Other Parts Discussed in Thread: AM3358, WL1835
hello,
we have interface wl1835 wifi chip with out am3358 based custom board and ping google successfully.
now i am interfacing Bluetooth on UART 5
i am following
i have configure UART 5 something like
uart5_pins: uart5_pins {
pinctrl-single,pins = <
AM33XX_IOPAD(0x908, PIN_INPUT_PULLUP | MUX_MODE3) /* (H16) gmii1_col.uart5_rxd */
AM33XX_IOPAD(0x944, PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* (H18) rmii1_refclk.uart5_txd */
AM33XX_IOPAD(0x90c, PIN_INPUT | MUX_MODE5) /* (H17) gmii1_crs.uart5_ctsn */
AM33XX_IOPAD(0x910, PIN_OUTPUT_PULLDOWN | MUX_MODE5) /* (J15) gmii1_rxer.uart5_rtsn */
&uart5 {
pinctrl-names = "default";
pinctrl-0 = <&uart5_pins>;
uart-has-rtscts; //fsl,uart-has-rtscts;
status = "okay";
bluetooth {
compatible = "ti,wl1835-st","ti,wl1835";
// enable-gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>;
in dtsi file i have changed
uart5: serial@481aa000 {
compatible = "ti,am3352-uart", "ti,omap3-uart";
ti,hwmods = "uart6";
clock-frequency = <48000000>;
reg = <0x481aa000 0x2000>;
interrupts = <46>;
status = "okay";
dmas = <&edma 3 1>, <&edma 4 1>;
dma-names = "tx", "rx", "rts", "cts";
i am getting bluetooth communication log at board boot time
Arago Project http://arago-project.org am335x-evm ttyS0 Arago 2019.07 am335x-evm ttyS0 am335x-evm login: U-Boot SPL 2019.01-g1ebdbc7d8b-dirty (Feb 25 2020 - 17:17:00 +0530) Trying to boot from MMC1 U-Boot 2019.01-g1ebdbc7d8b-dirty (Feb 25 2020 - 17:17:00 +0530) *********************** Aarohi02 *********************** CPU : AM335X-GP rev 2.1 Model: TI AM335x EVM DRAM: 1 GiB NAND: 0 MiB MMC: OMAP SD/MMC: 0 Loading Environment from FAT... *** Warning - bad CRC, using default environment <ethaddr> not set. Validating first E-fuse MAC Net: Could not get PHY for ethernet@4a100000: addr 0 eth0: ethernet@4a100000 Warning: usb_ether MAC addresses don't match: Address in ROM is de:ad:be:ef:00:01 Address in environment is 04:79:b7:03:11:1b , eth1: usb_ether Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 ** Unable to read file boot.scr ** 264 bytes read in 1 ms (257.8 KiB/s) Loaded env from uEnv.txt Importing environment from mmc0 ... Running uenvcmd ... 4375040 bytes read in 287 ms (14.5 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8fff3000, end 8ffff5bd ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.59-g5f8c1c6121 (raju@Raju-PC) (gcc version 8.0 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie [ 0.000000] OF: fdt: Machine model: TI AM335x EVM-SK [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0xbd000000 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (sgx neon) [ 0.000000] random: get_random_bytes called from start_kernel+0xa4/0x434 wit0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 4 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 975324K/1048576K available (9216K kernel code, 314K rwda) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (10208 kB) [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB) [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 315 kB) [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 264 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrus [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 8947s [ 0.000034] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, mas [ 0.000045] OMAP clocksource: timer1 at 24000000 Hz [ 0.000200] timer_probe: no matching timers found [ 0.000372] Console: colour dummy device 80x30 [ 0.000399] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000406] This ensures that you still see kernel messages. Please [ 0.000411] update your kernel commandline. [ 0.000464] Calibrating delay loop (skipped) preset value.. 