader referenced unknown path: /system/priv-app/MediaProvider/lib/arm
01-01 00:01:01.218 845 935 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
01-01 00:01:01.584 501 501 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:01.634 501 501 I ActivityManager: Start proc 1000:com.android.deskclock/u0a42 for broadcast com.android.deskclock/com.android.alarmclock.AnalogAppWidgetProvider
01-01 00:01:01.779 166 166 E SurfaceFlinger: GL error 0x0505
01-01 00:01:01.803 501 512 W art : Long monitor contention event with owner method=int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) from WindowManagerService.java:3105 waiters=0 for 828ms
01-01 00:01:01.863 577 577 W KeyguardUpdateMonitor: invalid subId in handleSimStateChange()
01-01 00:01:01.870 870 870 I Choreographer: Skipped 129 frames! The application may be doing too much work on its main thread.
01-01 00:01:01.911 860 860 D CarrierConfigLoader: CarrierConfigLoader has started
01-01 00:01:01.917 860 860 E BluetoothAdapter: Bluetooth binder is null
01-01 00:01:01.977 501 808 I ActivityManager: Start proc 1015:com.android.music/u0a36 for broadcast com.android.music/.MediaButtonIntentReceiver
01-01 00:01:02.066 1000 1000 W System : ClassLoader referenced unknown path: /system/app/DeskClock/lib/arm
01-01 00:01:02.117 166 166 W GLConsumer: [StatusBar] bindTextureImage: clearing GL error: 0x505
01-01 00:01:02.165 870 870 I Choreographer: Skipped 37 frames! The application may be doing too much work on its main thread.
01-01 00:01:02.196 501 520 I ActivityManager: Displayed com.android.launcher/com.android.launcher2.Launcher: +4s727ms
01-01 00:01:02.210 860 860 I Telephony: TtyManager: updateUiTtyMode -1 -> 0
01-01 00:01:02.295 577 577 W KeyguardUpdateMonitor: invalid subId in handleServiceStateChange()
01-01 00:01:02.318 860 860 D TelephonyDebugService: TelephonyDebugService()
01-01 00:01:02.353 860 860 D CarrierConfigLoader: mHandler: 12 phoneId: 0
01-01 00:01:02.391 1015 1015 W System : ClassLoader referenced unknown path: /system/app/Music/lib/arm
01-01 00:01:02.416 860 860 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
01-01 00:01:02.455 501 513 W Telecom : : registerPhoneAccount not allowed on non-voice capable device.
01-01 00:01:02.483 860 860 I Telephony: AccountEntry: Registered phoneAccount: [[ ] PhoneAccount: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e0184adedf913b076626646d3f52c3b49c39ad6d], UserHandle{0} Capabilities: 54 Schemes: tel voicemail ] with handle: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e0184adedf913b076626646d3f52c3b49c39ad6d], UserHandle{0}
01-01 00:01:02.491 860 860 I Telephony: PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.gsm.GSMPhone) {41f1d57}
01-01 00:01:02.507 501 940 W Telecom : : No account found for the calling user
01-01 00:01:02.661 501 940 I ActivityManager: Start proc 1040:com.android.settings/1000 for broadcast com.android.settings/.sim.SimSelectNotification
01-01 00:01:02.666 870 870 I Choreographer: Skipped 63 frames! The application may be doing too much work on its main thread.
01-01 00:01:02.894 1040 1040 W System : ClassLoader referenced unknown path: /system/priv-app/Settings/lib/arm
01-01 00:01:02.912 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:03.420 501 697 D NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]: Probably not a portal: exception java.net.UnknownHostException: Unable to resolve host "connectivitycheck.gstatic.com": No address associated with hostname
01-01 00:01:03.442 501 544 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] validation failed
01-01 00:01:04.228 166 166 E SurfaceFlinger: GL error 0x0505
01-01 00:01:04.316 870 870 I Choreographer: Skipped 198 frames! The application may be doing too much work on its main thread.
