U-Boot SPL 2013.10-g23ae3d7-dirty (Jan 06 2020 - 16:17:27) MUX CONF REGSReset DSPreading u-boot.img reading u-boot.img U-Boot 2013.10-g23ae3d7-dirty (Jan 06 2020 - 16:17:27)-MMC I2C: ready DRAM: 128 MiB NAND: 512 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Using default environment Hit any key to stop autoboot: 0 Booting from SD card 2476152 bytes read in 180 ms (13.1 MiB/s) 38728 bytes read in 12 ms (3.1 MiB/s) Kernel image @ 0x80200000 [ 0x000000 - 0x25c878 ] ## Flattened Device Tree blob at 80f80000 Booting using the fdt blob at 0x80f80000 Loading Device Tree to 87b3c000, end 87b48747 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.4.19+ (jayawar@jayawar-pc) (gcc version 7.4.0 (Buildroot 2019.02.1-ga3e6942-dirty) ) #32 PREEMPT Mon Jan 6 14:22:58 EET 2020 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: Variscite AM335x SOM [ 0.000000] cma: Reserved 48 MiB at 0x84800000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 [ 0.000000] Kernel command line: root=/dev/mmcblk0p2 ro console=ttyS0,115200n8 mtdparts=8000000.nand:128k(LD1),896k(LD2),-(UBI) [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes) [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Memory: 73424K/131072K available (4659K kernel code, 214K rwdata, 1712K rodata, 220K init, 227K bss, 8496K reserved, 49152K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xc8800000 - 0xff800000 ( 880 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0640f7c (6372 kB) [ 0.000000] .init : 0xc0641000 - 0xc0678000 ( 220 kB) [ 0.000000] .data : 0xc0678000 - 0xc06ada90 ( 215 kB) [ 0.000000] .bss : 0xc06ada90 - 0xc06e69ec ( 228 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000018] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000045] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000058] OMAP clocksource: timer1 at 24000000 Hz [ 0.000264] clocksource_probe: no matching clocksources found [ 0.000483] Console: colour dummy device 80x30 [ 0.000529] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032) [ 0.058833] pid_max: default: 32768 minimum: 301 [ 0.058971] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.058987] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.059644] CPU: Testing write buffer coherency: ok [ 0.060045] Setting up static identity map for 0x80008200 - 0x80008258 [ 0.062601] devtmpfs: initialized [ 0.078178] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.093906] omap_hwmod: debugss: _wait_target_disable failed [ 0.137566] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.141493] pinctrl core: initialized pinctrl subsystem [ 0.142899] NET: Registered protocol family 16 [ 0.145353] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.168889] cpuidle: using governor ladder [ 0.198877] cpuidle: using governor menu [ 0.204321] OMAP GPIO hardware version 0.1 [ 0.206827] omap_gpio 481ae000.gpio: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/gpio_pins_default, deferring probe [ 0.216435] No ATAGs? [ 0.216474] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.234037] edma 49000000.edma: TI EDMA DMA engine driver [ 0.237689] usbcore: registered new interface driver usbfs [ 0.237804] usbcore: registered new interface driver hub [ 0.237938] usbcore: registered new device driver usb [ 0.238396] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe [ 0.238453] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe [ 0.238629] pps_core: LinuxPPS API ver. 1 registered [ 0.238641] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.238681] PTP clock support registered [ 0.239733] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.240136] Advanced Linux Sound Architecture Driver Initialized. [ 0.241132] clocksource: Switched to clocksource timer1 [ 0.254009] NET: Registered protocol family 2 [ 0.254823] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.254856] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.254880] TCP: Hash tables configured (established 1024 bind 1024) [ 0.254964] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.254991] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.255177] NET: Registered protocol family 1 [ 0.255887] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available [ 0.258188] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.272279] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 0.272317] io scheduler noop registered [ 0.272337] io scheduler deadline registered [ 0.272385] io scheduler cfq registered (default) [ 0.273820] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.350795] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.355605] console [ttyS0] disabled [ 0.355708] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 126, base_baud = 3000000) is a 8250 [ 0.888479] console [ttyS0] enabled [ 0.893444] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 127, base_baud = 3000000) is a 8250 [ 0.903634] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 128, base_baud = 3000000) is a 8250 [ 0.914555] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [ 0.923579] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.930153] ehci-omap: OMAP-EHCI Host Controller driver [ 0.935650] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.941926] ohci-platform: OHCI generic platform driver [ 0.947430] usbcore: registered new interface driver emi26 - firmware loader [ 0.956682] 47401b00.usb-phy supply vcc not found, using dummy regulator [ 0.993489] musb-hdrc musb-hdrc.0.auto: Failed to request rx1. [ 0.999442] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517 [ 1.015733] i2c /dev entries driver [ 1.020657] cpuidle: enable-method property 'ti,am3352' found operations [ 1.027805] sdhci: Secure Digital Host Controller Interface driver [ 1.034046] sdhci: Copyright(c) Pierre Ossman [ 1.072170] omap_hsmmc 47810000.mmc: no pinctrl state for hs mode [ 1.078876] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 1.118735] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.129032] mmc0: new high speed SDHC card at address 5048 [ 1.135245] mmcblk0: mmc0:5048 SD16G 14.4 GiB [ 1.141629] mmcblk0: p1 p2 [ 1.221485] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.227996] ledtrig-cpu: registered to indicate activity on CPUs [ 1.234130] mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 1.245091] usbcore: registered new interface driver snd-usb-audio [ 1.256120] NET: Registered protocol family 10 [ 1.263338] NET: Registered protocol family 17 [ 1.267976] omap_voltage_late_init: Voltage driver support not added [ 1.291449] tps65910 0-002d: No interrupt support, no core IRQ [ 1.321212] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 1.328054] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz [ 1.343650] asoc-simple-card sound0: dmic-hifi <-> 48038000.mcasp mapping ok [ 1.352131] vdd_mpu: supplied by vbat [ 1.357208] hctosys: unable to open rtc device (rtc0) [ 1.366806] wlan-en-regulator: disabling [ 1.371240] ALSA device list: [ 1.374235] #0: cx2092x [ 1.381079] VFS: Mounted root (ext2 filesystem) readonly on device 179:2. [ 1.389910] devtmpfs: mounted [ 1.393364] Freeing unused kernel memory: 220K (c0641000 - c0678000) [ 1.399751] This architecture does not have kernel memory protection. starting pid 53, tty '': '/etc/startup' + mount -t proc none /proc + mount -t sysfs none /sys + mount -t tmpfs none /tmp + mount -t tmpfs none /run + mkdir -p /dev/pts /dev/shm + mount -t devpts none /dev/pts + mount -t tmpfs none /dev/shm + test -e /etc/sdcard + mount -o remount,rw / + ip link set lo up + modprobe -a hci_uart [ 1.609243] Bluetooth: Core ver 2.21 [ 1.613050] NET: Registered protocol family 31 [ 1.617519] Bluetooth: HCI device and connection manager initialized [ 1.623950] Bluetooth: HCI socket layer initialized [ 1.628860] Bluetooth: L2CAP socket layer initialized [ 1.633994] Bluetooth: SCO socket layer initialized [ 1.645395] Bluetooth: HCI UART driver ver 2.3 [ 1.649876] Bluetooth: HCI UART protocol H4 registered [ 1.655169] Bluetooth: HCI UART protocol LL registered + modprobe -a snd_soc_davinci_mcasp snd_soc_tlv320aic3x snd_soc_simple_card modprobe: module snd_soc_davinci_mcasp not found in modules.dep modprobe: module snd_soc_tlv320aic3x not found in modules.dep modprobe: module snd_soc_simple_card not found in modules.dep + modprobe -a phy-am335x musb_am335x musb_dsps modprobe: module phy-am335x not found in modules.dep modprobe: module musb_am335x not found