718.02 BogoMIPS ) [ 0.000481] pid_max: default: 32768 minimum: 301 [ 0.000671] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000688] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001455] CPU: Testing write buffer coherency: ok [ 0.001519] CPU0: Spectre v2: using BPIALL workaround [ 0.002338] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.002482] rcu: Hierarchical SRCU implementation. [ 0.002794] EFI services will not be available. [ 0.004087] devtmpfs: initialized [ 0.011493] VFP support v0.3: implementor 41 architecture 3 part 30 variant 3 [ 0.011862] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms [ 0.011885] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.015271] pinctrl core: initialized pinctrl subsystem [ 0.015993] DMI not present or invalid. [ 0.016427] NET: Registered protocol family 16 [ 0.018556] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.024285] omap_hwmod: mcasp1: no dt node [ 0.024306] ------------[ cut here ]------------ [ 0.024344] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 8 [ 0.024350] omap_hwmod: mcasp1: doesn't have mpu register target base [ 0.024357] Modules linked in: [ 0.024376] CPU: 0 PID: 1 Comm: swapper Not tainted 4.19.59-g5f8c1c6121 #4 [ 0.024383] Hardware name: Generic AM33XX (Flattened Device Tree) [ 0.024390] Backtrace: [ 0.024412] [<c010cb64>] (dump_backtrace) from [<c010ced4>] (show_stack+0x18) [ 0.024424] r7:00000009 r6:00000000 r5:c0bc6b70 r4:ee885de4 [ 0.024440] [<c010cebc>] (show_stack) from [<c0947694>] (dump_stack+0x24/0x2) [ 0.024460] [<c0947670>] (dump_stack) from [<c012aab8>] (__warn+0xe0/0xf8) [ 0.024473] [<c012a9d8>] (__warn) from [<c012a710>] (warn_slowpath_fmt+0x50/) [ 0.024484] r9:c0d3d820 r8:00000000 r7:c0e0a2c0 r6:00000000 r5:c0bc7100 r4:8 [ 0.024497] [<c012a6c4>] (warn_slowpath_fmt) from [<c0d0b724>] (_init.constp) [ 0.024505] r3:c0bc85e8 r2:c0bc7100 [ 0.024512] r5:00000000 r4:c0e0a288 [ 0.024524] [<c0d0b578>] (_init.constprop.21) from [<c0d0bb80>] (__omap_hwmo) [ 0.024535] r10:00000003 r9:c0d3d820 r8:00000000 r7:c0d0bb38 r6:ffffe000 r50 [ 0.024541] r4:c0e0a288 [ 0.024557] [<c0d0bb38>] (__omap_hwmod_setup_all) from [<c0102640>] (do_one_) [ 0.024564] r5:c0e03048 r4:c0e4e900 [ 0.024587] [<c01025bc>] (do_one_initcall) from [<c0d00f2c>] (kernel_init_fr) [ 0.024598] r8:c0d3d840 r7:c0e4e900 r6:c0e4e900 r5:c0d503c4 r4:c0cac6a4 [ 0.024617] [<c0d00de4>] (kernel_init_freeable) from [<c095b970>] (kernel_in) [ 0.024627] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r50 [ 0.024634] r4:00000000 [ 0.024644] [<c095b960>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14) [ 0.024652] Exception stack(0xee885fb0 to 0xee885ff8) [ 0.024662] 5fa0: 00000000 00000000 00000 [ 0.024673] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000 [ 0.024683] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.024691] r5:c095b960 r4:00000000 [ 0.024706] ---[ end trace a3943eeea60c08ae ]--- [ 0.036503] l4_wkup_cm:clk:0010:0: failed to disable [ 0.077558] cpuidle: using governor ladder [ 0.077594] cpuidle: using governor menu [ 0.082335] OMAP GPIO hardware version 0.1 [ 0.091726] No ATAGs? [ 0.091745] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.104705] edma 49000000.edma: TI EDMA DMA engine driver [ 0.106198] v1_8d: supplied by vbat [ 0.106472] v3_3d: supplied by vbat [ 0.108746] SCSI subsystem initialized [ 0.109396] media: Linux media interface: v0.10 [ 0.109441] videodev: Linux video capture interface: v2.00 [ 0.109528] pps_core: LinuxPPS API ver. 1 registered [ 0.109537] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom> [ 0.109557] PTP clock support registered [ 0.109589] EDAC MC: Ver: 3.0.0 [ 0.110632] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.111224] Advanced Linux Sound Architecture Driver Initialized. [ 0.111768] Bluetooth: Core ver 2.22 [ 0.111825] NET: Registered protocol family 31 [ 0.111833] Bluetooth: HCI device and connection manager initialized [ 0.111847] Bluetooth: HCI socket layer initialized [ 0.111856] Bluetooth: L2CAP socket layer initialized [ 0.111885] Bluetooth: SCO socket layer initialized [ 0.112517] clocksource: Switched to clocksource