01-01 00:01:04.327 501 515 V KeyguardServiceDelegate: *** Keyguard started
01-01 00:01:04.327 501 515 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
01-01 00:01:04.335 501 501 V KeyguardServiceDelegate: *** Keyguard connected (yay!)
01-01 00:01:04.339 501 544 D ConnectivityService: handlePromptUnvalidated 100
01-01 00:01:04.346 501 939 D CryptdConnector: SND -> {2 cryptfs getpw}
01-01 00:01:04.347 135 145 D VoldCryptCmdListener: cryptfs getpw
01-01 00:01:04.347 135 145 I Ext4Crypt: ext4 crypto complete called on /data
01-01 00:01:04.347 135 145 I Ext4Crypt: No master key, so not ext4enc
01-01 00:01:04.354 135 145 I Ext4Crypt: ext4 crypto complete called on /data
01-01 00:01:04.354 135 145 I Ext4Crypt: No master key, so not ext4enc
01-01 00:01:04.355 501 537 D CryptdConnector: RCV <- {200 2 -1}
01-01 00:01:04.357 501 939 D CryptdConnector: SND -> {3 cryptfs clearpw}
01-01 00:01:04.357 135 145 D VoldCryptCmdListener: cryptfs clearpw
01-01 00:01:04.357 135 145 I Ext4Crypt: ext4 crypto complete called on /data
01-01 00:01:04.358 135 145 I Ext4Crypt: No master key, so not ext4enc
01-01 00:01:04.358 501 537 D CryptdConnector: RCV <- {200 3 0}
01-01 00:01:04.445 577 577 D PhoneStatusBar: disable: < EXPAND ICONS* alerts SYSTEM_INFO* BACK HOME RECENT clock SEARCH quick_settings >
01-01 00:01:04.483 577 577 D PhoneStatusBar: disable: < EXPAND ICONS alerts SYSTEM_INFO BACK HOME RECENT clock SEARCH quick_settings >
01-01 00:01:04.570 166 166 W GLConsumer: [StatusBar] bindTextureImage: clearing GL error: 0x505
01-01 00:01:04.693 501 929 W DropBoxManagerService: Dropping: system_app_strictmode (10 > 0 bytes)
01-01 00:01:04.696 501 607 V KeyguardServiceDelegate: **** SHOWN CALLED ****
01-01 00:01:04.775 577 577 D PhoneStatusBar: disable: < expand* ICONS alerts SYSTEM_INFO back* HOME RECENT clock SEARCH quick_settings >
01-01 00:01:05.699 501 520 W WindowManager: Timeout waiting for drawn: undrawn=[Window{7e43081 u0 StatusBar}]
01-01 00:01:05.917 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:06.687 166 166 E SurfaceFlinger: GL error 0x0505
01-01 00:01:06.772 577 577 I Choreographer: Skipped 260 frames! The application may be doing too much work on its main thread.
