We are using WL1831MOD module to which i need to connecot PCB type antenna with IPEX MHF connector, Please suggest me suitable antennas for this module with minimum size.
Yaseen
Yaseen
Hi Yaseen,
I hope all is well. I believe that the IPEX MHF connector is equivalent to the U.FL connector. You can see a list of our recommended antennas on our DoC for the WL1831MOD. This can be found here: www.ti.com/.../swrq047.pdf.
For example you may be able to use the LSR whip antenna (001-0012) with one of the cable assemblies (008-0013), depending on your applications. Other options may be the Ethertronics antenna that connects with a U.FL connector.
Riz
Hi Rizwan,
The recommended anted we are using already , we are looking for smaller in size example around 20X10X1mm.
Yaseen