timer1 [ 0.120305] NET: Registered protocol family 2 [ 0.121081] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096) [ 0.121112] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.121181] TCP bind hash table entries: 8192 (order: 3, 32768 bytes) [ 0.121247] TCP: Hash tables configured (established 8192 bind 8192) [ 0.121372] UDP hash table entries: 512 (order: 1, 8192 bytes) [ 0.121396] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) [ 0.121542] NET: Registered protocol family 1 [ 0.122101] RPC: Registered named UNIX socket transport module. [ 0.122113] RPC: Registered udp transport module. [ 0.122119] RPC: Registered tcp transport module. [ 0.122125] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.123166] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 countee [ 0.124401] Initialise system trusted keyrings [ 0.124748] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 0.128975] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.129714] NFS: Registering the id_resolver key type [ 0.129765] Key type id_resolver registered [ 0.129773] Key type id_legacy registered [ 0.129812] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.134904] Key type asymmetric registered [ 0.134920] Asymmetric key parser 'x509' registered [ 0.134992] bounce: pool size: 64 pages [ 0.135061] Block layer SCSI generic (bsg) driver version 0.4 loaded (major ) [ 0.135074] io scheduler noop registered [ 0.135082] io scheduler deadline registered [ 0.135328] io scheduler cfq registered (default) [ 0.135339] io scheduler mq-deadline registered [ 0.135347] io scheduler kyber registered [ 0.137094] pinctrl-single 44e10800.pinmux: 142 pins, size 568 [ 0.140213] pwm-backlight backlight: backlight supply power not found, usingr [ 0.140310] pwm-backlight backlight: Linked as a consumer to regulator.0 [ 0.185481] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.189191] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud =0 [ 1.077506] console [ttyS0] enabled [ 1.082063] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud =0 [ 1.091877] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 32, base_baud =0 [ 1.100859] serial serial0: tty port ttyS5 registered [ 1.107782] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 1.114195] random: fast init done [ 1.117811] random: crng init done [ 1.123265] tilcdc-panel panel: found backlight [ 1.128138] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 1.134480] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 1.140902] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 1.146913] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.153569] [drm] No driver support for vblank timestamp query. [ 1.204341] Console: switching to colour frame buffer device 60x34 [ 1.228245] tilcdc 4830e000.lcdc: fb0: DRM emulated frame buffer device [ 1.235461] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on min0 [ 1.254269] brd: module loaded [ 1.263906] loop: module loaded [ 1.269554] libphy: Fixed MDIO Bus: probed [ 1.342572] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 0 [ 1.350284] davinci_mdio 4a101000.mdio: detected phy mask fffffffe [ 1.357535] libphy: 4a101000.mdio: probed [ 1.361577] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, drit [ 1.371837] cpsw 4a100000.ethernet: No slave[1] phy_id, phy-handle, or fixedy [ 1.380292] cpsw 4a100000.ethernet: Missing dual_emac_res_vlan in DT. [ 1.386833] cpsw 4a100000.ethernet: Using 2 as Reserved VLAN for 1 slave [ 1.393604] cpsw 4a100000.ethernet: Detected MACID = 04:79:b7:03:11:19 [ 1.400278] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4 [ 1.406708] cpsw 4a100000.ethernet: ALE Table size 1024 [ 1.411984] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies) [ 1.419992] cpsw 4a100000.ethernet: cpsw: Detected MACID = 04:79:b7:03:11:1b [ 1.428358] i2c /dev entries driver [ 1.433015] Bluetooth: HCI UART driver ver 2.3 [ 1.437487] Bluetooth: HCI UART