in modules.dep modprobe: module musb_dsps not found in modules.dep + modprobe snd_usb_audio modprobe: module snd_usb_audio not found in modules.dep + modprobe -a wlcore wlcore_sdio wl18xx modprobe: module wlcore not found in modules.dep modprobe: module wlcore_sdio not found in modules.dep modprobe: module wl18xx not found in modules.dep + sleep 1 + test -c /dev/snd/controlC0 + amixer -c 0 set PCM '100%' amixer: Unable to find simple control 'PCM',0 + test -c /dev/snd/controlC1 starting pid 70, tty '': '/etc/rc/udevd' starting pid 71, tty '': '/etc/rc/dbus' starting pid 72, tty '': '-/etc/rc/shell' [ 2.867842] udevd[70]: starting version 3.2.7 [ 2.879355] random: udevd: uninitialized urandom read (16 bytes read, 19 bits of entropy available) [ 2.890693] udevd[70]: starting eudev-3.2.7 [ 2.930045] random: dbus-daemon: uninitialized urandom read (12 bytes read, 20 bits of entropy available) [ 2.960690] random: dbus-daemon: uninitialized urandom read (12 bytes read, 20 bits of entropy available) ~ # ~ # ~ # lsmod Module Size Used by Not tainted hci_uart 10906 0 bluetooth 297127 1 hci_uart rfkill 19877 1 bluetooth ~ # cd lib/ /lib # ls firmware libblkid.so.1.1.0 libudev.so.1 ld-musl-armhf.so.1 libc.so libudev.so.1.6.3 libatomic.so libgcc_s.so libuuid.so.1 libatomic.so.1 libgcc_s.so.1 libuuid.so.1.3.0 libatomic.so.1.2.0 libmount.so.1 modules libblkid.so.1 libmount.so.1.1.0 /lib # cd modules/ /lib/modules # ls 4.4.19+ /lib/modules # cd 4.4.19\+/ /lib/modules/4.4.19+ # ls kernel modules.builtin modules.devname modules.softdep modules.alias modules.dep modules.order modules.symbols /lib/modules/4.4.19+ # cd kernel/ /lib/modules/4.4.19+/kernel # ls arch crypto drivers lib net /lib/modules/4.4.19+/kernel # cd net/ /lib/modules/4.4.19+/kernel/net # ls bluetooth mac80211 rfkill wireless /lib/modules/4.4.19+/kernel/net # cd wireless/ /lib/modules/4.4.19+/kernel/net/wireless # ls cfg80211.ko /lib/modules/4.4.19+/kernel/net/wireless # insmod cfg80211.ko ^C /lib/modules/4.4.19+/kernel/net/wireless # ^C /lib/modules/4.4.19+/kernel/net/wireless # insmod cfg80211.ko /lib/modules/4.4.19+/kernel/net/wireless # cd ..\ > ^C > cd ^C > ^C > ^C > \ > /lib/modules/4.4.19+/kernel/net # ls bluetooth mac80211 rfkill wireless /lib/modules/4.4.19+/kernel/net # cd mac80211/ /lib/modules/4.4.19+/kernel/net/mac80211 # ls mac80211.ko /lib/modules/4.4.19+/kernel/net/mac80211 # insmod mac80211.ko /lib/modules/4.4.19+/kernel/net/mac80211 # cd ~ ~ # ls bin etc oya sys var boot lib proc tmp dev lost+found run usr ~ # [ 265.964799] random: nonblocking pool is initialized ~ # cd oya/ /oya # ls audio evk-nebula-generic-7.76.8.01-32m-padded.sfs i2c_flash iflash.bin update wifi /oya # cd wifi/ /oya/wifi # ls bcm43438.bin cywdhd.ko nvram.txt readme.txt /oya/wifi # cat readme.txt INSTRUCTIONS make KDIR=/path/to/kernel/ ARCH=arm CROSS_COMPILE=/path/to/toolchain # path to tool chain should be `~/oya-system/buildroot/output/host/bin/arm-buildroot-linux-musleabihf-` (if not available global) insmod cywdhd.ko firmware_path=../bcm43438.bin nvram_path=../nvram.txt nvram.txt: nvram configuration file bcm43438.bin: module firmware /oya/wifi # insmod cywdhd.ko firmware_path=../bcm43438.bin nvram_path=../nvram.t xt [ 312.139672] cywdhd: disagrees about version of symbol cfg80211_inform_bss_frame_data [ 312.147577] cywdhd: Unknown symbol cfg80211_inform_bss_frame_data (err -22) [ 312.154615] cywdhd: disagrees about version of symbol alloc_etherdev_mqs [ 312.161368] cywdhd: Unknown symbol alloc_etherdev_mqs (err -22) [ 312.167364] cywdhd: disagrees about version of symbol sdio_release_host [ 312.174111] cywdhd: Unknown symbol sdio_release_host (err -22) [ 312.179992] cywdhd: disagrees about version of symbol sdio_disable_func [ 312.186662] cywdhd: Unknown symbol sdio_disable_func (err -22) [ 312.192588] cywdhd: disagrees about version of symbol sdio_set_block_size [ 312.199408] cywdhd: Unknown symbol sdio_set_block_size (err -22) [ 312.205491] cywdhd: disagrees about version of symbol __nlmsg_put [ 312.211637] cywdhd: Unknown symbol __nlmsg_put (err -22) [ 312.217007] cywdhd: disagrees about version of symbol sock_wfree [ 312.223058] cywdhd: Unknown symbol sock_wfree (err -22) [ 