01-01 00:01:06.785 166 188 I SurfaceFlinger: Boot is finished (43354 ms)
01-01 00:01:06.795 501 520 I SystemServiceManager: Starting phase 1000
01-01 00:01:06.811 501 501 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:06.956 501 1058 I RecoverySystem: No recovery log file
01-01 00:01:06.991 501 1058 W DropBoxManagerService: Dropping: SYSTEM_BOOT (300 > 0 bytes)
01-01 00:01:06.999 501 1058 I BootReceiver: Copying audit failures to DropBox
01-01 00:01:07.000 501 1058 I BootReceiver: Checking for fsck errors
01-01 00:01:07.007 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.060 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.092 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.154 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.164 501 501 I ActivityManager: Start proc 1061:com.android.providers.calendar/u0a1 for broadcast com.android.providers.calendar/.CalendarReceiver
01-01 00:01:07.182 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_03 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.222 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.252 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.371 501 511 I art : Background sticky concurrent mark sweep GC freed 11318(1141KB) AllocSpace objects, 30(1784KB) LOS objects, 19% free, 12MB/15MB, paused 5.131ms total 102.698ms
01-01 00:01:07.373 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.407 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.437 1061 1061 W System : ClassLoader referenced unknown path: /system/priv-app/CalendarProvider/lib/arm
01-01 00:01:07.440 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (300 > 0 bytes)
01-01 00:01:07.451 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.505 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.541 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.602 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.634 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.669 1061 1061 I CalendarProvider2: Created com.android.providers.calendar.CalendarAlarmManager@e1d54bb(com.android.providers.calendar.CalendarProvider2@5f03dd8)
01-01 00:01:07.679 501 939 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:07.683 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.719 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_07 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.782 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.789 501 512 I ActivityManager: Start proc 1079:com.android.managedprovisioning/u0a8 for broadcast com.android.managedprovisioning/.BootReminder
01-01 00:01:07.812 501 1058 I BootReceiver: Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:01:07.851 501 1058 W DropBoxManagerService: Dropping: SYSTEM_TOMBSTONE (10 > 0 bytes)
01-01 00:01:07.947 501 511 I art : Background sticky concurrent mark sweep GC freed 2100(389KB) AllocSpace objects, 37(2MB) LOS objects, 19% free, 12MB/15MB, paused 6.155ms total 69.378ms
01-01 00:01:08.025 1079 1079 W System : ClassLoader referenced unknown path: /system/priv-app/ManagedProvisioning/lib/arm
01-01 00:01:08.113 501 940 I ActivityManager: Start proc 1094:com.android.onetimeinitializer/u0a15 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
01-01 00:01:08.276 1094 1094 W System : ClassLoader referenced unknown path: /system/priv-app/OneTimeInitializer/lib/arm
01-01 00:01:08.282 1094 1094 V OneTimeInitializerRece: OneTimeInitializerReceiver.onReceive
01-01 00:01:08.362 501 513 I ActivityManager: Start proc 1111:com.android.email/u0a24 for broadcast com.android.email/.service.EmailBroadcastReceiver
01-01 00:01:08.580 1111 1111 W System : ClassLoader referenced unknown path: /system/app/Email/lib/arm
01-01 00:01:08.720 1061 1061 I CalendarProvider2: Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
01-01 00:01:08.721 1061 1061 W ContentResolver: Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
01-01 00:01:08.920 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:09.230 501 607 I ActivityManager: Start proc 1126:com.android.exchange/u0a20 for service com.android.exchange/.service.EasService
01-01 00:01:09.307 1111 1131 D ActivityThread: Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
01-01 00:01:09.314 501 940 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:09.317 501 607 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:09.322 1111 1132 D ActivityThread: Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
01-01 00:01:09.504 1126 1126 W System : ClassLoader referenced unknown path: /system/app/Exchange2/lib/arm
01-01 00:01:09.530 845 845 I SystemBroadcastReceiver: Boot has been completed
01-01 00:01:09.530 845 845 I SystemBroadcastReceiver: toggleAppIcon() : FLAG_SYSTEM = true
01-01 00:01:09.603 501 808 I ActivityManager: Start proc 1148:com.android.calendar/u0a41 for broadcast com.android.calendar/.alerts.AlertReceiver
01-01 00:01:09.776 501 513 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:09.779 501 512 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:09.918 1148 1148 W System : ClassLoader referenced unknown path: /system/app/Calendar/lib/arm
