Other Parts Discussed in Thread: , WL1835MOD
What is the purpose of “PerSubBandRxTraceLoss” parameters in .ini file (swru422a):
- “for the correct RSSI reading on the solution boundary” -> what is the benefit in practice compared to plain RSSI seen by the SoC?
- There are module specific (e.g. WL1837MOD) .ini files available with different PerSubBandRxTraceLoss configuration -> does it mean that each particular configuration normalizes the RSSI per sub band to the antenna port of the module (=solution boundary), instead of the SoC?
- If PerSubBandRxTraceLoss is set to zero, is plain RSSI seen by the SoC reported?