312.228388] cywdhd: disagrees about version of symbol cfg80211_scan_done [ 312.235138] cywdhd: Unknown symbol cfg80211_scan_done (err -22) [ 312.241166] cywdhd: disagrees about version of symbol sdio_claim_host [ 312.247636] cywdhd: Unknown symbol sdio_claim_host (err -22) [ 312.253351] cywdhd: disagrees about version of symbol sdio_memcpy_fromio [ 312.260083] cywdhd: Unknown symbol sdio_memcpy_fromio (err -22) [ 312.266059] cywdhd: disagrees about version of symbol consume_skb [ 312.272195] cywdhd: Unknown symbol consume_skb (err -22) [ 312.277545] cywdhd: disagrees about version of symbol sdio_register_driver [ 312.284465] cywdhd: Unknown symbol sdio_register_driver (err -22) [ 312.290599] cywdhd: disagrees about version of symbol sdio_readw [ 312.296647] cywdhd: Unknown symbol sdio_readw (err -22) [ 312.302013] cywdhd: disagrees about version of symbol unregister_netdev [ 312.308659] cywdhd: Unknown symbol unregister_netdev (err -22) [ 312.314551] cywdhd: disagrees about version of symbol cfg80211_remain_on_channel_expired [ 312.322693] cywdhd: Unknown symbol cfg80211_remain_on_channel_expired (err -22) [ 312.330212] cywdhd: disagrees about version of symbol __netlink_kernel_create [ 312.337398] cywdhd: Unknown symbol __netlink_kernel_create (err -22) [ 312.343823] cywdhd: disagrees about version of symbol sdio_writew [ 312.349943] cywdhd: Unknown symbol sdio_writew (err -22) [ 312.355335] cywdhd: disagrees about version of symbol sdio_memcpy_toio [ 312.361909] cywdhd: Unknown symbol sdio_memcpy_toio (err -22) [ 312.367729] cywdhd: disagrees about version of symbol cfg80211_new_sta [ 312.374302] cywdhd: Unknown symbol cfg80211_new_sta (err -22) [ 312.380108] cywdhd: disagrees about version of symbol unregister_netdevice_queue [ 312.387553] cywdhd: Unknown symbol unregister_netdevice_queue (err -22) [ 312.394238] cywdhd: disagrees about version of symbol __pskb_copy_fclone [ 312.400969] cywdhd: Unknown symbol __pskb_copy_fclone (err -22) [ 312.406947] cywdhd: disagrees about version of symbol cfg80211_disconnected [ 312.413956] cywdhd: Unknown symbol cfg80211_disconnected (err -22) [ 312.420200] cywdhd: disagrees about version of symbol sdio_f0_readb [ 312.426511] cywdhd: Unknown symbol sdio_f0_readb (err -22) [ 312.432047] cywdhd: disagrees about version of symbol eth_type_trans [ 312.438430] cywdhd: Unknown symbol eth_type_trans (err -22) [ 312.444059] cywdhd: disagrees about version of symbol wiphy_new_nm [ 312.450268] cywdhd: Unknown symbol wiphy_new_nm (err -22) [ 312.455746] cywdhd: disagrees about version of symbol cfg80211_ready_on_channel [ 312.463104] cywdhd: Unknown symbol cfg80211_ready_on_channel (err -22) [ 312.469684] cywdhd: disagrees about version of symbol kfree_skb [ 312.475643] cywdhd: Unknown symbol kfree_skb (err -22) [ 312.480827] cywdhd: disagrees about version of symbol sdio_release_irq [ 312.487400] cywdhd: Unknown symbol sdio_release_irq (err -22) [ 312.493258] cywdhd: disagrees about version of symbol wiphy_register [ 312.499643] cywdhd: Unknown symbol wiphy_register (err -22) [ 312.505282] cywdhd: disagrees about version of symbol __cfg80211_alloc_reply_skb [ 312.512729] cywdhd: Unknown symbol __cfg80211_alloc_reply_skb (err -22) [ 312.519387] cywdhd: disagrees about version of symbol __cfg80211_alloc_event_skb [ 312.526832] cywdhd: Unknown symbol __cfg80211_alloc_event_skb (err -22) [ 312.533519] cywdhd: disagrees about version of symbol __alloc_skb [ 312.539640] cywdhd: Unknown symbol __alloc_skb (err -22) [ 312.545004] cywdhd: disagrees about version of symbol cfg80211_put_bss [ 312.551577] cywdhd: Unknown symbol cfg80211_put_bss (err -22) [ 312.557363] cywdhd: disagrees about version of symbol cfg80211_roamed [ 312.563847] cywdhd: Unknown symbol cfg80211_roamed (err -22) [ 312.569546] cywdhd: disagrees about version of symbol cfg80211_ch_switch_notify [ 312.576904] cywdhd: Unknown symbol cfg80211_ch_switch_notify (err -22) [ 312.583531] cywdhd: disagrees about version of symbol sdio_set_host_pm_flags [ 312.590612] cywdhd: Unknown symbol sdio_set_host_pm_flags (err -22) [ 312.596933] cywdhd: disagrees about version of symbol sdio_f0_writeb [ 312.603331] cywdhd: Unknown symbol sdio_f0_writeb (err -22) [ 