01-01 00:01:09.936 1111 1131 W art : Long monitor contention event with owner method=boolean libcore.io.Posix.access(java.lang.String, int) from Posix.java:4294967294 waiters=0 for 607ms
01-01 00:01:09.946 1111 1132 W art : Long monitor contention event with owner method=boolean libcore.io.Posix.access(java.lang.String, int) from Posix.java:4294967294 waiters=1 for 600ms
01-01 00:01:09.948 1111 1138 W art : Long monitor contention event with owner method=boolean libcore.io.Posix.access(java.lang.String, int) from Posix.java:4294967294 waiters=2 for 558ms
01-01 00:01:10.003 501 607 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
01-01 00:01:10.039 501 512 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
01-01 00:01:10.070 1111 1135 W art : Long monitor contention event with owner method=android.database.sqlite.SQLiteDatabase com.android.email.provider.EmailProvider.getDatabase(android.content.Context) from EmailProvider.java:478 waiters=0 for 697ms
01-01 00:01:10.076 501 939 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
01-01 00:01:10.082 501 513 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:10.083 501 808 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:10.094 1111 1162 I Email : Observing account changes for notifications
01-01 00:01:10.176 1126 1126 I Exchange: EasService.onCreate
01-01 00:01:10.193 1111 1147 W art : Long monitor contention event with owner method=android.database.sqlite.SQLiteDatabase com.android.email.provider.EmailProvider.getDatabase(android.content.Context) from EmailProvider.java:478 waiters=1 for 624ms
01-01 00:01:10.197 501 939 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:10.200 501 513 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:10.225 1111 1134 W art : Long monitor contention event with owner method=android.database.sqlite.SQLiteDatabase com.android.email.provider.EmailProvider.getDatabase(android.content.Context) from EmailProvider.java:478 waiters=2 for 196ms
01-01 00:01:10.230 501 512 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:10.235 501 939 I AccountManagerService: getTypesVisibleToCaller: isPermitted? true
01-01 00:01:10.235 1111 1111 E ActivityThread: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@d543520 that was originally bound here
01-01 00:01:10.235 1111 1111 E ActivityThread: android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@d543520 that was originally bound here
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:1092)
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:986)
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1303)
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.app.ContextImpl.bindService(ContextImpl.java:1286)
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.content.ContextWrapper.bindService(ContextWrapper.java:604)
01-01 00:01:10.235 1111 1111 E ActivityThread: at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181)
01-01 00:01:10.235 1111 1111 E ActivityThread: at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224)
01-01 00:01:10.235 1111 1111 E ActivityThread: at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
01-01 00:01:10.235 1111 1111 E ActivityThread: at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
01-01 00:01:10.235 1111 1111 E ActivityThread: at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
01-01 00:01:10.235 1111 1111 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305)
01-01 00:01:10.235 1111 1111 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
01-01 00:01:10.235 1111 1111 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:66)
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.os.Handler.dispatchMessage(Handler.java:102)
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.os.Looper.loop(Looper.java:148)
01-01 00:01:10.235 1111 1111 E ActivityThread: at android.os.HandlerThread.run(HandlerThread.java:61)
01-01 00:01:10.248 1126 1166 I Exchange: RestartPingTask
01-01 00:01:10.286 1148 1148 D ExtensionsFactory: No custom extensions.
01-01 00:01:10.322 1126 1126 I Exchange: RestartPingsTask did not start any pings.
01-01 00:01:10.328 1148 1148 D AlertReceiver: onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x8000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
01-01 00:01:10.328 1126 1126 I Exchange: PSS stopIfIdle
01-01 00:01:10.328 1126 1126 I Exchange: PSS has no active accounts; stopping service.
01-01 00:01:10.331 1126 1126 I Exchange: onDestroy
01-01 00:01:10.347 967 1110 W MediaScanner: Error opening directory '/oem/media/', skipping: No such file or directory.
01-01 00:01:10.372 1000 1000 V AlarmClock: AlarmInitReceiver android.intent.action.BOOT_COMPLETED
01-01 00:01:10.392 1148 1170 D AlertService: 0 Action = android.intent.action.BOOT_COMPLETED
01-01 00:01:10.411 1148 1170 D AlertService: Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
01-01 00:01:10.464 1148 1170 D AlarmScheduler: No events found starting within 1 week.
