Hi experts,
Currently, my customer has created a custom board using the WL1837MODGI. They are trying to get FCC approval on their custom board and are using the "Calibrator Tool" to measure the power waveform. To do so, they are investigating the following.WiLink8 Calibrator Tool User's Guide
Q1: Could you please tell me the following parameters when TI obtained FCC approval for the module at 2.4GHz and 5GHz frequencies?
- tune_channel Command Parameters
- set_tx_power Command Parameters
- start_tx Command Parameters
- other (if there are any other settings you need)
Q2: Could you tell us how you obtained the FCC?
I checked the "WL18MODGI Module Certification Reports" document, but it seems that you did not use the Calibrator, but used some kind of tool on your PC. I would like to know what tool was used on the PC and what setting values were used on the module.WL18XX-REPORTS_4.10.00.00
I apologize for the rush, but the customer is in a great hurry and would appreciate a response by 1/21. If you need more time than that, please let me know.
O.H