312.608938] cywdhd: disagrees about version of symbol sdio_unregister_driver [ 312.616033] cywdhd: Unknown symbol sdio_unregister_driver (err -22) [ 312.622362] cywdhd: disagrees about version of symbol sdio_readsb [ 312.628484] cywdhd: Unknown symbol sdio_readsb (err -22) [ 312.633857] cywdhd: disagrees about version of symbol __cfg80211_send_event_skb [ 312.641216] cywdhd: Unknown symbol __cfg80211_send_event_skb (err -22) [ 312.647797] cywdhd: disagrees about version of symbol init_net [ 312.653671] cywdhd: Unknown symbol init_net (err -22) [ 312.658758] cywdhd: disagrees about version of symbol cfg80211_ibss_joined [ 312.665679] cywdhd: Unknown symbol cfg80211_ibss_joined (err -22) [ 312.671850] cywdhd: disagrees about version of symbol skb_pull [ 312.677710] cywdhd: Unknown symbol skb_pull (err -22) [ 312.682881] cywdhd: disagrees about version of symbol netlink_unicast [ 312.689353] cywdhd: Unknown symbol netlink_unicast (err -22) [ 312.695103] cywdhd: disagrees about version of symbol cfg80211_michael_mic_failure [ 312.702723] cywdhd: Unknown symbol cfg80211_michael_mic_failure (err -22) [ 312.709553] cywdhd: disagrees about version of symbol wiphy_apply_custom_regulatory [ 312.717259] cywdhd: Unknown symbol wiphy_apply_custom_regulatory (err -22) [ 312.724187] cywdhd: disagrees about version of symbol dev_close [ 312.730133] cywdhd: Unknown symbol dev_close (err -22) [ 312.735320] cywdhd: disagrees about version of symbol cfg80211_connect_result [ 312.742503] cywdhd: Unknown symbol cfg80211_connect_result (err -22) [ 312.748903] cywdhd: disagrees about version of symbol skb_push [ 312.754776] cywdhd: Unknown symbol skb_push (err -22) [ 312.759901] cywdhd: disagrees about version of symbol cfg80211_del_sta_sinfo [ 312.766996] cywdhd: Unknown symbol cfg80211_del_sta_sinfo (err -22) [ 312.773314] cywdhd: disagrees about version of symbol sdio_readl [ 312.779347] cywdhd: Unknown symbol sdio_readl (err -22) [ 312.784619] cywdhd: disagrees about version of symbol mmc_set_data_timeout [ 312.791539] cywdhd: Unknown symbol mmc_set_data_timeout (err -22) [ 312.797675] cywdhd: disagrees about version of symbol register_netdev [ 312.804160] cywdhd: Unknown symbol register_netdev (err -22) [ 312.809880] cywdhd: disagrees about version of symbol wiphy_unregister [ 312.816481] cywdhd: Unknown symbol wiphy_unregister (err -22) [ 312.822283] cywdhd: disagrees about version of symbol free_netdev [ 312.828404] cywdhd: Unknown symbol free_netdev (err -22) [ 312.833764] cywdhd: disagrees about version of symbol netlink_kernel_release [ 312.840844] cywdhd: Unknown symbol netlink_kernel_release (err -22) [ 312.847243] cywdhd: disagrees about version of symbol cfg80211_get_bss [ 312.853825] cywdhd: Unknown symbol cfg80211_get_bss (err -22) [ 312.859606] cywdhd: disagrees about version of symbol netif_tx_wake_queue [ 312.866439] cywdhd: Unknown symbol netif_tx_wake_queue (err -22) [ 312.872501] cywdhd: disagrees about version of symbol __ieee80211_get_channel [ 312.879670] cywdhd: Unknown symbol __ieee80211_get_channel (err -22) [ 312.886076] cywdhd: disagrees about version of symbol netif_rx_ni [ 312.892211] cywdhd: Unknown symbol netif_rx_ni (err -22) [ 312.897569] cywdhd: disagrees about version of symbol cfg80211_vendor_cmd_reply [ 312.904926] cywdhd: Unknown symbol cfg80211_vendor_cmd_reply (err -22) [ 312.911513] cywdhd: disagrees about version of symbol sdio_writel [ 312.917633] cywdhd: Unknown symbol sdio_writel (err -22) [ 312.923017] cywdhd: disagrees about version of symbol mmc_wait_for_req [ 312.929575] cywdhd: Unknown symbol mmc_wait_for_req (err -22) [ 312.935383] cywdhd: disagrees about version of symbol netif_rx [ 312.941258] cywdhd: Unknown symbol netif_rx (err -22) [ 312.946337] cywdhd: disagrees about version of symbol __netdev_alloc_skb [ 312.953083] cywdhd: Unknown symbol __netdev_alloc_skb (err -22) [ 312.959061] cywdhd: disagrees about version of symbol cfg80211_mgmt_tx_status [ 312.966243] cywdhd: Unknown symbol cfg80211_mgmt_tx_status (err -22) [ 312.972674] cywdhd: disagrees about version of symbol sdio_get_host_pm_caps [ 312.979667] cywdhd: Unknown symbol sdio_get_host_pm_caps (err -22) [ 312.985926] cywdhd: disagrees about