protocol H4 registered [ 1.444054] Bluetooth: HCI UART protocol LL registered [ 1.449393] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 1.455970] Bluetooth: HCI UART protocol Broadcom registered [ 1.462934] cpuidle: enable-method property 'ti,am3352' found operations [ 1.470137] sdhci: Secure Digital Host Controller Interface driver [ 1.476447] sdhci: Copyright(c) Pierre Ossman [ 1.481574] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000) [ 1.490423] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.496700] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.504077] ledtrig-cpu: registered to indicate activity on CPUs [ 1.514484] NET: Registered protocol family 10 [ 1.520301] Segment Routing with IPv6 [ 1.524258] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 1.530909] NET: Registered protocol family 17 [ 1.535791] Key type dns_resolver registered [ 1.540392] omap_voltage_late_init: Voltage driver support not added [ 1.547722] Loading compiled-in X.509 certificates [ 1.592751] tps65910 0-002d: No interrupt support, no core IRQ [ 1.600413] vrtc: supplied by vbat [ 1.607471] vio: supplied by vbat [ 1.612226] vdd1: supplied by vbat [ 1.617354] vdd2: supplied by vbat [ 1.623765] vdig1: supplied by vbat [ 1.628544] vdig2: supplied by vbat [ 1.633323] vpll: supplied by vbat [ 1.638006] vdac: supplied by vbat [ 1.642714] vaux1: supplied by vbat [ 1.647496] vaux2: supplied by vbat [ 1.652246] vaux33: supplied by vbat [ 1.657124] vmmc: supplied by vbat [ 1.661788] vbb: supplied by vbat [ 1.666561] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 1.672630] cpu cpu0: Linked as a consumer to regulator.9 [ 1.678091] Bluetooth: hci0: Failed to get CTS [ 1.682693] cpu cpu0: Dropping the link to regulator.9 [ 1.688027] cpu cpu0: Linked as a consumer to regulator.9 [ 1.694996] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000) [ 1.703902] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.709075] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.19 [ 1.745336] omap_hsmmc 47810000.mmc: Linked as a consumer to regulator.6 [ 1.785308] mmc0: host does not support reading read-only switch, assuming we [ 1.795633] mmc0: new high speed SDHC card at address 59b4 [ 1.803415] mmcblk0: mmc0:59b4 00000 7.48 GiB [ 1.811196] mmcblk0: p1 p2 [ 1.869545] hctosys: unable to open rtc device (rtc0) [ 1.876114] lis3_reg: disabling [ 1.879372] v1_8d: disabling [ 1.882310] v3_3d: disabling [ 1.885495] ALSA device list: [ 1.888528] No soundcards found. [ 1.892333] omap_hsmmc 47810000.mmc: card claims to support voltages below de [ 1.902475] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 sum [ 1.921125] mmc1: new high speed SDIO card at address 0001 [ 2.069622] EXT4-fs (mmcblk0p2): recovery complete [ 2.161871] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. ) [ 2.170281] VFS: Mounted root (ext3 filesystem) on device 179:2. [ 2.187265] devtmpfs: mounted [ 2.191750] Freeing unused kernel memory: 1024K [ 2.196911] Run /sbin/init as init process [ 2.619926] systemd[1]: System time before build time, advancing clock. [ 2.675223] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SE) [ 2.697508] systemd[1]: Detected architecture arm. Welcome to Arago 2019.07! [ 2.743984] systemd[1]: Set hostname to <am335x-evm>. [ 3.274920] systemd[1]: File /lib/systemd/system/systemd-journald.service:36. [ 3.292235] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warn) [ 3.382784] systemd[1]: /lib/systemd/system/gadget-init.service:15: Unknown ' [ 3.876289] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 3.914238] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 3.963946] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 3.997926] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Reached target Remote File Systems. [ OK ] Listening on Network Service Netlink Socket. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Swap. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Listening on Journal Socket. Starting Load Kernel Modules... Starting Create list of required st��…ce nodes for the current kernel.. [ 4.309551] cryptodev: loading out-of-tree module taints kernel. Starting Remount Root and Kernel File Systems... [ 4.335949] cryptodev: driver 1.9 loaded. Starting Journal Service... [ 4.411216] usbcore: registered new interface driver usbfs Mounting Kernel Debug File System... [ 4.477086] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Mounting Temporary Directory (/tmp)... [ 4.502857] usbcore: registered new interface driver hub [ 4.530515] usbcore: registered new device driver usb [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Created slice User and Session Slice. [ OK ] Reached target Slices. [ 4.599765] usbcore: registered new interface driver ftdi_sio Mounting POSIX Message Queue File System... [ OK ] Listening on udev Control Socket. [ OK ] Reached target Paths. [ OK ] Listening on udev Kernel Socket. [ 4.634381] usbserial: USB Serial support registered for FTDI USB Serial Deve Starting udev Coldplug all Devices... [ OK ] Started Create list of required sta��…vice nodes for the current kerne. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Mounted POSIX Message Queue File System. Starting Apply Kernel Variables... Mounting Kernel Configuration File System... Starting Create Static Device Nodes in /dev... [ OK ] Started Journal Service. [FAILED] Failed to start Apply Kernel Variables. See 'systemctl status systemd-sysctl.service' for details. [ OK ] Mounted Kernel Configuration File System. Starting Flush Journal to Persistent Storage... [ OK ] Started Create Static Device Nodes in /dev. [ 5.274956] systemd-journald[85]: Received request to flush runtime journal 1 Starting udev Kernel Device Manager... [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... [ OK ] Reached target Containers. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. [ OK ] Started udev Kernel Device Manager. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Load/Save Random Seed. [ OK ] Started Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... Starting Network Service... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Service. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Synchronized. [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. [ 7.893687] omap_rtc 44e3e000.rtc: already running [ 7.908357] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 8.003305] omap_rtc 44e3e000.rtc: registered as rtc0 [ OK ] Started udev Coldplug all Devices. [ OK ] Found device /dev/ttyS0. [ OK ] Created slice system-systemd\x2dbacklight.slice. Starting Load/Save Screen Backlight��…ightness of backlight:backlight.. [ 9.114462] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 9.155310] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 9.242811] omap-aes 53500000.aes: will run requests pump with realtime prioy [ 9.332367] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.sgx on 1 [ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight. [ 9.504687] remoteproc remoteproc0: wkup_m3 is available [ 9.539505] remoteproc remoteproc0: powering up wkup_m3 [ 9.546447] PM: Cannot get wkup_m3_ipc handle [ 9.607251] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf,6 Starting Apply Kernel Variables... [ 9.733081] remoteproc remoteproc0: remote processor wkup_m3 is now up [ 9.733105] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192 [FAILED] Failed to start Apply Kernel Variables. See 'systemctl status systemd-sysctl.service' for details. [ OK ] Found device /dev/ttyS3. [ 10.712776] net eth1: initializing cpsw version 1.12 (0) [ 10.720528] libphy: PHY not found [ 10.854429] net eth1: phy "" not found on slave 1, err -19 [ 11.016455] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 11.328180] net eth0: initializing cpsw version 1.12 (0) [ 11.464425] Atheros 8031 ethernet 