01-01 00:01:10.494 1000 1174 V AlarmClock: AlarmInitReceiver - Reset timers and clear stopwatch data
01-01 00:01:10.622 1000 1174 V AlarmClock: AlarmInitReceiver finished
01-01 00:01:10.626 1148 1148 D AlertReceiver: onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x10 cmp=com.android.calendar/.alerts.AlertReceiver }
01-01 00:01:10.640 1148 1176 D AlertService: 0 Action = android.intent.action.PROVIDER_CHANGED
01-01 00:01:10.861 967 1110 V MediaScanner: pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@a53b1b4
01-01 00:01:10.862 967 1110 V MediaScanner: /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@a53b1b4
01-01 00:01:11.434 501 697 D NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]: Probably not a portal: exception java.net.UnknownHostException: Unable to resolve host "connectivitycheck.gstatic.com": No address associated with hostname
01-01 00:01:11.434 501 544 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] validation failed
01-01 00:01:11.921 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:13.150 501 1099 W DropBoxManagerService: Dropping: system_app_strictmode (10 > 0 bytes)
01-01 00:01:14.921 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:15.643 1148 1176 I GlobalDismissManager: no sender configured
01-01 00:01:15.643 1148 1176 D AlertService: Beginning updateAlertNotification
01-01 00:01:15.670 1148 1176 D AlertService: No fired or scheduled alerts
01-01 00:01:15.681 1148 1176 D AlertService: Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
01-01 00:01:15.707 1148 1176 D AlarmScheduler: No events found starting within 1 week.
01-01 00:01:16.798 501 522 I PowerManagerService: Going to sleep due to screen timeout (uid 1000)...
01-01 00:01:16.798 501 522 I PowerManagerService: ####NOT allowing to sleep due to screen timeout (uid 1000)...
01-01 00:01:17.921 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:20.923 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:23.923 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:25.409 501 515 I ActivityManager: Waited long enough for: ServiceRecord{605b866 u0 com.android.calendar/.alerts.InitAlarmsService}
01-01 00:01:26.924 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:27.455 501 697 D NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]: Probably not a portal: exception java.net.UnknownHostException: Unable to resolve host "connectivitycheck.gstatic.com": No address associated with hostname
01-01 00:01:27.456 501 544 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] validation failed
01-01 00:01:29.924 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:32.924 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:35.925 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:38.925 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:40.410 1148 1173 D InitAlarmsService: Clearing and rescheduling alarms.
01-01 00:01:41.926 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:44.926 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:45.435 501 528 I PowerManagerService: Going to sleep due to screen timeout (uid 1000)...
01-01 00:01:45.435 501 528 I PowerManagerService: ####NOT allowing to sleep due to screen timeout (uid 1000)...
01-01 00:01:45.444 501 808 I PowerManagerService: Going to sleep due to screen timeout (uid 1000)...
01-01 00:01:45.445 501 808 I PowerManagerService: ####NOT allowing to sleep due to screen timeout (uid 1000)...
01-01 00:01:45.452 501 501 I PowerManagerService: Going to sleep due to screen timeout (uid 1000)...
01-01 00:01:45.452 501 501 I PowerManagerService: ####NOT allowing to sleep due to screen timeout (uid 1000)...
01-01 00:01:45.480 501 939 I PowerManagerService: Going to sleep due to screen timeout (uid 1000)...
01-01 00:01:45.481 501 939 I PowerManagerService: ####NOT allowing to sleep due to screen timeout (uid 1000)...
01-01 00:01:47.926 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:50.928 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:53.928 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:56.317 501 542 E WifiMonitor: startMonitoring(wlan0) failed!
01-01 00:01:56.324 501 542 D WIFI : Registering NetworkFactory
01-01 00:01:56.324 501 542 D WIFI_UT : Registering NetworkFactory
01-01 00:01:56.324 501 544 D ConnectivityService: Got NetworkFactory Messenger for WIFI
01-01 00:01:56.325 501 544 D ConnectivityService: Got NetworkFactory Messenger for WIFI_UT
01-01 00:01:56.325 501 542 E WifiStateMachine: Failed to setup control channel, restart supplicant
01-01 00:01:56.326 501 542 E WifiMonitor: killSupplicant p2pfalse init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-01 00:01:56.833 501 542 D WIFI : got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 30
01-01 00:01:56.833 501 542 D WIFI_UT : got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 30
01-01 00:01:56.928 570 570 E sdcard : missing packages.list; retrying
01-01 00:01:59.494 501 697 D NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]: Probably not a portal: exception java.net.UnknownHostException: Unable to resolve host "connectivitycheck.gstatic.com": No address associated with hostname
01-01 00:01:59.495 501 544 D ConnectivityService: NetworkAgentInfo [Ethernet () - 100] validation failed
01-01 00:01:59.929 570 570 E sdcard : missing packages.list; retrying
01-01 00:02:00.001 501 528 I PowerManagerService: Going to sleep due to screen timeout (uid 1000)...
