WL1835MOD: FCC/ETSI Qualification
Part Number: WL1835MOD
We are using VAR-SOM-SOLO module which has an inbuilt WIFi with part no.-
WL1835MOD.
Please clarify the below details.
which type of modulation technique?
Adaptive equipment or Non adaptive equipment .
FCC/ETSI Qualification details
  • Please check below link for certifications -
    www.ti.com/.../wl18xx-CERTIFICATION
    The link provided by Hari will allow you to download our certification reports for the module. In here you can find the info you requested.
    1) Modulation techniques - We cover DSSS, CCK, OFDM and MCS rates
    2) We are adaptive (look before talk) and implement CCA (Clear channel assessment)
    3) For FCC/ETSI qualification, you can refer to the reports.
    Riz
  • I required the details of wifi module like which type of equipment it is FBE or LBE etc. and further detail information.
    Within each of the reports (FCC, IC, CE, Japan), there are details information of the wifi module. I am not sure what information you are missing. If you can provide a detailed list we can point you to the information or provide the details.
    Riz
    Can you please clarify my queries regarding WL1837MODGIMOC. Below are the queries:
    1. The type of wide band modulation used?
    2. Adaptive equipment or Non- Adaptive Equipment?
    3. For adaptive equipment: whether LBT based DAA or non-LBT based DAA?
    4. for LBT based adaptive equipment whether FBE or LBE/
    5. Receiver Category?
    6. Transmit operating mode?
    7. Operating frequency range of the equipment?
    8. the type of the equipment, for example: stand-alone equipment, plug-in radio equipment, combined equipment, etc?
    9. the operational environmental profile?
    10. the intended combination(s) of the radio equipment power settings and one or more antenna assemblies, their corresponding maximum gain(s) (G) and the resulting e.i.r.p. levels taking also into account the beamforming gain (Y) if applicable  For equipment where in receive mode, the antenna assembly gain and/or beamforming gain is different from the transmit mode, the antenna assemblies, their corresponding maximum gain(s) (G) and the beamforming gain (Y) that apply in the receive mode?
    11. any specific test modes available which can be used to facilitate testing?
    12. the nominal voltages of the stand-alone radio equipment or the nominal voltages of the host equipment or combined equipment in case of plug-in equipment?
    13. whether or not the equipment supports a geo-location capability?
    14. the minimum performance criteria that corresponds to the intended use of the equipment?
    Please find my responses below. Note that some of the information will be at the product level
    1. The type of wide band modulation used? -> We are 20MHZ and 40MHz Wifi signas, DSSS, CCK, OFDM, MCS rates
    2. Adaptive equipment or Non- Adaptive Equipment? -> Adaptive
    3. For adaptive equipment: whether LBT based DAA or non-LBT based DAA? -> LBT
    4. for LBT based adaptive equipment whether FBE or LBE/ -> LBE
    5. Receiver Category? -> You can get this information from our Canada certificate in the previous link I sent you.
    6. Transmit operating mode? -> a/b/g/n
    7. Operating frequency range of the equipment? -> This will be up to you end product. you can see our test reports for 2.4GHZ and 5GHZ frequency bands for your specific region.
    8. the type of the equipment, for example: stand-alone equipment, plug-in radio equipment, combined equipment, etc? -> Customer question at product level.
    9. the operational environmental profile? -> Customer question at product level.
    10. the intended combination(s) of the radio equipment power settings and one or more antenna assemblies, their corresponding maximum gain(s) (G) and the resulting e.i.r.p. levels taking also into account the beamforming gain (Y) if applicable  For equipment where in receive mode, the antenna assembly gain and/or beamforming gain is different from the transmit mode, the antenna assemblies, their corresponding maximum gain(s) (G) and the beamforming gain (Y) that apply in the receive mode? -> no beam forming
    11. any specific test modes available which can be used to facilitate testing? -> We use calibrator via the Host or RTTT for gui based control.
    12. the nominal voltages of the stand-alone radio equipment or the nominal voltages of the host equipment or combined equipment in case of plug-in equipment? -> Customer question at the product level.