4a101000.mdio:00: attached PHY driver [Ath) [ 11.610190] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 14.917184] TI-am335x-tsc TI-am335x-tsc.0.auto: ti,charge-delay not specified [ 14.987170] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/TI-am335x0 [ 15.073778] PM: bootloader does not support rtc-only! [ 15.602117] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc r [* ] (1 of 3) A start job is running for��…-mmcblk0p1.device (11s / 1min 300 [ 15.821279] musb-hdrc musb-hdrc.0: MUSB HDRC host driver [ 15.842795] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc r [ 15.917309] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus numb1 [ 15.969143] am335x-phy-driver 47401b00.usb-phy: Linked as a consumer to regu0 [ 15.991524] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, b9 [ 16.042821] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1 [ 16.050140] usb usb1: Product: MUSB HDRC host driver [ 16.189175] cfg80211: Loading compiled-in X.509 certificates for regulatory e [ 16.199724] usb usb1: Manufacturer: Linux 4.19.59-g5f8c1c6121 musb-hcd [ 16.241358] usb usb1: SerialNumber: musb-hdrc.0 [ 16.279430] hub 1-0:1.0: USB hub found [ 16.314699] hub 1-0:1.0: 1 port detected [ 16.376423] musb-hdrc musb-hdrc.1: MUSB HDRC host driver [ 16.381806] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus numb2 [ 16.403742] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 16.526797] remoteproc remoteproc1: 4a334000.pru is available [** ] (1 of 3) A start job is running for��…-mmcblk0p1.device (12s / 1min 309 [ 16.652751] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed succey [ 16.661132] remoteproc remoteproc2: 4a338000.pru is available [ 16.722722] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1 [ 16.782443] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed succey [ 16.794711] usb usb2: Product: MUSB HDRC host driver [ 16.827294] usb usb2: Manufacturer: Linux 4.19.59-g5f8c1c6121 musb-hcd [ 16.882714] usb usb2: SerialNumber: musb-hdrc.1 [ 16.923312] platform regulatory.0: Direct firmware load for regulatory.db fa2 [ 16.952903] hub 2-0:1.0: USB hub found [ 16.959093] hub 2-0:1.0: 1 port detected [ 16.992823] cfg80211: failed to load regulatory.db [ 17.108279] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connect2 [ *** ] (2 of 3) A start job is running for��… to be Configured (13s / no limi) [ 17.753362] wlcore: loaded [ ***] (2 of 3) A start job is running for��… to be Configured (14s / no limi0 [ 18.636414] wlcore: firmware booted (Rev 8.9.0.0.76) [ 18.665480] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ OK ] Found device /dev/mmcblk0p1. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Created slice system-systemd\x2dfsck.slice. Starting File System Check on /dev/mmcblk0p1... [ OK ] Reached target System Initialization. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Started Daily rotation of log files. Starting Reboot and dump vmcore via kexec... [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. Starting Start USB gadget... [ OK ] Started Redis In-Memory Data Store. [ OK ] Started Periodic Command Scheduler. Starting Bluetooth service... Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Login Service... Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started Job spooling tools. Starting Lightning Fast Webserver With Light System Requirements... Starting Permit User Sessions... [ 23.366994] using random self ethernet address [ 23.371481] using random host ethernet address [ 23.467345] using host ethernet address: 04:79:B7:03:11:1B [ 23.467428] using random self ethernet address [ OK ] Started D-Bus System Message Bus. [ 23.567236] using random host ethernet address [ 23.607864] using host ethernet address: 04:79:B7:03:11:1B [ 23.611506] usb0: HOST MAC 04:79:b7:03:11:1b [ 23.690333] usb0: MAC 52:92:a1:26:dc:55 Starting RPC Bind Service... [ 23.782220] Mass Storage Function, version: 