01-01 00:02:00.001 501 528 I PowerManagerService: ####NOT allowing to sleep due to screen timeout (uid 1000)...
01-01 00:02:00.241 501 501 I PowerManagerService: Going to sleep due to screen timeout (uid 1000)...
01-01 00:02:00.241 501 501 I PowerManagerService: ####NOT allowing to sleep due to screen timeout (uid 1000)...
01-01 00:02:01.640 167 499 D CommandListener: Setting iface cfg
01-01 00:02:01.640 167 499 D CommandListener: Trying to bring down wlan0
01-01 00:02:01.665 167 499 D CommandListener: Clearing all IP addresses on wlan0
01-01 00:02:01.668 501 542 E WifiMonitor: killSupplicant p2pfalse init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-01 00:02:01.670 501 542 D wifi : Can not initialize the vendor function pointer table
01-01 00:02:01.670 501 542 E WifiNative-HAL: Could not start hal
01-01 00:02:01.670 501 542 E WifiStateMachine: Failed to start HAL
01-01 00:02:01.791 501 542 D WifiMonitor: startMonitoring(wlan0) with mConnected = false
01-01 00:02:01.824 1193 1193 D wpa_supplicant: wpa_supplicant v2.5-devel-6.0
01-01 00:02:01.824 1193 1193 D wpa_supplicant: random: Trying to read entropy from /dev/random
01-01 00:02:01.824 1193 1193 I wpa_supplicant: Successfully initialized wpa_supplicant
01-01 00:02:01.825 1193 1193 D wpa_supplicant: Initializing interface 'wlan0' conf '/data/misc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
01-01 00:02:01.825 1193 1193 D wpa_supplicant: Configuration file '/data/misc/wifi/wpa_supplicant.conf' -> '/data/misc/wifi/wpa_supplicant.conf'
01-01 00:02:01.825 1193 1193 D wpa_supplicant: Reading configuration file '/data/misc/wifi/wpa_supplicant.conf'
01-01 00:02:01.827 1193 1193 D wpa_supplicant: update_config=1
01-01 00:02:01.827 1193 1193 D wpa_supplicant: ctrl_interface='/data/misc/wifi/sockets'
01-01 00:02:01.827 1193 1193 D wpa_supplicant: ap_scan=1
01-01 00:02:01.827 1193 1193 D wpa_supplicant: fast_reauth=1
01-01 00:02:01.827 1193 1193 D wpa_supplicant: persistent_reconnect=1
01-01 00:02:01.827 1193 1193 D wpa_supplicant: disassoc_low_ack=1
01-01 00:02:01.828 1193 1193 E wpa_supplicant: Line 8: unknown global field 'concurrent_sched_scan=1'.
01-01 00:02:01.828 1193 1193 E wpa_supplicant: Line 8: Invalid configuration line 'concurrent_sched_scan=1'.