    13. whether or not the equipment supports a geo-location capability? -> depending on how you setup the SW. Out of the box our module is no. We support WW mode
    14. the minimum performance criteria that corresponds to the intended use of the equipment? -> this is a customer product level question.
    Riz
    Kindly clarify the below details for WL1837MODGIMOC as well:
    1) No of Transmit chain?
    2) adaptive Equipment without the possibility to switch to a non-adaptive mode or  adaptive Equipment which can also operate in a non-adaptive mode?
    3) The maximum Channel Occupancy Time implemented by the equipment:?
    4) The worst case operational mode for each of the following tests:
    a) RF Output Power
    b) Adaptivity & Receiver Blocking
    c) Transmitter unwanted emissions in the OOB domain
    d) Transmitter unwanted emissions in the spurious domain
    e)Receiver spurious emissions
    f)Power Spectral Density
    5)  Which is the transmit operating modes:
    a)Operating mode 1: Single Antenna Equipment
    b)Operating mode 2: Smart Antenna Systems - Multiple Antennas without beam forming
    c) Operating mode 3: Smart Antenna Systems - Multiple Antennas with beam forming
    6) In case of Smart Antenna Systems:
    • The number of Receive chains: ...........
    • The number of Transmit chains:
    7) Operating Frequency Range 1:
    • Operating Frequency Range 2:
    8) Nominal Channel Bandwidth 1:
    • Nominal Channel Bandwidth 2:
    9)  The intended combination(s) of the radio equipment power settings and one or more antenna assemblies and
    their corresponding e.i.r.p. levels:
    Dedicated Antennas (equipment with antenna connector)
    Single power level with corresponding antenna(s)
    Multiple power settings and corresponding antenna(s)
    Number of different Power Levels: .............
    Power Level 1: ............. dBm
    Power Level 2: ............. dBm
    Power Level 3: ............. dBm
    10) Describe the test modes available which can facilitate testing:
    11) The equipment type (e.g. Bluetooth®, IEEE 802.11™ [i.3], IEEE 802.15.4™ [i.4], proprietary, etc.):
    12) Describe the minimum performance criteria that apply to the equipment based on receiver category.
    Can you please share the link of Canada certificate once again.
    Ruchita Shreeram Mishra
  • Hi Ruchita,
    My apologies for the delay. Please find my responses below for the WL1837MODGIMOC:
    1) No of Transmit chain? -> Can be up to 2 depending on how you configure the device. We can support dual antenna. See the datasheet for more detaisl and a block diagram.
    2) adaptive Equipment without the possibility to switch to a non-adaptive mode or  adaptive Equipment which can also operate in a non-adaptive mode? -> adaptive
    3) The maximum Channel Occupancy Time implemented by the equipment:? -> 25mS
    4) The worst case operational mode for each of the following tests: -> Please see the test reports that can be found at www.ti.com/.../wl18xx-certification
    a) RF Output Power
    5)  Which is the transmit operating modes: -> This depends if you are using 2 antennas or one. See the datasheet. We do not support beam forming.
    7) Operating Frequency Range 1: -> See the test reports. We support 2,4GHz band and 5GHZ band
    8) Nominal Channel Bandwidth 1: -> We support 20MHz and 40MHz. This depends on your implementation.
    their corresponding e.i.r.p. levels: -> this is dependent on your product.
    10) Describe the test modes available which can facilitate testing: -> We have RTTT or calibrator. This is the same for the WL1835MOD
    11) The equipment type (e.g. Bluetooth®, IEEE 802.11™ [i.3], IEEE 802.15.4™ [i.4], proprietary, etc.): -> We support 2.4-GHz Wifi, 5-GHz Wifi, BLE, EDR, BT classic.
    12) Describe the minimum performance criteria that apply to the equipment based on receiver category. -> See the test reports at Please see the test reports that can be found at http://www.ti.com/tool/wl18xx-certification. Within here you can find the Canada reports for WL18MODGI.