2009/09/11 [ 23.824631] LUN: removable file: (no medium) Starting uim-sysfs.service... [ 23.860622] LUN: removable read only file: /dev/mmcblk0p1 [ 23.915263] Number of LUNs=1 Starting Print notice about GPLv3 packages... [ 23.945357] g_multi gadget: Multifunction Composite Gadget Starting Enable and configure wl18xx bluetooth stack... [ 23.994144] g_multi gadget: g_multi ready [ OK ] Started File System Check on /dev/mmcblk0p1. [ OK ] Started Reboot and dump vmcore via kexec. [ 24.228446] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready [ OK ] Started Lightning Fast Webserver With Light System Requirements. [ OK ] Started Permit User Sessions. [ OK ] Started RPC Bind Service. [ OK ] Found device /dev/ttyGS0. [ OK ] Started Start USB gadget. Starting Hostname Service... Starting Load/Save RF Kill Switch Status... [ OK ] Started NFS status monitor for NFSv2/3 locking.. [ OK ] Started Serial Getty on ttyS0. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS3. [ OK ] Started Serial Getty on ttyGS0. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Mounting /run/media/mmcblk0p1... [ OK ] Started Load/Save RF Kill Switch Status. [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ OK ] Started Synchronize System and HW clocks. [ OK ] Started Bluetooth service. [ OK ] Started Login Service. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Reached target Bluetooth. [ OK ] Mounted /run/media/mmcblk0p1. [ OK ] Started Hostname Service. [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started uim-sysfs.service. Starting rc.pvr.service... [ 26.980290] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ] [ OK ] Started rc.pvr.service. Starting weston.service... *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils cifs-utils cpio cpp-symlinks cpp dosfstools elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav gzip hidapi libbfd libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmavconn libmpc3 libmpfr6 libreadline-dev libreadline7 libunistring2 m4-dev m4 make mavlink mavros-extras mavros-msgs mavros nettle pdm-anomaly-detection socketcan-interface which If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am335x-evm ttyS0 Arago 2019.07 am335x-evm ttyS0 am335x-evm login:
alse while board on after some time i am getting message somthing like
[ 393.552506] Bluetooth: hci0: Frame reassembly failed (-84) [ 393.620008] Bluetooth: hci0: Frame reassembly failed (-84) [ 398.394348] Bluetooth: hci0: Frame reassembly failed (-84) [ 398.400329] Bluetooth: hci0: Frame reassembly failed (-84)
i have changed bt-en.sh file accoerding to our board configutation something like
#!/bin/bash
function bten_335_evm {
echo 66 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio66/direction
echo 1 > /sys/class/gpio/gpio66/value
echo "Done enabling BT"
local gpio="nshutdown_gpio=66"
local tty="tty=/dev/ttyS5"
local flow="flow_cntrl=1"
local baud_rate="baud_rate=3000000"
sudo rm -r /home/root/tibt
mkdir /home/root/tibt
echo $gpio > /home/root/tibt/config
echo $tty >> /home/root/tibt/config
echo $flow >> /home/root/tibt/config
echo $baud_rate >> /home/root/tibt/config
and result of this file
root@am335x-evm:~/BluetopiaPM# ./bt-en.sh ./bt-en.sh: line 52: warning: command substitution: ignored null byte in input TI AM335x EVM-SK success Done enabling BT root@am335x-evm:~/BluetopiaPM#
but while i am running
cd /home/root/BluetopiaPM/bin
./SS1BTPM &
./LinuxSPPM
Initialize 1
SetDevicePower 1
echo 66 > /sys/class/gpio/export sh: line 0: echo: write error: Device or resource busy echo out > /sys/class/gpio/gpio66/direction echo 0 > /sys/class/gpio/gpio66/value echo 1 > /sys/class/gpio/gpio66/value echo 0 > /sys/class/gpio/gpio66/value echo 1 > /sys/class/gpio/gpio66/value BT COMM PORT (/dev/ttyS5): -5 DEVM_PowerOnDevice() Failure: -14, Unknown Error. Function Error. SPPM>
i am getting in boot log
<strong>[ 1.678091] Bluetooth: hci0: Failed to get CTS</strong>