01-01 00:02:01.831 1193 1193 I wpa_supplicant: rfkill: Cannot open RFKILL control device
01-01 00:02:01.831 1193 1193 D wpa_supplicant: nl80211: RFKILL status not available
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:1
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:5
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:2
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:4
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported cipher 00-14-72:1
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supports Probe Response offload in AP mode
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Using driver-based off-channel TX
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=0
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=1
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x80028 subcmd=2
01-01 00:02:01.832 1193 1193 D wpa_supplicant: nl80211: Supported vendor event: vendor_id=0x80028 subcmd=0
01-01 00:02:01.833 1193 1193 D wpa_supplicant: nl80211: Supported vendor event: vendor_id=0x80028 subcmd=1
01-01 00:02:01.833 1193 1193 D wpa_supplicant: nl80211: Use separate P2P group interface (driver advertised support)
01-01 00:02:01.833 1193 1193 D wpa_supplicant: nl80211: Enable multi-channel concurrent (driver advertised support)
01-01 00:02:01.833 1193 1193 D wpa_supplicant: nl80211: use P2P_DEVICE support
01-01 00:02:01.833 1193 1193 D wpa_supplicant: nl80211: interface wlan0 in phy phy0
01-01 00:02:01.833 1193 1193 D wpa_supplicant: nl80211: Set mode ifindex 4 iftype 2 (STATION)
01-01 00:02:01.860 1193 1193 D wpa_supplicant: nl80211: Subscribe to mgmt frames with non-AP handle 0xb6a4b0c0
01-01 00:02:01.860 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=0104
01-01 00:02:01.860 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=040a
01-01 00:02:01.860 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=040b
01-01 00:02:01.860 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=040c
01-01 00:02:01.860 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=040d
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=090a
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=090b
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=090c
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=090d
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=0409506f9a09
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=7f506f9a09
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=0801
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=06
01-01 00:02:01.861 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=0a07
01-01 00:02:01.862 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=0a11
01-01 00:02:01.862 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=0a1a
01-01 00:02:01.862 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=1101
01-01 00:02:01.862 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=1102
01-01 00:02:01.862 1193 1193 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb6a4b0c0 match=0505
01-01 00:02:02.811 501 607 I MediaFocusControl: AudioFocus abandonAudioFocus() from android.media.AudioManager@b496416com.android.music.MediaPlaybackService$3@9c28197
01-01 00:02:02.849 501 515 I ActivityManager: Start proc 1194:com.android.musicfx/u0a10 for broadcast com.android.musicfx/.ControlPanelReceiver
01-01 00:02:02.929 570 570 E sdcard : missing packages.list; retrying
01-01 00:02:03.118 1194 1194 W System : ClassLoader referenced unknown path: /system/priv-app/MusicFX/lib/arm
01-01 00:02:03.134 1194 1194 V MusicFXControlPanelReceiver: onReceive
01-01 00:02:03.135 1194 1194 V MusicFXControlPanelReceiver: Action: android.media.action.CLOSE_AUDIO_EFFECT_CONTROL_SESSION
01-01 00:02:03.135 1194 1194 V MusicFXControlPanelReceiver: Package name: com.android.music
01-01 00:02:03.135 1194 1194 V MusicFXControlPanelReceiver: Audio session: 4
01-01 00:02:03.138 1194 1194 V MusicFXControlPanelEffect: closeSession(android.app.ReceiverRestrictedContext@3647d9f, com.android.music, 4)
01-01 00:02:05.929 570 570 E sdcard : missing packages.list; retrying
01-01 00:02:06.756 1193 1193 E wpa_supplicant: Could not set interface wlan0 flags (UP): Connection timed out
01-01 00:02:06.756 1193 1193 E wpa_supplicant: nl80211: Could not set interface 'wlan0' UP
01-01 00:02:06.756 1193 1193 I wpa_supplicant: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
01-01 00:02:06.756 1193 1193 D wpa_supplicant: nl80211: Remove monitor interface: refcount=0
01-01 00:02:06.756 1193 1193 D wpa_supplicant: netlink: Operstate: ifindex=4 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
01-01 00:02:06.756 1193 1193 D wpa_supplicant: nl80211: Set mode ifindex 4 iftype 2 (STATION)
01-01 00:02:06.756 1193 1193 D wpa_supplicant: nl80211: Unsubscribe mgmt frames handle 0x3e2c3849 (mode change)
01-01 00:02:06.756 1193 1193 E wpa_supplicant: wlan0: Failed to initialize driver interface
Will you please let me know why wpa_supplicant: Could not set interface wlan0 flags (UP): Connection timed out
Thanks and Regards,
Firdosh