version of symbol skb_realloc_headroom [ 312.992847] cywdhd: Unknown symbol skb_realloc_headroom (err -22) [ 312.998996] cywdhd: disagrees about version of symbol cfg80211_unregister_wdev [ 313.006342] cywdhd: Unknown symbol cfg80211_unregister_wdev (err -22) [ 313.012900] cywdhd: disagrees about version of symbol __dev_kfree_skb_any [ 313.019721] cywdhd: Unknown symbol __dev_kfree_skb_any (err -22) [ 313.025805] cywdhd: disagrees about version of symbol cfg80211_rx_mgmt [ 313.032379] cywdhd: Unknown symbol cfg80211_rx_mgmt (err -22) [ 313.038229] cywdhd: disagrees about version of symbol sdio_claim_irq [ 313.044630] cywdhd: Unknown symbol sdio_claim_irq (err -22) [ 313.050240] cywdhd: disagrees about version of symbol sdio_enable_func [ 313.056811] cywdhd: Unknown symbol sdio_enable_func (err -22) [ 313.062683] cywdhd: disagrees about version of symbol cfg80211_unlink_bss [ 313.069502] cywdhd: Unknown symbol cfg80211_unlink_bss (err -22) [ 313.076169] cywdhd: disagrees about version of symbol wiphy_free [ 313.082264] cywdhd: Unknown symbol wiphy_free (err -22) [ 313.087794] cywdhd: disagrees about version of symbol sdio_readb [ 313.093866] cywdhd: Unknown symbol sdio_readb (err -22) [ 313.099119] cywdhd: disagrees about version of symbol sdio_writeb [ 313.105257] cywdhd: Unknown symbol sdio_writeb (err -22) [ 313.110594] cywdhd: disagrees about version of symbol register_netdevice [ 313.117341] cywdhd: Unknown symbol register_netdevice (err -22) [ 313.549618] cywdhd: disagrees about version of symbol cfg80211_inform_bss_frame_data [ 313.557521] cywdhd: Unknown symbol cfg80211_inform_bss_frame_data (err -22) [ 313.564557] cywdhd: disagrees about version of symbol alloc_etherdev_mqs [ 313.571313] cywdhd: Unknown symbol alloc_etherdev_mqs (err -22) [ 313.577304] cywdhd: disagrees about version of symbol sdio_release_host [ 313.583967] cywdhd: Unknown symbol sdio_release_host (err -22) [ 313.589843] cywdhd: disagrees about version of symbol sdio_disable_func [ 313.596504] cywdhd: Unknown symbol sdio_disable_func (err -22) [ 313.602429] cywdhd: disagrees about version of symbol sdio_set_block_size [ 313.609248] cywdhd: Unknown symbol sdio_set_block_size (err -22) [ 313.615328] cywdhd: disagrees about version of symbol __nlmsg_put [ 313.621465] cywdhd: Unknown symbol __nlmsg_put (err -22) [ 313.626834] cywdhd: disagrees about version of symbol sock_wfree [ 313.632882] cywdhd: Unknown symbol sock_wfree (err -22) [ 313.638213] cywdhd: disagrees about version of symbol cfg80211_scan_done [ 313.644963] cywdhd: Unknown symbol cfg80211_scan_done (err -22) [ 313.650973] cywdhd: disagrees about version of symbol sdio_claim_host [ 313.657460] cywdhd: Unknown symbol sdio_claim_host (err -22) [ 313.663176] cywdhd: disagrees about version of symbol sdio_memcpy_fromio [ 313.669907] cywdhd: Unknown symbol sdio_memcpy_fromio (err -22) [ 313.675881] cywdhd: disagrees about version of symbol consume_skb [ 313.682019] cywdhd: Unknown symbol consume_skb (err -22) [ 313.687370] cywdhd: disagrees about version of symbol sdio_register_driver [ 313.694292] cywdhd: Unknown symbol sdio_register_driver (err -22) [ 313.700426] cywdhd: disagrees about version of symbol sdio_readw [ 313.706473] cywdhd: Unknown symbol sdio_readw (err -22) [ 313.711838] cywdhd: disagrees about version of symbol unregister_netdev [ 313.718483] cywdhd: Unknown symbol unregister_netdev (err -22) [ 313.724377] cywdhd: disagrees about version of symbol cfg80211_remain_on_channel_expired [ 313.732522] cywdhd: Unknown symbol cfg80211_remain_on_channel_expired (err -22) [ 313.740041] cywdhd: disagrees about version of symbol __netlink_kernel_create [ 313.747228] cywdhd: Unknown symbol __netlink_kernel_create (err -22) [ 313.753653] cywdhd: disagrees about version of symbol sdio_writew [ 313.759774] cywdhd: Unknown symbol sdio_writew (err -22) [ 313.765168] cywdhd: disagrees about version of symbol sdio_memcpy_toio [ 313.771825] cywdhd: Unknown symbol sdio_memcpy_toio (err -22) [ 313.777652] cywdhd: disagrees about version of symbol cfg80211_new_sta [ 313.784234] cywdhd: Unknown symbol cfg80211_new_sta (err -22) [ 313.790042] cywdhd: disagrees about version of symbol unregister_netdevice_queue [ 313.797491] cywdhd: Unknown symbol unregister_netdevice_queue (err -22) [ 313.804175] cywdhd: disagrees about version of symbol __pskb_copy_fclone [ 313.810906] cywdhd: Unknown symbol __pskb_copy_fclone (err -22) [ 313.816886] cywdhd: disagrees about version of symbol cfg80211_disconnected [ 313.823895] cywdhd: Unknown symbol cfg80211_disconnected (err -22) [ 313.830141] cywdhd: disagrees about version of symbol sdio_f0_readb [ 313.836453] cywdhd: Unknown symbol sdio_f0_readb (err -22) [ 313.841989] cywdhd: disagrees about version of symbol eth_type_trans [ 313.848372] cywdhd: Unknown symbol eth_type_trans (err -22) [ 313.854001] cywdhd: disagrees about version of symbol wiphy_new_nm [ 313.860210] cywdhd: Unknown symbol wiphy_new_nm (err -22) [ 313.865689] cywdhd: disagrees about version of symbol cfg80211_ready_on_channel [ 313.873049] cywdhd: Unknown symbol cfg80211_ready_on_channel (err -22) [ 313.879629] cywdhd: disagrees about version of symbol kfree_skb [ 313.885590] cywdhd: Unknown symbol kfree_skb (err -22) [ 313.890774] cywdhd: disagrees about version of symbol sdio_release_irq [ 313.897346] cywdhd: Unknown symbol sdio_release_irq (err -22) [ 313.903170] cywdhd: disagrees about version of symbol wiphy_register [ 313.909553] cywdhd: Unknown symbol wiphy_register (err -22) [ 313.915187] cywdhd: disagrees about version of symbol __cfg80211_alloc_reply_skb [ 313.922633] cywdhd: Unknown symbol __cfg80211_alloc_reply_skb (err -22) [ 313.929290] cywdhd: disagrees about version of symbol __cfg80211_alloc_event_skb [ 313.936735] cywdhd: Unknown symbol __cfg80211_alloc_event_skb (err -22) [ 313.943422] cywdhd: disagrees about version of symbol __alloc_skb [ 313.949543] cywdhd: Unknown symbol __alloc_skb (err -22) [ 313.954907] cywdhd: disagrees about version of symbol cfg80211_put_bss [ 313.961480] cywdhd: Unknown symbol cfg80211_put_bss (err -22) [ 313.967265] cywdhd: disagrees about version of symbol cfg80211_roamed [ 313.973749] cywdhd: Unknown symbol cfg80211_roamed (err -22) [ 313.979449] cywdhd: disagrees about version of symbol cfg80211_ch_switch_notify [ 313.986805] cywdhd: Unknown symbol cfg80211_ch_switch_notify (err -22) [ 313.993434] cywdhd: disagrees about version of symbol sdio_set_host_pm_flags [ 314.000515] cywdhd: Unknown symbol sdio_set_host_pm_flags (err -22) [ 314.006838] cywdhd: disagrees about version of symbol sdio_f0_writeb [ 314.013237] cywdhd: Unknown symbol sdio_f0_writeb (err -22) [ 314.018845] cywdhd: disagrees about version of symbol sdio_unregister_driver [ 314.025938] cywdhd: Unknown symbol sdio_unregister_driver (err -22) [ 314.032267] cywdhd: disagrees about version of symbol sdio_readsb [ 314.038388] cywdhd: Unknown symbol sdio_readsb (err -22) [ 314.043762] cywdhd: disagrees about version of symbol __cfg80211_send_event_skb [ 314.051105] cywdhd: Unknown symbol __cfg80211_send_event_skb (err -22) [ 314.057700] cywdhd: disagrees about version of symbol init_net [ 314.063575] cywdhd: Unknown symbol init_net (err -22) [ 314.068663] cywdhd: disagrees about version of symbol cfg80211_ibss_joined [ 314.075592] cywdhd: Unknown symbol cfg80211_ibss_joined (err -22) [ 314.081764] cywdhd: disagrees about version of symbol skb_pull [ 314.087624] cywdhd: Unknown symbol skb_pull (err -22) [ 314.092827] cywdhd: disagrees about version of symbol netlink_unicast [ 314.099300] cywdhd: Unknown symbol netlink_unicast (err -22) [ 314.105058] cywdhd: disagrees about version of symbol cfg80211_michael_mic_failure [ 314.112679] cywdhd: Unknown symbol cfg80211_michael_mic_failure (err -22) [ 314.119511] cywdhd: disagrees about version of symbol wiphy_apply_custom_regulatory [ 314.127218] cywdhd: Unknown symbol wiphy_apply_custom_regulatory (err -22) [ 314.134146] cywdhd: disagrees about version of symbol dev_close [ 314.140093] cywdhd: Unknown symbol dev_close (err -22) [ 314.145279] cywdhd: disagrees about version of symbol cfg80211_connect_result [ 314.152463] cywdhd: Unknown symbol cfg80211_connect_result (err -22) [ 314.158863] cywdhd: disagrees about version of symbol skb_push [ 314.164737] cywdhd: Unknown symbol skb_push (err -22) [ 314.169862] cywdhd: disagrees about version of symbol cfg80211_del_sta_sinfo [ 314.176959] cywdhd: Unknown symbol cfg80211_del_sta_sinfo (err -22) [ 314.183277] cywdhd: disagrees about version of symbol sdio_readl [ 314.189310] cywdhd: Unknown symbol sdio_readl (err -22) [ 314.194582] cywdhd: disagrees about version of symbol mmc_set_data_timeout [ 314.201504] cywdhd: Unknown symbol mmc_set_data_timeout (err -22) [ 314.207642] cywdhd: disagrees about version of symbol register_netdev [ 314.214126] cywdhd: Unknown symbol register_netdev (err -22) [ 314.219845] cywdhd: disagrees about version of symbol wiphy_unregister [ 314.226418] cywdhd: Unknown symbol wiphy_unregister (err -22) [ 314.232211] cywdhd: disagrees about version of symbol free_netdev [ 314.238332] cywdhd: Unknown symbol free_netdev (err -22) [ 314.243691] cywdhd: disagrees about version of symbol netlink_kernel_release [ 314.250770] cywdhd: Unknown symbol netlink_kernel_release (err -22) [ 314.257164] cywdhd: disagrees about version of symbol cfg80211_get_bss [ 314.263739] cywdhd: Unknown symbol cfg80211_get_bss (err -22) [ 314.269519] cywdhd: disagrees about version of symbol netif_tx_wake_queue [ 314.276352] cywdhd: Unknown symbol netif_tx_wake_queue (err -22) [ 314.282414] cywdhd: disagrees about version of symbol __ieee80211_get_channel [ 314.289581] cywdhd: Unknown symbol __ieee80211_get_channel (err -22) [ 314.295986] cywdhd: disagrees about version of symbol netif_rx_ni [ 314.302121] cywdhd: Unknown symbol netif_rx_ni (err -22) [ 314.307477] cywdhd: disagrees about version of symbol cfg80211_vendor_cmd_reply [ 314.314834] cywdhd: Unknown symbol cfg80211_vendor_cmd_reply (err -22) [ 314.321421] cywdhd: disagrees about version of symbol sdio_writel [ 314.327541] cywdhd: Unknown symbol sdio_writel (err -22) [ 314.332928] cywdhd: disagrees about version of symbol mmc_wait_for_req [ 314.339486] cywdhd: Unknown symbol mmc_wait_for_req (err -22) [ 314.345293] cywdhd: disagrees about version of symbol netif_rx [ 314.351167] cywdhd: Unknown symbol netif_rx (err -22) [ 314.356246] cywdhd: disagrees about version of symbol __netdev_alloc_skb [ 314.362991] cywdhd: Unknown symbol __netdev_alloc_skb (err -22) [ 314.368968] cywdhd: disagrees about version of symbol cfg80211_mgmt_tx_status [ 314.376150] cywdhd: Unknown symbol cfg80211_mgmt_tx_status (err -22) [ 314.382579] cywdhd: disagrees about version of symbol sdio_get_host_pm_caps [ 314.389572] cywdhd: Unknown symbol sdio_get_host_pm_caps (err -22) [ 314.395831] cywdhd: disagrees about version of symbol skb_realloc_headroom [ 314.402753] cywdhd: Unknown symbol skb_realloc_headroom (err -22) [ 314.408905] cywdhd: disagrees about version of symbol cfg80211_unregister_wdev [ 314.416204] cywdhd: Unknown symbol cfg80211_unregister_wdev (err -22) [ 314.422753] cywdhd: disagrees about version of symbol __dev_kfree_skb_any [ 314.429573] cywdhd: Unknown symbol __dev_kfree_skb_any (err -22) [ 314.435657] cywdhd: disagrees about version of symbol cfg80211_rx_mgmt [ 314.442231] cywdhd: Unknown symbol cfg80211_rx_mgmt (err -22) [ 314.448077] cywdhd: disagrees about version of symbol sdio_claim_irq [ 314.454478] cywdhd: Unknown symbol sdio_claim_irq (err -22) [ 314.460088] cywdhd: disagrees about version of symbol sdio_enable_func [ 314.466660] cywdhd: Unknown symbol sdio_enable_func (err -22) [ 314.472529] cywdhd: disagrees about version of symbol cfg80211_unlink_bss [ 314.479349] cywdhd: Unknown symbol cfg80211_unlink_bss (err -22) [ 314.485403] cywdhd: disagrees about version of symbol wiphy_free [ 314.491452] cywdhd: Unknown symbol wiphy_free (err -22) [ 314.496752] cywdhd: disagrees about version of symbol sdio_readb [ 314.502802] cywdhd: Unknown symbol sdio_readb (err -22) [ 314.508053] cywdhd: disagrees about version of symbol sdio_writeb [ 314.514187] cywdhd: Unknown symbol sdio_writeb (err -22) [ 314.519525] cywdhd: disagrees about version of symbol register_netdevice [ 314.526270] cywdhd: Unknown symbol register_netdevice (err -22) insmod: can't insert 'cywdhd.ko': Invalid argument /oya/wifi #
Hi we are trying to bring up the WiFi on our board, but we get errors when we try to insmod wifi. please check the 9_1_2020_log.txt
The schematics are also shared fyi.
Any help will be greatly appreciated!
Anik
